Old 12-17-2003, 11:09 PM   #1
shuttermutt
Don't say "Oops!", Doctor
shuttermutt's Avatar
Temp gauge problem - sending unit or gauge?
The needle on the temperature gauge in my 68 moves from zero to about 1/5 of the way up when fully warmed up. Needless to say, this isn't normal. I'm just wondering which I should tackle first, the sending unit or the gauge itself. Anybody ever have this problem?
'Mutt
1968 CST LWB: R.I.P.
1967 Chevelle: TPI 454 beast
1967 C10 SWB: Claimed when Bumpster didn't put it on his list
shuttermutt is offline   Reply With Quote
Old 12-17-2003, 11:34 PM   #2
bow-tie-bandit
Live life and be happy.
bow-tie-bandit's Avatar
I would check the thermostat also.
bow-tie-bandit is offline   Reply With Quote
Old 12-17-2003, 11:38 PM   #3
dinnut
dinnut's Avatar
has it always doen this? or is this abnormal... the first part of the gauge is about 80% of the degree scale and the other 80% of the gauge is the high temperatrues you dont want to be reading at
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 12-17-2003, 11:39 PM   #4
shuttermutt
Hmmm... if there was no thermostat (or it was stuck open) then the engine would eventually reach operating temperature, but it would take longer. On the other hand, if the thermostat was stuck closed then the engine would get hotter and faster. Am I missing something? It wouldn't be the first time!
'Mutt
Old 12-17-2003, 11:40 PM   #5
shuttermutt
It's done the same thing with both engines (the 307 and the 350). I've never seen the gauge go beyond the second "big tick" and towards what I'd consider normal (roughly straight up and down).
'Mutt
Old 12-18-2003, 02:30 AM   #6
jhow66
jhow66's Avatar
First mark past cold is approx. 180* Have a direct reading gauge also and it reads 180* when stock gauge is to 1st mark. When direct gauge goes up to around 200* (in traffic) stock gauges only goes a little past the 1st mark. This is normal range for stock gauge.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 12-18-2003, 10:39 AM   #7
shuttermutt
This is what my gauge looks like when the truck is at full operating temperature. I've seen it creep just a little beyond this point, but not much. If I understand jhow66, this is approximately 180 degrees, right? If that's right, it sounds like my gauge is just fine and I just didn't know how to read it.
Huh... I coulda swore they went nearly straight up at full operating temperature. Oh well! One less part I've got to replace. Woohoo!
'Mutt
Old 12-18-2003, 10:43 AM   #8
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Mine goes straight up and down w/ a 190 degree thermostat. Sounds like you might have a sender for an idiot light and not a sender for the gauge they are different.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 12-18-2003, 10:48 AM   #9
shuttermutt
D'oh! I thought that was a little screwy. Hell, it's not like replacing the sending unit is expensive or time consuming. I'm gonna bite the bullet and make sure I've got the correct, working unit. Thanks JIMs70GMC!
'Mutt
Old 12-18-2003, 12:05 PM   #10
tom hand
CCRider
tom hand's Avatar
If your thermostat stuck open and your radiator is plenty big, it's never going to get over 150-160. First thing to do is see how hot you are running. You can get a kitchen thermometer at the grocery store for a couple of bucks. Let it sit and run with the cap off with the thermometer in the radiator...in about 20 minutes you will know what you have.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 12-18-2003, 01:48 PM   #11
grebus1
grebus1's Avatar
I have experienced both sides of this issue. My gauge used to read at second mark at normal temp. Then the sending unit crapped out. I have replaced it with 3 different senders and they all read at different part of the gauge at normal temp. The current one I ordered from Lectric Limited, who claimed it was calibrated correctly. The normal range is now straight up, but the gauge goes up almost all the way to hot before the thermostat opens. It is not a comforting sight! What gives? Does anyone sell a matched sender/gauge?
'72 Chevy Suburban Custom Deluxe 10, 402/TH400
grebus1 is offline   Reply With Quote
Old 12-18-2003, 01:54 PM   #12
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
grebus1 mine does the same thing what I think it is, is more fo a coolant flow problem near the sending unit. and the thermostat is open but it (cooler water) take's time to purge out all the hot water. or the the hot water takes awhile to get to the thermostat. Mine does it in the summer and winter, and even after replacing the thermostat.
Old 12-18-2003, 02:48 PM   #13
shuttermutt
Well, now I'm as confused as ever. Should the needle be straight up when at "normal" operating temperature? Is that the goal?
'Mutt
Old 12-18-2003, 05:26 PM   #14
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Yep! At least mine is just every now and then it goes past then comes back to the middle, usually when I first start it each day.
Old 12-18-2003, 05:36 PM   #15
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
shuttermutt, I have had several trucks over the years and all of the gauges have read what your gauge is reading now. Yours may be slightly cooler. I run 180 degree thourmustats and the needles rise just a little above the first tick. It looks to me like yours is reading normaly. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 12-18-2003, 05:45 PM   #16
shuttermutt
Thanks WES (and thanks to everyone else, too)! I think that I'm going to leave well enough alone for the time being. I may go ahead and stick a thermometer in there when I get a chance and verify that she's not running too hot.
'Mutt
Old 12-18-2003, 10:55 PM   #17
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Your reading is correct shuttermutt, that's usually where mine runs with a 180* degree thermostat, in all of my trucks.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 06-07-2007, 03:15 PM   #18
lazybra1n
lazybra1n's Avatar
Re: Temp gauge problem - sending unit or gauge?
I just got my '70 running w/ an LS1. I used a VDO sending unit on the rear of the passenger side head, via a reccomendation from another online source, and a 160* thermostat. After about 5-10 minutes it runs the guage up to the top of the normal range, and would keep going if I didnt shut it off. The top, bottom & heater hoses are hot but theres no circulation in the radiator and its cold to the touch. What is the temp range for the stock guage? Am I not letting it get warm enought to open the therm. Is it possible that the sending unit is for an idiot light and not a gauge,or that it's not running long enough to open the therm even though it's creeping uncomfortably close to the "H"? To me it seems like the water pump is not pumping- but is that possible w/ the motor running? Theres no leaks and theres only 30,000 on the motor so I'm assuming the pump is still good... Any ideas?
lazybra1n is offline   Reply With Quote
Old 06-07-2007, 05:19 PM   #19
JHART
1972 Shorty Owner
JHART's Avatar
Location: Stationed in Cali , born and raised in PHX Arizona.
Check this thread here. I posted a few picks of my temp gauge in here. If yours looks like this your good to go.
http://67-72chevytrucks.com/vboard/s...d.php?t=235946
1972 Chevy Shorty C-10- Project In Work
http://67-72chevytrucks.com/gallery/...ATT1721941.jpg- New Project
JHART is offline   Reply With Quote
