Old 12-13-2013, 01:42 AM   #1326
67chevy1series
67chevy1series's Avatar
Re: 1967 Chevy CST aka "the loud truck"
Beautiful write up! I need to find out where to buy the correct crush sleeve I cannot find it anywhere here in Merced!
67chevy1series is offline   Reply With Quote
Old 12-13-2013, 02:37 AM   #1327
Pegman
Pegman's Avatar
Nice very nice
Pegman is offline   Reply With Quote
Old 12-13-2013, 03:39 AM   #1328
67chevy1series
Yeah Jeremy usually has the answer!
Old 12-13-2013, 04:30 AM   #1329
NewType72
NewType72's Avatar
Rick to answer your question on the gas mileage I think we run pretty close in this aspect least same area haha. I get 10 city and 12 highway 350/330hp th350 trans with shift kit 15mph and then 40ish it shifts. 3:73 gears doglegger.
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 12-13-2013, 04:14 PM   #1330
67chevy1series
Lol ok so it's a little less then what I have now lol
And I've been doing some searching and I think if I'm correct a 700r shortbed driveline is 55"-55.5"? Am I correct?
Old 12-13-2013, 08:25 PM   #1331
DesertCat
DesertCat's Avatar
Rick! 9999 posts? wow!
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131
DesertCat is offline   Reply With Quote
Old 12-13-2013, 08:26 PM   #1332
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
He has a lot to say....just sayin'...
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 12-13-2013, 11:08 PM   #1333
jbclassix
Junk Yartist
jbclassix's Avatar
Rick, look into a 200r. It can be built just as strong if not stronger than a 700r and is the same length as a TH350
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 12-14-2013, 05:36 AM   #1334
67chevy1series
Hahaha! And to think my 10,000 post is on my own build thread! That's scary... There 10,000 times you can find a post from me! I wouldn't rather hav posted on any other site 10,000 times more then here!
I already have a fresh rebuilt never used 700r with a shift kit installed.
All I need for the the 700r/posi/3.73 install is:
I need a tilt shift indcator lense for a 700r and a shorter drive line
As for the posi/3.73 install I need the correct crush sleeve, posi additive and 80w90 diff lube as well as guidance from a well expeienced individual lol I'm not scared to install the pinnion I'm just worried about how well it's going to be installed or last lol
Old 12-15-2013, 01:37 AM   #1335
67chevy1series
Well I messed with the fuel guage situation a little today... When I disconnect the brown wire at the tank it goes all the way to full and then when I reconnect it it just goes to empty.
Old 12-15-2013, 01:39 AM   #1336
67chevy1series
Well I have bought a new sending unit and now when I disconnect the brown wire my guage reads full and when I reconnect it goes to empty... Took the sending unit out and grounded it, connected the brown wire and moved the floater and the fuel guage would move
Old 12-16-2013, 01:14 AM   #1337
67chevy1series
I picked up a drive line today that will work with my 700r swap so now I'm down to:
11 quarts of ATF
And I need to figure out how the 700r overdrive cable connects to my 1406 eddy since it doesn't use the same cable as the 350
Old 12-16-2013, 02:33 AM   #1338
jbclassix
Junk Yartist
jbclassix's Avatar
bowtieoverdrives.com 1406 to 700R4 TV cable bracket
-Jeremy
Rebuilding an NP205
Old 12-16-2013, 02:44 AM   #1339
jbclassix
Junk Yartist
jbclassix's Avatar
O'Reilly crush sleeve
EBay crush sleeve
I recommend something like this
-Jeremy
Rebuilding an NP205
Old 12-16-2013, 03:10 AM   #1340
67chevy1series
Nice! Ok ill but the one you recommend. And I need to get the right bolt for the cable it needs the one with the ball end I don't think I have that bolt.
Old 12-16-2013, 09:06 AM   #1341
shawno72
C/10 junkie
shawno72's Avatar
The bowtie overdrives tv cable is the kit I used and it was nice.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 12-16-2013, 04:53 PM   #1342
67chevy1series
Thanks For the input Shawn I noticed that it has a carb spacer is that needed?
Old 12-16-2013, 05:24 PM   #1343
67chevy1series
And as for an update I went down to see the general today and you wouldn't believe it... He actually still had 1 last blower motor relay for a 67! So I snatched that up ad also got some diff lube and posi additive, an I have the crush sleeve and shims coming on there way
Old 12-24-2013, 01:52 AM   #1344
67chevy1series
alright i finally have a computer at my disposal lol. I'm gonna take you guys wayy back to when i stopped posting pics and build up to current day. i have done a bunch of things like replacing the "s" plenum box under the dash and putting metal AC ball vents from a 65 wildcat in then the drop coils in the rear and the rear disc, the posi (currently still trying to make happen), I've installed an even better passenger fender I've installed a new hood since the last one got hit in the hit and run, I've been sanding off all the old nasty paint of the door and shooting them with a coat of primer and paint which made them look soo much better then before, I've had a flat and ended up turning the white lines inside and I've even replaced the thermostat and water pump recently, as well as getting parts together for the 7004r swap i hop you enjoy all the pics of those upgrades and installs as well as the random pics taken around town or at my college.
Old 12-24-2013, 02:00 AM   #1345
67chevy1series
more
Old 12-24-2013, 02:04 AM   #1346
67chevy1series
even sandblasted,primed and painted the vacuum pod and linkage for the passenger kick-panel vent
Old 12-24-2013, 02:09 AM   #1347
67chevy1series
took the hood off na dwas getting ready to install the hood from the 67 i found at pick' n pull ill post a picture of it
Old 12-24-2013, 02:14 AM   #1348
67chevy1series
more
Old 12-24-2013, 02:15 AM   #1349
67chevy1series
and i took it to c/10 kings c10 get together with the new hood on
Old 12-24-2013, 02:25 AM   #1350
67chevy1series
then i went to the turlock swap meet and had some fun there got some cool stuff for the garage and old school craftsman toolbox which i keep in the truck
