Old 12-15-2013, 10:36 AM   #1
lkt1954
71-72 Center Link
Are the center links for a 71-72 GM 1/2 ton 2wd truck a reproduction item? I have spent a couple of hours on the internet looking and cannot find any, so I presume there are not a reproduction item. Am I correct?? Also am I correct that 71-72 had different control arms that other models or will other models fit?
If used is the only source where can I find one?
Larry
lkt1954 is offline   Reply With Quote
Old 12-15-2013, 10:50 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 71-72 Center Link
As far as I know the 71-72 specific centerlink is not reproduced.
The 67-72 a-arms are the same withe the exception of the C20/C30 lowers.
They have a larger balljoint hole than the C10 version.
Just make sure you install the correct balljoints for the year of spindle that you are using.
What exactly are you doing?
Disc brake swap?
Keith
Convert to disc brakes.
Old 12-15-2013, 11:13 AM   #3
lkt1954
Keith- we are restoring a 72 back to original and the center link is MIA now. I either put it in a safe place where I would not forget where it was (yea right) or a big black dog carried it off- cause its no where to be found and now I have a nickel holding up a dollar. I have all the other original parts - just do have center link.
Old 12-15-2013, 11:20 AM   #4
HotRod C/10
HotRod C/10's Avatar
Is Dumas by Amarillo?
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 12-15-2013, 02:07 PM   #5
Mondo
Mondo's Avatar
FYI, when I got my truck the centerlink was installed upside down (yeah, it goes together). You'll know because when turning the wheel all the way the outside wheel will turn in too much. Normal driving is unaffected.
I only found out the solution by some observant guys on this site who noticed in a picture.
Mondo is offline   Reply With Quote
Old 12-15-2013, 02:08 PM   #6
tlcrz1972
tlcrz1972's Avatar
The a-arms for 71-72 1/2 tons are different than 70 and earlier. The turn stop surface is different. So you need to be careful to know the differences.
Disc brake swap?
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more.
1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE)
1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI ,
1972 Chevrolet 3/4 ton suburban future project
1972 Chevrolet 3/4 ton p/u maybe a project one day
1966 Toyota Landcruiser my playtoy
tlcrz1972 is offline   Reply With Quote
Old 12-15-2013, 04:12 PM   #7
lkt1954
Yes Dumas is 40 miles north of Amarillo.
tlcrz1972- do you have a 71-72 center link still for sale????
Old 12-15-2013, 05:58 PM   #8
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
FYI Anyone born north of the Canadian River is a Dang Yankee!!! J/K Long time Amarillo resident.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-15-2013, 06:28 PM   #9
tlcrz1972
tlcrz1972's Avatar
Yes I do, I thought I sent you a PM, but it doesn't show in my sent folder.
What's your zip code and I'll see what mailing cost will be.
thanks Brian
Old 12-15-2013, 07:10 PM   #10
lkt1954
Brian- no pm, but zip is 79029. If you will send me a pm with your paypal account address I will get you some money.
Larry
Old 12-16-2013, 05:16 PM   #11
tlcrz1972
tlcrz1972's Avatar
Larry,
I found out the mailing cost to you will be $15.00.
Pm sent with info
Brian
Larry
Old 12-16-2013, 07:16 PM   #12
tlcrz1972
tlcrz1972's Avatar
Larry,
Payment received and I'll get it going asap.
Brian
Old 12-16-2013, 08:04 PM   #13
leddzepp
Moderator
leddzepp's Avatar
In the future please keep parts sales on the parts board, thank you.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
