Old 12-22-2013, 04:38 PM   #1
blazer1972
blazer1972's Avatar
1957 6 cyl manual to 350th?
how can u make a 1957 chevy truck 6 cyl 235 cu automatic? a 350th
blazer1972 is offline   Reply With Quote
Old 12-22-2013, 05:21 PM   #2
ng64
ng64's Avatar
Re: 1957 6 cyl manual to 350th?
My truck has that setup sittin in it now its not mounted to truck yet. The trans will bolt to the 6 cyl but I haven't figured out the mount setup yet because the truck is setup to use front mounts with the 6 cyl an mounts from the bell housing on a manual but with auto matic all I will have is front mount on engine an rear mount on trans really need to figure out how to use the mid mounts. On the engine block but haven't gotten that far yet only had it for two weeks
ng64 is offline   Reply With Quote
Old 12-22-2013, 06:48 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
A TH350 will not bolt directly to a 235. You need a trans adapter that bolts to the engine that will accept the trans bolt pattern.
Here is an adapter
http://stoveboltengineco.com/catalog...400&id=1396439
Then as said above you need a way to use side mounts on the engine. Some 235's have the side mount casting but if it doesn't you can use something like this to mount off the front of the engine or fab one that works.
http://www.speedwaymotors.com/1955-1...ount,6725.html
Or something like this that does use mid engine side mounts
http://www.speedwaymotors.com/Big-Bl...ount,1198.html
Old 12-22-2013, 07:06 PM   #4
ng64
ng64's Avatar
Is it possible that I have a later model 6cyl I haven't ran the numbers on it but don't remember seeing an adapter of any sort. But I've only had truck for two weeks an haven't had time to do much with it
