Old 12-19-2013, 08:10 AM   #976
67chevy1series
67chevy1series's Avatar
Re: post your 67-72 4x4
Originally Posted by landy View Post
Picked up this very original and clean '71 GMC K1500 recently. Has a 350, 4 speed, and cool old cable operated Warn winch. Body and frame are very clean.
Are these 16" inch steel rims
67chevy1series is offline   Reply With Quote
Old 12-19-2013, 11:31 AM   #977
landy
They are 16-in rims. The SPID tag indicates that the truck originally came with 16 in rims. The p.o. I bought the truck from got the truck with some aftermarket chrome rims, but was unable to find any original 16 in rims. He found some trailer rims which were, apparently, the same size as the originals, and that's what's on the truck now.
landy is offline   Reply With Quote
Old 12-20-2013, 12:20 AM   #978
Gangreen
Man, there sure are a lot of nice trucks in this thread. My truck needs sooo much work...not sure if I should be inspired or embarrassed!
Here are a couple of photos I took from our Cruzin' Grand scene which runs each Friday evening during the summer months here in Escondido. On this particular evening the local C10 club was featured and while there were several beautiful Chevy trucks in attendance, these are the 4wd trucks that I saw.
The burnt orange Jimmy was spectacular, and I dig the big green long bed! Not sure if either of these trucks belongs to a member of this message board, but I just had to share.
Happy Holidays everyone!
Gangreen is offline   Reply With Quote
Old 12-20-2013, 12:28 AM   #979
mud.man.rj
mud.man.rj's Avatar
I do like 4x4's, thanks for sharing both of them.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 12-20-2013, 12:33 AM   #980
LukeReardon
Hey that Jimmy looks familiar! I've met the guy that owns that truck he's super cool, he said he's on the forum so i wouldn't be surprised to see him around.
-A picture of my truck and his truck together
LukeReardon is offline   Reply With Quote
Old 12-20-2013, 06:05 PM   #981
Gangreen
Hey Luke, I am curious about your roll bar / cage set up. It looks as though you have a full cage in the cab which extends to the bed. I can't tell if it goes through the cab but it looks stout. That is one nice truck young man, love the green color. Hopefully I'll run into you in the SD area one day.
Old 12-21-2013, 02:51 AM   #982
LukeReardon
Hey, i appreciate it! The cage is welded to the frame and the pre-runner styled bars are welded to the cab of the truck. The cage connects to the cab but there are no drilled out holes that directly connect the cage to the bars. I'm in the process of doing a partial restoration to my truck because it threw a rod recently and i decided on cleaning up some the of body work. The Pre-runner bars are starting to crack the welds on the cab because of the lack of the frame being able to flex so i'm planning on putting a rubber separator inside of where the bolt and bar come together just to give it a little bit of wiggle room.
Old 12-21-2013, 11:25 AM   #983
joeydurango
joeydurango's Avatar
Here's our '72 shortbed 4x4. Prepping for an LS swap and some daily driver brake, suspension, and front end work, hoping to be done by the time March rolls around!
By the way, I've been seeing conflicting accounts on whether a stock-height 4x4 can be LS-swapped. Pacific Fab says that with their 4x4 crossmember and their low-height oil pan it will work great. Anyone have first-hand experience with non-lifted swaps?
joeydurango is offline   Reply With Quote
Old 12-22-2013, 05:13 PM   #984
shishka26
shishka26's Avatar
My friends K20. Its his daily driver.
shishka26 is offline   Reply With Quote
Old 12-29-2013, 01:54 PM   #985
ikester
ikester's Avatar
My 68 K10... Almost Finished
ikester is offline   Reply With Quote
Old 12-29-2013, 07:38 PM   #986
joeydurango
Nice truck ikester! Is that stock-height with ~33" tires, or does it have a little lift as well?
Old 12-29-2013, 07:58 PM   #987
ikester
ikester's Avatar
Thanks! Yes.
It's completely stock height with 33's on stock 15" rally's
Old 12-29-2013, 09:09 PM   #988
mud.man.rj
mud.man.rj's Avatar
Do you have new leaf springs, the 33's fit nice for stock height.
5.0 4spd std.
7" lift w 35's.
Old 12-29-2013, 09:59 PM   #989
ikester
ikester's Avatar
It has the original Leaf springs with new bushings all around. The tires are brand new so that might help a bit
Old 12-29-2013, 11:53 PM   #990
mud.man.rj
mud.man.rj's Avatar
It seems to sit fairly high for stock leaves to fit the 33's. Maybe had a good life without hauling too much to often. Looks like a nice project.
5.0 4spd std.
7" lift w 35's.
Old 01-03-2014, 09:00 PM   #991
possum1
Our little 68
possum1 is offline   Reply With Quote
Old 01-13-2014, 12:02 AM   #992
68chevycst
68chevycst's Avatar
Picked up a loaded 72 sierra grande today. It has a/c power steering, power brakes, tilt, am/fm and tach.
68 Chevy CST Short Bed, 70 Chevy CST Short Bed, 70 Chevy Short Bed 4X4, 72 Chevy Cheyenne Super 4X4, 72 GMC 1/2 Ton 4x4 Sierra Grande, 72 Chevy 1/2 Ton Big Block Suburban Highlander, 72 Chevy 1/2 Ton 4x4 Suburban, 72 Chevy 1/2 Ton Cheyenne Super, 72 C50 Custom, 69 Chevy CST C30 tow truck, 71 Chevy Big Block C30
68chevycst is offline   Reply With Quote
Old 01-13-2014, 12:14 AM   #993
K10 STEPSIDE
K10 STEPSIDE's Avatar
I don't even know what to call the that color but I like it, simple and down right beautiful.
_______________________________________________
A project can be finished, but a car is never done.
1967 chevy K10 step
2002 chevy Impala
Latest Project http://67-72chevytrucks.com/vboard/s...d.php?t=605308
K10 STEPSIDE is offline   Reply With Quote
Old 01-16-2014, 09:42 AM   #994
Posted
Posted's Avatar
1970 K10 Stepside 4" Lift Built 350
I have had this truck for almost 25 years now. My 1st vehicle. I have taken this baby through the ringer. She started off as my high school beater, and spent many days pounding the forest floor. I lifted it and dropped a junk yard 350 in it. Over the years I started to see how awesome this truck is and how rare a nice stepside is. I almost never see any. Everytime I take this truck out I have someone come to it. She has been on the backburner now for some time. Kids.. Well, now I am ready. She is getting a heart transplant in a few weeks to the motor shown below. Tranny is getting sent out, and I am installing a new wire harness. I will post a bunch of pics. This truck is solid in and out. All new fenders, bed, wood floor, rails, etc.. When I say new I mean I did this build 14 years ago. My father in law helped me with the body and paint. Came out okay. I will have it re-painted in the near future.
<a href="http://smg.photobucket.com/user/400exboy/media/1970_june_06_3.jpg.html" target="_blank"><img src="http://img.photobucket.com/albums/v235/400exboy/1970_june_06_3.jpg" border="0" alt=" photo 1970_june_06_3.jpg"/></a>
Posted is offline   Reply With Quote
Old 01-16-2014, 12:56 PM   #995
JayB331
JayB331's Avatar
Nice truck Posted!
'67 K10 SWB
350, SM465, NP205, 12 Bolt & Dana 44 w/ 3.08's
My Project
http://67-72chevytrucks.com/vboard/s...d.php?t=602684
JayB331 is offline   Reply With Quote
Old 01-17-2014, 01:39 AM   #996
mud.man.rj
mud.man.rj's Avatar
That is still a nice 4x4 stepper
5.0 4spd std.
7" lift w 35's.
Old 01-27-2014, 01:17 AM   #997
Desert.Chevy
Desert.Chevy's Avatar
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
Desert.Chevy is offline   Reply With Quote
Old 01-31-2014, 01:18 AM   #998
underliner6
underliner6's Avatar
My 72
[/url]
Jim
1972 K20 Cheyenne- 350/350/205
1972 K20 Cheyenne - 350/SM465/205
1971 K5 Blazer
underliner6 is offline   Reply With Quote
Old 01-31-2014, 10:12 PM   #999
mud.man.rj
mud.man.rj's Avatar
Nice setup on the Blazer, 6" lift, 36 Swampers and a 4spd, very nice all around. Plus holds lots of people and a good stereo sounds killer.
Mudman.
5.0 4spd std.
7" lift w 35's.
Old 02-01-2014, 11:38 AM   #1000
underliner6
Mudman.
Thank you! The truck has a really powerful kenwood system in it which was preinstalled when I bought it. Got to crank it to hear anything over the hum of the tires!
Jim
1971 K5 Blazer
