Old 12-12-2013, 10:52 AM   #1
slam59
Old dry lightbulb grease making contact bad
Went to change rear tail light turn signal bulb and replaced it but after 10 minutes of driving my turn signal was blinking real fast again so took apart to make sure it was in all the way and discovered that the light brown colored bulb grease was old and dried out in the socket and I believe it is not giving a good contact on the new bulb. Cause when I moved the bulb back and forth it would work so I got it in the right position and working for a day only to have it blinking fast again and not working. How do you clean it out and with what and do I disconnect a battery terminal before doing so?
1974 C10 swb 350
1977 3/4 ton Silverado 454
1999 2 door 2wd Tahoe
slam59 is offline   Reply With Quote
Old 12-12-2013, 01:48 PM   #2
83GMCK2500
Re: Old dry lightbulb grease making contact bad
I clean it with one of two products:
CRC Lectra-MotiveŽ Electric Parts Cleaner
CRC QDŽ Contact Cleaner
I usually spray it on the rag, stuff rag in bulb socket, let it soften up the old grease, and twist it out.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 12-12-2013, 03:15 PM   #3
slam59
Thanks 83gmck. I gotta try that on mine. Again thanks for the tip!
1974 C10 swb 350
Old 12-12-2013, 05:33 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
And then add a gob of fresh dielectric grease....
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-12-2013, 06:00 PM   #5
rudey737
Plus one on the new dielectric grease. Your local part store will sell it for a couple of bucks in a small packet and it'll be more than enough to do all of your bulbs in the truck.
Azulita - 84 Chevy Scottsdale Longbed 305/350
rudey737 is offline   Reply With Quote
Old 12-12-2013, 06:06 PM   #6
Tx Firefighter
I buy my dielectric grease off of eBay. You can buy giant toothpaste sized tubes cheap.
