#1001 |
Re: intro + 66 black bagged long fleet
I am in for this, but am going to have to pass on copying you on it this time....LoL .... my plate is pretty full with my build as it is to get it done on time !!
Rock on dude, I know you are going to knock this out of the park ![]()
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
#1002 |
man now that's what im talking about!!
my project: http://67-72chevytrucks.com/vboard/s...d.php?t=456163 |
#1003 |
dash is awesome, and the front clip setting in the shop is so cool, I know you have to put it back on the truck but man it looks great sitting there, talk about a killer man cave table
my 65 fleetside build http://67-72chevytrucks.com/vboard/s...d.php?t=442370 big back glass conversion http://67-72chevytrucks.com/vboard/s...dow+conversion |
#1004 |
Registered Loser
The pancaked crossmember is definitely gonna be sweet. I can't wait to see it back together.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
#1005 | |||||||
![]() ![]() Quote:
![]() ![]() Quote:
thanx guys Quote:
![]() ![]() well i been getting some work done got the crossmember all done.. didnt really take any pics while cutting it up. ![]() ![]() test fit ![]() ![]() raised the gear box 2 inches to match ![]() i lowered the bumper 1 1/4" and i lowered the front body mounts 1/2". I am going to lower the center body mount 1/4" and adjust the bed to match the lean of the cab since my bed is adjustable. I want some rake in the stance. so the rear will be about 1 1/2" off the ground and hopefully the front bumper will lay on the ground. it will be close ![]() ![]() ![]() ![]() ![]() all painted up ![]() ![]() all i have to do now is notch the frame for the steering, install a u joint on the steering shaft and notch my control arm then i can start putting it back together
![]() bagged 66 longbed build http://67-72chevytrucks.com/vboard/s...d.php?t=449548 my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918 |
#1006 |
Rollin' Old Skool
Man, you work fast!
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
#1007 |
Awesome Fast Progress...
DON Proverbs 27:17 ![]() US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
#1008 |
![]() Join Date: Oct 2009
very nice craftsmanship. and you got a lot done on the vacation time.
i need to try a bagged truck one of these days and if i ever get to it, i thank you for the blueprint. |
#1009 |
Nice work on the pancake cross member.
You mentioned about having a slight rake when done. Are you working towards laying frame in the future? Dig the front end sittin off to the side. |
#1010 |
Man I couldn't hardly tell what you did. I really had to look......Looks good man.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
#1011 |
Your a magician with metal! Good stuff!
#1012 |
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Wow!
Super-nice work on the crossmember!...and some great pics! I am sure that it will look sweet when reassembled!
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=512904 |
#1013 | |||||
![]() ![]() ![]() ![]() ![]() Quote:
btw i would like to see you build a bagged truck!! im sure it would be top quality ![]() ![]() ![]() Quote:
![]() ![]() ![]() got some more work done today. i got it back as a roller now. all i have left is the steering shaft u joint (gotta order one) and raise the engine mounts. Im not sure if you small block guys had to do this or not but the drain plug on my oil pan was about 1/2" off the ground before i modded the crossmember. so looks like i need to raise it about 2 inches. Im sure that will open i new can of worms to make all that work. ![]() ![]() anyway here are a few pics ![]() well the bumper doesnt touch the ground but i guess its close enough ![]() not the best pics but you can get an idea of what the stance will look like ![]() ![]() ![]() more updates coming soon. ![]() ![]() ![]() ![]() ![]() ![]()
#1014 |
Needs a Big Block
Killin it man!!!
1964 Short box On dropmembers and billets 1962 Suburban family cruiser 1972 K10 |
#1015 |
Layin frame or not you Nailed it. Nailed it with a Sledge Hammer!
#1016 |
That looks awesome buddy !!
come up to the Frozen Garage, I will help you do mine... ![]()
#1017 |
![]() Join Date: Mar 2011
Looks awsome, man. Just high enough that you don't scrape off the good stuff.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. ![]() |
#1018 |
Perfect!
#1019 |
That Stance…
#1020 |
Killed it!! Your fab work continues to impress!
'58 Apache |
#1021 |
![]() Join Date: Mar 2005
You've got some killer fab skills, brother. I'm diggin' the truck!!
I actually like the fact that it's not dragging the bumper. I like my stuff slammed, but the whole "laying frame" thing doesn't look nearly as cool as a '60-'66 with the perfect rake. To me, the forward-leaning back window looks even cooler when the chassis has the right rake.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
#1022 |
I agree too. Killer work as usual.
#1023 |
thanx for all the cool comments guys!!
I got a little bit of work done today. i got most of the notching done to get the front clip to fit. my back got tired after wrestling that thing around 4 different tries ![]() ![]() bad news is my wheel tubs will need to be moved up about 3/4 inch ![]() ![]() ![]() i should have taken the advice i was given early on and just made them extra big then. this will be the third time ive had to work on those front wheel tubs ![]() ![]() ![]() ![]() ![]() the front clip is being held up about 3/4 inch off the mounts because the tires are hitting the wheel tubs. once i get it mounted down where i need it though you really wont be able to tell i dropped the bumper as much as i did ![]() ![]() ![]() after i gave up on that i got the tranny pulled off to get ready for rebuild and get the engine on a stand. here are a couple of non action shots.. lol ![]() ![]() also ive been doing alot of drawing lately so give as xmas presents to family. here are a couple little bit of glare on this pic but you get the idea ![]() ![]() going to try to get that front clip knocked out tomorrow stay tuned ![]() ![]() ![]()
#1024 |
Rollin' Old Skool
Dude your artistry skills are phenomenal! You should probably be using that as a profession, but if you're like me you'd rather keep it as a hobby. I gotta admit though, your talent outweighs mine.
#1025 |
You certainly know your way around a pencil and some paper man !!
I have to ask if there are certain things you do and don't do in your garage there. I am always amazed at how clean your shop looks and it occured to me that if I did not weld, grind, and paint in the same area as my build, then it would not be so freekin dirty all the time. Your truck just keeps looking better and better dude ![]()
