Double cardan joint
Hey guys, I figured you might be able to help me out. I have a 68 K10 and the double cardan on the front driveshaft is worn out and causes a pretty major vibration if the front axle is spinning, although it doesnt vibrate without the hubs locked I am using it as a winter driver for the 4 wheel drive and I need to get the joint replaced. Does anyone here know where I could buy one? I know what will be involved to do it so no worries there I just cant find where to buy them. Any help would be great as always
Austin 2005 GMC Sierra 1500 4X4 4.8l V8 (Wrecked) 2003 Chevy 1500 standard cab short bed 4x4 w/ 5.3l |
Vintage 4x4s
Re: Double cardan joint
Curious as well since I have a 67 GMC. Have you tried Rock auto?
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
![]() Join Date: Aug 2008
Driveline shops will have the parts.
You can also get parts online at places like Northern Drivetrain.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
#4 | |
If it that sloppy, you may need to have the weld-on yoke replaced. There is a pin on the end that holds a ball-like bearing. This engages the center section and keeps the two joints at equal angles. It has to be there, and they are often damaged if the joint is that loose.
You are probably going to have to find a local driveline shop to access it. Then either have it repaired or replaced as needed. You may find an internet source that could save you some money, may take longer though, and you would be replacing the entire thing instead of just the worn end.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
I was hoping to be able to just buy the whole joint assembly in one peice, then have it pressed into the driveshaft, is this possible?
#6 | |
![]() Join Date: Jul 2012
Driveshaft Specialist Inc. 8327 McCullough Avenue San Antonio TX 78216 210.342.6622 Phone 210.342.7074 Fax 1.866.455.6622 Toll Free Orders and Free Tech Advice sales.dsi@sbcglobal.net is our email address Jonathon
1960 GMC K1500 LB Fleet Side 1962 GMC K1000 LB Step Side 1988 Chevrolet C2500 |
#7 | |
Nope. It has to be "assembled" in a specific order.
#8 | |
How is the rest of the driveshaft? I had a complete new shaft with 1350 CV built for my jeep a few years ago and it was only $350ish. its been long enough that i don't remember, but it wasn't so bad for new driveline.
Overall I think it is in good shape, the yolk doesnt seem to have any play so I think the worn out DC joint is my only problem, I will look into how much it may cost to have a driveline shop repair mine for me but I need to have the four wheel drive for ice fishing this winter! so we will see what is the best option for me thanks for the help guys you always have the knowledge I need to work on my truck
http://www.drivetrainindustries.com/
these guys have always had what i needed when it came to drive train stuff. from parts to entire built drive lines. |
Got my whole drive shaft from http://www.4xshaft.com/ These are top quality and trail proof! Worth every penny as mine are 13 years old and running perfectly.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
well I just contacted Da-Burb because I went and said hi to him here the other week and while I was there I saw one that he had sitting around, but I also just found on rockauto that you can buy a whole new reman front driveshaft for 280 without a core and 230 with one, so I might go that route unless Da-Burb does have one I can buy from him
Ever since my earliest recollection of this i have known it as a constant velocity joint..... Ya learn something new every day!
![]() Great info too!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#15 |
also, I will take a video of what I am seeing and see what you guys think, I just hope thhe centering pin isnt broken, but unfortunately I wont know until I take it apart but I dont want to take it off the truck since I need the 4 wheel drive this winter if I want to go ice fishing at all (which I do). I just watched a video of someone replacing the U-joints in one and from what I am seeing, either my centering bearing is completely gone or the pin is broken. I will just have to get some prices and hope it lasts me till the end of winter, fingers crossed. if anything I might just buy a used one that I know works fine and replace the U-joints and use that, but thats equally as risky IMO.
And swamp rat, just to make sure we are talking about the same thing, here is a picture of what I am talking about so we dont get you confused on what is and isnt a CV joint, ![]()
#16 |
These stock front shafts are absolutely not worth rebuilding. I got a custom made Double Cardon shaft off ebay for $270, and it was better than stock.
Money well spent. |
#17 | |
#18 |
The joint in a driveline is a double cardan. at least the one we are talking about. they are considered near constant velocity. a CV joint is what you find in a halfshaft. like the front shaft of an IFS truck or a front wheel drive car half shaft.
1968k10blue I am sightly confused about your dilemma. you dont have to loose the 4x4 in your truck for the entire winter. if you are concerned about downtime why not just order the reman shaft and have it ready. then you are talking about an hour or so. doesn't take that long to R&R the driveline. it is a pain to deal with the spicer style output, but thats part of the fun... either way if downtime is an issue you will have to have all of the parts that may possibly be broken in order to repair the current shaft. there are plenty of options available for a complete replacement shaft. that seems to be the most expedient solution if time is of the essence. i wouldnt do a lot of driving around with the shaft being wasted anyhow. it will prematurely wear the front output of the transfer case. same goes for the front pinion. the most likely issue would be that it just chucks the shaft in pieces. |
#19 |
ryanroo
Okay, I know I have been jumping around through the thread a little, but I will try to explain it the best I can. Basically, when driving 25+MPH the truck will vibrate, but I have narrowed it down to the front driveshaft, since it vibrates the cab a good amount and it only happens when I have either the hubs locked or the transfer case in 4 wheel drive. I crawled underneath maybe a month or so ago to try to find the source of the vibration and noticed that this joint is able to be moved by hand, and it is not caused by worn out u joints, its hard to explain it any other way than that. I know what a bad U-joint looks like and thats not the problem, although it is probably due for a new set of them. since it is cristmas time I am fairly short on money and I also need this truck to make it to school in the morning if it snows since my other truck is 2wd and is horrendous in the snow, even with almost a half ton of sand in the back. my driveway is horrible when it comes to trying to get out of the house in the winter time so I need to have something to get to school/work when there is a decent bit of snow on the ground. so my main worry is if I buy all the parts to rebuild it and pull it off to find the centering pin is broken, im screwed, I will have no way to get anywhere when the white stuff flies and I have another vehicle parked in my driveway not doing anything other than getting in the way. So long story short, tight on money, need the truck with little to no downtime.
#20 | |
Vintage 4x4s
Order all the parts to rebuild the shaft and tear into when you have a full day to work on it. Watch the weather for when no snow is in the forecast. If you get in a bind, drive the 2wd. I drove a 88 chevy 2wd lwb v6 10miles to high school everyday here in MN. As long as you have decent tires and know how to drive, you can cope. Change your tires if they're that bad. A 2wd with good tires is just as good as a 4x4 with ****ty tires. Nevermind the fact you can actually stop when you want to.
#21 |
Yeah thats what I'm thinking on doing, but in the case that I need the whole driveshaft I think I would rather buy a used one to fix up myself, which was why I talked to da-burb cause that I think would be the safest route for me. and its not the roads that are the problem with my 2wd its my driveway, it is flat in front of the house then it turns and goes up hill, last year I had to be pulled out 3 times by my brother and im tired of not being able to do it I have ended up in the trees at the otherside of the driveway more times than I care to admit (plus i am kinda spoiled now after having the 4 wheel drive)
#22 | |
#23 |
That makes more sense to me. if i was in your snow boots, i would try to find a decent used shaft that will bolt in. that way you are back in business until you can get a new/rebuilt unit. are you running the stock rockwell 221 or is it a later 205 t-case? If you can pull a measurement on the length of shaft (the mounting face of the double cardan joint to the center of the u-joint on the pinion) it will help you in searching for a replacement.
rebuilding them is not that big of a deal, but if the center pin yoke is damaged it becomes a little more extensive. if you pull the shaft, you may be able to tell if it is toast by looking but you may have to pull the joint apart to see. if it is, it is a cutting and welding operation. to do it correctly you need a lathe and a dial indicator. if you arent so equipped it is better to have a shop do it. at which point you will probably be close to or over the price of a new/reman shaft. |
#24 |
thats exactly what my dilemma is, but it is a stock t221 so that makes it a little more difficult as I have heard they are harder to find parts for. a reman shaft is actually pretty inexpensive but it is just the wrong time of year to need one so I cant really afford it, and I am really trying to focus a little more on school, so I dont exactly have much time other than christmas break and spring break, but after june 6th it is home free
#25 |
I know it's clear across the country for you, but I've had good dealings with Driveshaft Superstore out of Phoenix, AZ. Good luck.
