Closed Thread
Old 12-21-2013, 02:12 AM   #1
VA72C10
VA72C10
VA72C10's Avatar
Project part-out 22"billet rims, wilwood,accuair airride, cpp, big block parts,etc
These were intended for a project that just isn't going to happen and I need to recuperate what I can to refund deposits. Prices listed include shipping unless noted. First I'll take it...asking questions doesn't place you in line. I will do my best to get pictures posted but it may be a while. Several of the parts can be seen in the link to the project in my signature. Local pickup preferred and will make a great deal if you want a lot of these parts. Shipping will likely take several days or even a week or more once payment isn't received due to my traveling for work often. I accept paypal (ONLY if fee is paid by buyer), money orders, or cash in person. These are also advertised locally and other places online
22" Raceline Deceptives. 22x8.5 22x10 with Two Nitto 265/35/22 and two 285/35/22 2800 shipped
CPP modular 2" drop spindles (73-87 ball joints) with Wilwood calipers and 5x5 smooth 12" Rotors disc brakes 700 shipped
front CPP sway bar setup in box 140 shipped
New rear sway bar (trailing arm style) in box 140 shipped
Power brakes (new CPP complete booster/master/prop setup) for disc/drums 265 shipped
Power steering (rebuilt Big block factory setup with pump, pump cover, lines, and brackets) and new power steering gearbox 950 shipped
black restored seat belts (3 pc set for bench seat) including shoulder belts (minus boots) 600 shipped (shoulder belts not in this picture)
Tilt steering restored with Perfect stock wheel painted semi-gloss black (Sold together only) 700 shipped
69-72 cowl hood new but out of box 400 NO shipping
67-72 new aftermarket doors with one piece windows installed in driver's side and most parts (missing triangle piece and lower mount for glass- have glass and scrapers- checking on ordering these parts next week) for passenger side. Power window regulators. Asking 950 for everything NO SHIPPING
EVERYTHING BELOW IS SOLD AND SHIPPED
Accuair E-level complete air ride setup with two 5 gallon Accuair tanks with dual Viair 400c compressors, power kit, and plumbing kit new in boxes 2500 shipped SOLD
Boyd Welding aluminum tank designed for our trucks for non-efi with bed fill option new in box with silver powdercoat (looks like raw aluminum but will stay looking new) and has sending unit 400 shipped SOLD
Stock style 68 lower trim Mar-K new in box 650 shipped SOLD
ECE hidden hitch with flip up license plate 225 shipped SOLD
VA72C10 is offline
Old 12-21-2013, 02:43 AM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: Project part-out 22"billet rims, wilwood,accuair airride, cpp, big block parts,et
1969 a/c cab shaved drip rails, rear seam, firewall, and gas filler hole. Replaced outer rockers, cab mounts, and cab corners. Floor is solid. Inner rockers needed work but they put outers on. Also has one small spot above driver's side windshield 3" long that needs patched. comes with tx title. 1500 as is. NO shipping.
swb roller frame with extra holes shaved (needs final grinding on some). Primered with etching primer. Was a leaf spring frame PO converted the right way to trailing arms with grade 8 hardware, CPP trailing arm crossmember, and CPP tubular trailing arms. Converted to 73-87 front crossmember with 5 lug discs. Still has 6 lug 12 bolt rear. Has power steering gearbox installed. Roller wheels/tires barely holding air. 950 NO SHIPPING
1971 Cheyenne super A/C Cab with roof repaired (pictures in Proj#1 link) good floor, needs rockers and some work on cab corners and few small spots. Comes with the title, vin tag (PO removed for paint) and comes on the correct vin number short bed frame and correct glovebox door. Frame was stripped and then painted black by PO (poorly to be honest). Trailing arm rear, disc brake front, rally wheels w/ roller tires. Asking 1500 for cab and frame since it's a true cheyenne super swb A/C truck. Will include doors also for full asking price (need some work but not horrible) (Can add a front clip with good hood, fenders, and core support (correct for a/c with condenser still attached) for 350 more. Can include a rough, but saveable, swb steel floor bed for 250 more, and can include the BB/th400 combo with correct driveshaft and bb motor mounts (currently is installed in truck) for additional 2250. Will do 4000 as it sits with front clip, bed, and bb/th400/driveshaft/bb mounts/new rebuilt carb)
Rebuilt 468/400 combo with edelbrock intake, basic headers, and new rebuilt in box edelbrock 750 electric choke carb not installed 2250 no shipping
VA72C10 is offline
Old 12-21-2013, 07:52 AM   #3
rob32472
What all was done to the engine and tranny? Four bolt mains? What cam does it have? Factory converter? Interested pending answers. Thanks
rob32472 is offline
Old 12-21-2013, 12:41 PM   #4
VA72C10
VA72C10
VA72C10's Avatar
I will look for the details as I have them somewhere, but it is a 454 truck engine rebuilt with an rv cam and a factory converter. Basic rebuild on tranny. I will look up the engine block and head numbers and post.
VA72C10 is offline
Old 12-21-2013, 01:08 PM   #5
Elliot949
Elliot949's Avatar
I would like to see the Hitch and flip up...
Elliot949 is offline
Old 12-21-2013, 01:13 PM   #6
DaHos
DaHos's Avatar
Johnathan, I am interested in the Boyd tank and Mar-K trim, could you do $1000 shipped for both?
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline
Old 12-21-2013, 01:48 PM   #7
VA72C10
VA72C10
VA72C10's Avatar
I will need to see exactly how much shipping will cost. Business or residential address? Can you pm me the address so I can get a shipped price? thanks
VA72C10 is offline
Old 12-21-2013, 01:49 PM   #8
VA72C10
VA72C10
VA72C10's Avatar
I will get pictures tonight or tomorrow.
VA72C10 is offline
Old 12-21-2013, 01:58 PM   #9
ls1nova71
ls1nova71's Avatar
Interested in rear sway bar. What brand is it? Pics?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline
Old 12-21-2013, 02:09 PM   #10
DaHos
DaHos's Avatar
PM, sent..
1967 C10 SWB
DaHos is offline
Old 12-21-2013, 02:31 PM   #11
Elliot949
Elliot949's Avatar
Thanks...
Old 12-21-2013, 03:23 PM   #12
olrosa
olrosa's Avatar
Interested in wheels. can you PM back spacing please
olrosa is offline
Old 12-21-2013, 06:16 PM   #13
65sw
Interested in the spindles and brakes. PM sent.
65sw is offline
Old 12-21-2013, 06:48 PM   #14
jessewebb
jessewebb's Avatar
Hey Jonathan, did you ever find those kick panels with the speaker holes?
Pete
The worst I ever had was wonderful
69 SWB work in progress
97 Ranger 6in. lift on 35's
04 325i lady's ride
jessewebb is offline
Old 12-21-2013, 07:16 PM   #15
VA72C10
VA72C10
VA72C10's Avatar
Backspacing is 5.5" front on the 8" rim, and 4.25" in the rear on a 10" rim for maximum lip on the rear wheels. They are designed to just tuck in the front and rear. Rear will require the 67-69 narrower style rear with 5 lug conversion.
pm replied. Picture is above. If you need a picture of the spindle I will try to get some tomorrow but they are packed back up in the boxes cpp sent them in.
they are sitting at the front of the garage. They have no speaker holes. I haven't been to wv since we talked...mainly been in alabama for trainings and meetings...
VA72C10 is offline
Old 12-21-2013, 07:21 PM   #16
olrosa
olrosa's Avatar
That's what I need but I have the newer rearend. Any negotiations on price? Then I could narrow rear or something
olrosa is offline
Old 12-21-2013, 07:44 PM   #17
VA72C10
VA72C10
VA72C10's Avatar
My best price shipped is 2900. Picked up is 2600... I'm losing money at those prices even though I got a good deal. Originally they were 2850 for just the wheels plus 300 shipping for wheels and tires and tires were another 1000. So this is 1250 off the original price for new in box wheels and unmounted new tires with stickers...and no waiting months for them...
VA72C10 is offline
Old 12-21-2013, 07:51 PM   #18
olrosa
olrosa's Avatar
I'll be in touch
olrosa is offline
Old 12-21-2013, 07:54 PM   #19
jessewebb
jessewebb's Avatar
It's been awhile, could you PM me a price with shipping if you want to part with them and its not to much trouble, thanks pete
Pete
04 325i lady's ride
Old 12-21-2013, 10:58 PM   #20
ihssalky
Interested in complete super cheyenne with motor and trans. Would like to talk to you on the phone if possible.
ihssalky is offline
Old 12-21-2013, 11:08 PM   #21
VA72C10
VA72C10
VA72C10's Avatar
sending a pm with my phone number
VA72C10 is offline
Old 12-22-2013, 01:02 AM   #22
jtp67-72
jtp67-72's Avatar
I'll take the moldings for $650 if it gets to me..it is for swb??..jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline
Old 12-22-2013, 01:09 AM   #23
VA72C10
VA72C10
VA72C10's Avatar
Yes, they are for Swb. They are yours since you were the first to say I'll take them
VA72C10 is offline
Old 12-22-2013, 04:56 AM   #24
1blue72
how about 400 on one of those gas tanks shipped
1blue72 is offline
Old 12-22-2013, 10:42 AM   #25
jtp67-72
jtp67-72's Avatar
pm me paypal info or how u want to be paid and i will give shipping address..glad i got em but sorry to see u have to part with a lot of good parts...I need a f.I. tank with a few mods or I would have bought one of yours....jim
jtp67-72 is offline
Closed Thread
