Old 12-15-2013, 09:11 PM   #1
DDAY
Electrical Problem, turn signal problem
Recently my turn left turn signal has started coming on at random. It fades in and out as if there is a short somewhere. If I turn the left signal on all of my lights blink in sink with the turn signal…..for example my tachometer light….license plate lights, etc. Any ideas?
DDAY is offline   Reply With Quote
Old 12-15-2013, 09:13 PM   #2
74baggedbug
Re: Electrical Problem, turn signal problem
Bulb may be burnt out or not making a good contact in the socket
74baggedbug is offline   Reply With Quote
Old 12-15-2013, 09:17 PM   #3
JOHNORO
oldschoolblazer@yahoo.com
JOHNORO's Avatar
I had a recent prob where I just traced all the wire made sure flasher was in all the way clean up the ground cables turned out I had a pinched wire shorting out.
also check that your emergency flasher button isn't pressed in.
good Luck
JOHNORO is offline   Reply With Quote
Old 12-15-2013, 09:21 PM   #4
DDAY
Check the bulbs they were good. I'm going to check the flasher and maybe the voltage regulator. Was thinking that the switch in the column for the turn signal could be crossing and causing everything to go crazy.
Old 12-15-2013, 09:22 PM   #5
DDAY
Ok thanks John, sounds light a good way to start
Old 12-15-2013, 10:09 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Sounds to me like you have a grounding problem. Are all of the stock ground straps in place and making good contact?
Here is a thread on ground straps.
http://67-72chevytrucks.com/vboard/s....php?p=4200642
LockDoc
Leon
Old 12-16-2013, 12:17 AM   #7
slikside
slikside's Avatar
LockDoc
Agreed. I recently solved a similar problem by running a separate ground from the "glowing" blinker housing to the frame. My problem crept up after having removed the front bumper for powdercoating. I had taped the blinkers (72 c-10) up on the bumper support brackets, and then reinstalled. Something in all that movement disturbed the ground. And that's all it takes in a 40+ year old harness.
Now, if I could just solve the short in my panel lights!!
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
