Old 12-22-2013, 04:08 PM   #1
Flthead
1964 long bed 5 lug upgrade ?
Put a '71 rear axle housing under my '64 long bed. Question on rear tracking bar arm. The '64 had a bracket welded to axle tube for rod/ sway bar . Is the '71 bar fit on '64 frame mount then to '71 axle ? Correct length ,angle ?
Flthead is offline   Reply With Quote
Old 12-22-2013, 04:42 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 1964 long bed 5 lug upgrade ?
Just try the '71 track bar.
The rearend needs to be centered at ride height.
If not,... there are many companies that sell adjustable versions.
Keith
Convert to disc brakes.
Old 12-23-2013, 01:15 AM   #3
Captainfab
60-66 Nut
Yes you will want to use the '71 panhard bar, but you will have to make a slight bend in it at the end that bolts to the frame bracket.
