wipers
I have a 1979 k10 cheyenne,as far as I can find. The wipers only worked on high with a delay switch,when I bought her. I put in an '82 switch from bone yard and all was good. For a year. Pump quit working 5 months ago, and auto park went out 3 months later, but otherwise working.What's the problem here? My buddy's 1976 motor has 2 wire plugs, as well as my 1986, but my '79 has 3. Hunting for a new switch, I am asked if it has intermittent wipers, but I don't know. Can anyone help me get this figured out? Is it the switch or the motor? I have a junk 1991 s10. Can any of those parts work?
#2 | ||
Re: wipers
But you can not mix match delay switch & none delay motors with Delay Motor & none delay switch. Because it may not work or work right. with the Parking since you change so much. If arm are in the place but not returning Ground is bad from motor to fire wall or cam is wore out LINK: http://bowtieguy.proboards.com/threa...-washer-repair
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
