Old 12-22-2013, 07:21 AM   #1
BBrendal
Recalculating.....
BBrendal's Avatar
Where does this go?
I am putting my duct work back in my 72 Blazer with A/C and can not figure out for the life of me where this connector connects to. The high blower relay, fan speed switch and A/C switch are all connected. Anyone?
Brian - (BBrendal)
1969 Chevy Camaro Z28
1972 Chevy Blazer CST
2004 GMC Yukon (The truck that pulls the car trailer)
1972 Chevy Blazer CST #2 (Finished and sold!)
Blazer build link...
http://s1213.photobucket.com/albums/...rendal/Blazer/
BBrendal is offline   Reply With Quote
Old 12-22-2013, 07:58 AM   #2
jjzepplin
jjzepplin's Avatar
Re: Where does this go?
There is a resistor inside the heater box that looks like a spring or something. I think it may go to that.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 12-22-2013, 10:26 AM   #3
JimKshortstep4x4
The wiring connector is for the Anti-Dieseling Relay. If you don't have the solenoid on your carburetor with the connecting wiring you will not need it. The relay would normally be on the inside lower lip of the dash close to the controls.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 12-22-2013, 12:18 PM   #4
NGN
NGN's Avatar
I'm thinking also what jjzepplin has mention
NGN is offline   Reply With Quote
Old 12-22-2013, 12:32 PM   #5
Molberg
Molberg's Avatar
Yep... looks like the blower speed resistor connector.(top of air box behind the glove box area on mine
-Project Nitemare-
http://67-72chevytrucks.com/vboard/s...d.php?t=607359
Molberg is offline   Reply With Quote
Old 12-22-2013, 01:40 PM   #6
MusicMan70
MusicMan70's Avatar
A location pic from my 70
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 12-22-2013, 04:12 PM   #7
terry b
terry b's Avatar
That is clearly not the same plug as in the first photo. The wires are also different colors.
terry b is offline   Reply With Quote
Old 12-22-2013, 04:19 PM   #8
Tuff Gong
Tuff Gong's Avatar
Fan switch?
Tuff Gong is offline   Reply With Quote
Old 12-23-2013, 12:36 PM   #9
48richard
48richard's Avatar
From my 71 service manual, the connector with pink, green and orange is indeed the anti-dieseling relay. This keeps the A/C compressor clutch engaged for a few seconds after turning off the ignition, which loads the engine enough to stop it dieseling. If the A/C blower switch is on, you will also notice the blower run on for a few seconds.
1971 C10 Longbed, 350/TH350
48richard is offline   Reply With Quote
Old 01-21-2014, 07:12 PM   #10
BBrendal
Recalculating.....
BBrendal's Avatar
Jim
Thanks Jim. That was the one. No need for me to connect.
Brian - (BBrendal)
Old 01-21-2014, 07:29 PM   #11
myyamr7
myyamr7's Avatar
If you plan to hook up and use the AC, you will need that switch hooked up for the AC compressor to turn on. In the spring and fall around here, I reach under the dash and unplug mine so the compressor isn't on all the time
Mark
71 C10 Cheyenne
12 Aprilia RSV4
myyamr7 is offline   Reply With Quote
Old 01-21-2014, 07:56 PM   #12
BBrendal
Recalculating.....
BBrendal's Avatar
Hmmm! So where does that connect to? It is under my dash by my pass side but I cant find where to plug it in to.
Brian - (BBrendal)
Old 01-21-2014, 08:15 PM   #13
myyamr7
myyamr7's Avatar
On mine, the relay switch is bolted to the bottom of the dash between the glove box and the AC controls. I forgot the exact name of the switch, it looks similar to the fan relay switch.
Mark
71 C10 Cheyenne
12 Aprilia RSV4
