Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 12-30-2011, 07:35 PM   #1
landarts
landarts
Ez-Wiring help with ignition hook-up
I have the mini-21 EZ-Wiring kit that I am trying to hookup. I did do several searches and found some good pointers. I am having trouble with the ignition switch hook-up. I do have a HEi distributor installed. This is for a 72 with a 350 V8.
In the kit it has the following wires marked and their colors:
  • Ign Switch power - Red with black pigtail coming off the side
  • Ign Switch start - purple
  • Ign Switch coil - pink
  • Ign Switch ACC - orange
  • Ign Switch IGN - brown
On the back of the switch it has the following post:
  • Acc
  • Sol
  • Ign
  • Bat
  • G-1
  • G-2
Im a little or maybe a lot confused on getting this right. Here is what I think from the schematic:
  • Acc gets the orange wire marked "Ign switch ACC"
  • Bat gets the red wire marked "ign switch power"
  • Ign gets the brown wire marked "Ign switch Ign"
  • Not sure on the (purple wire marked "Ign switch start" and the pink wire marked " Ign switch coil" )
If I am good on the first three, where do I put the purple and pink wires ? Also what do I do with the black pigtail coming off of the red power wire?
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
69 K20 Custom Deluxe 4x4
71 K10 Custom Deluxe
72 K20 Crew Cab Project
71 GMC Jimmy CST
70 Blazer
landarts is offline   Reply With Quote
Old 12-30-2011, 08:06 PM   #2
fixit-p
fixit-p's Avatar
Re: Ez-Wiring help with ignition hook-up
Is this what you have?
You are correct.
Ign Switch power - Red with black pigtail coming off the side Bat
Ign Switch start - purple =Sol
Ign Switch coil - pink =Ign
Ign Switch ACC - orange =Acc
Ign Switch IGN - brown =Ign
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 12-30-2011, 08:28 PM   #3
landarts
landarts
This is the type of ignition - stock in the 1972
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
70 Blazer
Old 12-30-2011, 08:45 PM   #4
fixit-p
fixit-p's Avatar
the switch you posted is correct for a 72 the diagram I posted is the generic ezwiring diagram, your connector should look like this.
The brown and green wires on the right are the G1 and G2 terminals the brown ignition wire is one on the left.
Old 05-19-2012, 01:14 AM   #5
b&a72
Active Member
b&a72's Avatar
I know this post is old but I am in the process of hooking up my ignition switch with an ez harness. Did you end up splicing the pink and the brown and connecting them to the Ign tab? And what did you do with the black wire which I am assuming is a ground?
b&a72 is offline   Reply With Quote
Old 05-29-2012, 10:23 PM   #6
tincan1966
tincan1966's Avatar
I recently installed a EZ harness for a customer(he already had the kit)
Personally, I hope I never see another one. The price is according to the quality- very disappointed- the directions are vague at best and the "instruction manual" if you want to call it that, wasn't even correct for the kit.
This was a 12 circuit with the mini fuses.
I know several on here use these and like them, but after using Painless, Ron Francis, and American Autowire i just didn't like it.
That's my 2 cents worth, I am sure the flogging will begin shortly.....
tincan1966 is offline   Reply With Quote
Old 10-13-2013, 02:59 PM   #7
Drickjennings
Drickjennings's Avatar
So you splice the pink and brown wire together?? Both going to ignition
Drickjennings is offline   Reply With Quote
Old 10-13-2013, 04:55 PM   #8
fixit-p
fixit-p's Avatar
No Pink supplies the ignition coil/hei while brown supplies power to ignition circuits like blower motor/windshield wiper. The pink stays hot while cranking while the brown drops out.
Old 11-03-2013, 03:48 PM   #9
concretekiller
So if wiring this up for a '65, where will the brown wire hook up to? I have the pink going to IGN.
concretekiller is offline   Reply With Quote
Old 11-03-2013, 05:51 PM   #10
concretekiller
Or to verify, in the picture, they are hooked up together. Is this correct for the '65?
Old 11-28-2013, 06:00 PM   #11
Steve-W
I'm in the process of installing a 12 circuit mini EZ wire harness and don't find it as EZ as the name would suggest the comments about the pigtails are very helpfull Fixit-P
Steve-W is offline   Reply With Quote
Old 12-07-2013, 11:26 AM   #12
concretekiller
Ok im having two problems. My dome light only comes on when I'm cranking my truck to start, and the starter sounds like it's trying to engage when Im turning the truck off. I have the ignition switch wired just like the picture, with pink and brown wires tied in together. With the two problems I'm having, I don't think this is correct.
Old 12-07-2013, 11:26 AM   #13
concretekiller
Dangit! Dome*
Old 12-14-2013, 10:01 AM   #14
Steve-W
I guess you have the dome hooked up the acctuator, so it only gets juice for as long as you hold the key in the starting position.
but now I think about it..perhaps you didn't ground it correctly?
Old 12-14-2013, 10:13 AM   #15
concretekiller
dome light is getting power straight from the fuse box. and then i ran the other ground side straight to a ground cable i installed on the frame (i know this is not how its supposed to be wired in the end, but im just trying to get it to light up). it lights up when trying to turn the the truck over, but once the truck is turned over and the truck is running, the light goes off. thats what makes me think i have something wired wrong with the ignition switch.
Old 12-14-2013, 01:03 PM   #16
Steve-W
Shouldn't the dome light have a constant power and the ground is through the door actuator? so that when you open your door the dome light comes on?
Old 12-14-2013, 01:10 PM   #17
concretekiller
the way ive read for it to be wired is that it has constant power from the fuse box, then the ground goes to the light switch. when you turn the light switch all the way one direction, that turns on the dome light. Like i said earlier, im not going to leave the ground of the dome light permanently wired to the frame for ground, im just trying to figure out why the dome light only wants to come on when cranking the truck.
Old 12-14-2013, 01:10 PM   #18
concretekiller
even if the ground were wired the right way, the dome light would only be getting power when the truck is cranking.
Old 12-14-2013, 05:34 PM   #19
Steve-W
Then I can only come to one conclusion and that is that it gets the power feed over your ign actuator, which only gets power while cranking over the engine.
as soon as the truck runs and the key is back in the running position the light goes off again right?
Old 12-14-2013, 05:48 PM   #20
concretekiller
Yes. That's why I'm thinking I wired something with the ignition switch wrong. That and when I turn the truck off, the starter makes a noise like it's trying to engage again. You know the sound your car makes when it's already running and you try to start it again? That's the sound my truck makes when I go to shut the truck off.
Old 12-14-2013, 06:01 PM   #21
Steve-W
this is above my paygrade..I understand the the problem, but what I would do is a try and error technique.
Get 7 feet of wire and run a direct feed from your battery to the dome light, just to try.
see if the mysterious problem with the light and the starter motor still exists.
Old 12-14-2013, 06:03 PM   #22
concretekiller
Did that already too. Light comes on with power straight from the battery and the other wire straight to ground.
Old 12-14-2013, 06:16 PM   #23
Steve-W
ofcourse it does, (you mean wen you open the door right?) but let one of them go their "original" way. so the battery feed and then leave the ground as you've got it hooked up now.
and the starter motor still did it's thingy with the direct feed to the dome light?
Old 12-14-2013, 06:21 PM   #24
concretekiller
With the battery straight to the dome light, and the ground ran to the headlight switch, it works as well.
Old 12-14-2013, 06:30 PM   #25
Steve-W
but the startermotor still wants to engage when you turn off the ignition?
