12-19-2013, 09:15 AM | #8551 |
Re: What did you do to your truck today!
That looks great! what are the specs on the wheels?[/QUOTE]
X2 really like that look! Who's the mfr?
1970 C10 Short Stepper with 71/72 front clip. |
12-19-2013, 10:28 PM | #8552 |
I finished installing the passenger side window regulator, the new window channel weather stripping (door glass felt run channel) and the fuzzies aka the scrappers or anti-rattle are installed. The junk yard/new window regulator works great! The window doesn't fall down now when I shut the door. And I didn't even break the glass putting it back in, kudos to me! Now I'm just waiting for the new arm rests to come in.
12-19-2013, 10:56 PM | #8553 |
X2 really like that look! Who's the mfr?[/QUOTE]
Circle Racing circleracing.com They are 20x10 rear and 20x8.5 fronts
My 1970 c10 (550hp LSX, 4l80e, full Ridetech) http://67-72chevytrucks.com/vboard/s...d.php?t=556610 |
12-20-2013, 01:29 AM | #8554 |
I tried (in vain) to see if I could get a fellow board member to part out his stepside bed so I could get his passenger side fender. Oh well, I ended up encouraging him to sell it all at once then prayed that he could.
It was cool talking with a fellow member and that made the call worthwhile. |
12-20-2013, 03:25 PM | #8555 | |
12-20-2013, 04:31 PM | #8556 |
12-20-2013, 07:18 PM | #8557 |
Put all new fuel lines and fuel pump...went for a cruise and wasted an hour drooling on a new tranny.......
Roll Tide! '69 C20 Longhorn 396 |
12-20-2013, 07:27 PM | #8558 |
Hey Texjake, It's snowing here and I have to work outside, so not doing it right now, But I have the window channels, (whole kit & trim everything you mentioned) and rubber Vent window gaskets also complete. Any insights, tricks to make it easier or just go for the obvious?
- Lee
68 GMC SWB Vortec 5.3 98 Chevy Blazer ZR2 94 Mazda Miata, LS2 6 speed, sold "No matter what happens, nobody gets out alive" |
12-21-2013, 12:29 AM | #8559 | |
Jason '70 C-10 short fleet 427BB TH400 (SOLD) '10 Ford F 350 '13 Ford RAPTOR 6.2 MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623 |
12-21-2013, 01:20 AM | #8560 |
today i installed the hei distributor, replaced the thermostat, and started on my 5 speed swap. i cut out the small hump and drilled holes for the high hump. i searched for a shifter, but to no luck. the shifter for the 90 nv3500 has been discontinued. so i made one myself, glad i did too because i paid a total of $0.64 for it. i had a long piece of rod laying in the garage i used.
12-21-2013, 01:46 AM | #8561 | |
12-21-2013, 08:51 AM | #8562 |
Old member
I'm having the 305 TPI motor swapped out for a 6.0 LSx motor.
Hawks 3rd gen Camaro is doing the work.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
12-21-2013, 09:05 AM | #8563 |
try to find the issue with contact. i have battery, but no contact ..... and no electricity !!
'70 C10 shortbed - 350 Edelbrock equipped - 4/1 headers - 3" flowmaster exausts '07 MUSTANG V8 convertible - CAI Spectre - Brembo's - 3" flowmaster exhausts |
12-21-2013, 02:41 PM | #8564 |
12-21-2013, 03:05 PM | #8565 |
thanks. After control, it was just a little issue with battery clip.
now it works
12-21-2013, 05:03 PM | #8566 |
I called the owner of the body/shop today that has had my truck for like 8 years and told him to get working on it, I've done this every other month for years now. I also told him that I just may have to take his butt to court if he did not get it done, or give me all my money back that I have paid him in advance and I'll find another shop to finish it. Guy offered me a deal, which I have in writing on the labor rate for helping him out $ during a hard time he was having. Hardly a deal when its taking this long. Granted though I never did put in a date of completion, and the work he is doing is the very top on notches. Money always seems to make enemies out of friends. So I guess I did at least something for my truck today!! Ha. John
12-21-2013, 05:32 PM | #8567 | |
12-21-2013, 08:24 PM | #8568 |
That is extremely long on the truck, but sounds like things will start to happen now, to bad it has to be that hard.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
12-22-2013, 07:17 PM | #8569 |
I went over to Sears and picked up my Craftsman Double Flare Kit for when I replace my entire fuel (hard) lines.
12-22-2013, 11:13 PM | #8570 |
Finally got the truck in the garage so I can begin work on it
67 C10 stepside long bed. 250 inline, 3 on the tree. |
12-23-2013, 06:38 AM | #8571 |
___________________________________ Dima 1970 Chevrolet C10 stepside http://67-72chevytrucks.com/vboard/s...d.php?t=569197 |
12-23-2013, 06:54 AM | #8572 |
Installed serpentine system, waiting on under drive pulleys to arrive today or tomorrow.
12-23-2013, 02:23 PM | #8573 |
Maybe some of you can do some video's on the metal work you do on your trucks, so the rest of us novices might learn something... Nice work......
12-23-2013, 05:28 PM | #8574 |
Blasted, Primed, Sprayed with 2 coats of 2k epoxy bedliner. Made good progress today.
12-23-2013, 08:04 PM | #8575 |
Wow ;
So much hard works ! great to look at . especially the welding & body works . I'm back from the Hospital , the neck surgery seems to have gone well , now I wait until March before being allowed to pick up my tools again .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
