Old 12-24-2013, 03:28 AM   #1
70c10stepside
Anyone running a lock right locker?
Searched and didn't find much. Considering trying one. How are the handling characteristics? Is it similar to a spool and only ratchets in parking lots or sharp turns? I don't mind the noise, I probably won't hear it over the exhaust anyways. Do they handle power fine? I have like 400-425. Going into a 4.11 12 bolt. Do you run posi fluid or regular 90 weight?
70c10stepside is offline   Reply With Quote
Old 12-24-2013, 10:39 AM   #2
Redline novdog
Redline novdog's Avatar
Re: Anyone running a lock right locker?
I have a TRACTECH brand in my 67 12 bolt. Got it free from my nephew. It's behind a tired 327. Put 80-90w straight gear lube in,works fine. I can hear it clicking around corners,but I have quiet exhaust. If you don't need a ring and pinion or rebuild it's the way to go!
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 12-24-2013, 11:17 AM   #3
turp mcspray
turp mcspray's Avatar
I have them in my blazer. You can feel the rear end of the vehicle pull from side to side when it locks and unlocks, from going on and off the throttle. I would not recommend one with a manual trans, as it puts a lot more shock to it. A lot of shock to them when they are trying to lock up, is what rounds off the corners of the teeth. I killed one of them. If it is strictly a street rig, I would use an Eaton posi. For off road, a Detroit is king.
Just use regular 80/90 lube.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 12-24-2013, 01:10 PM   #4
Stu Pidd
I had a Lock Right in a Jeep Wrangler, and was really happy with it. That Jeep took me places I never thought it could. A little clicking noise when turning sharp was nothing compared to the cacophony of noises the greasy bits of that Jeep made. I doubt any noise would be heard at all in a full-size pick-up.
Stu Pidd is offline   Reply With Quote
Old 12-24-2013, 01:54 PM   #5
Z10
Z10's Avatar
Look at PowerTrax. http://www.powertrax.com/
I've got one in my 69 Camaro and really like it. If you keep the air pressure in your rear tires equal, you'll rarely hear or feel the ratcheting.
I'll be putting one in my 72 soon.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 12-24-2013, 01:58 PM   #6
Molberg
Molberg's Avatar
X2.. these units good for up to 500HP I read. Easy to install.
-Project Nitemare-
http://67-72chevytrucks.com/vboard/s...d.php?t=607359
Molberg is offline   Reply With Quote
Old 12-24-2013, 02:59 PM   #7
Stu Pidd
This is worse with a short wheelbase. The Wrangler has about the shortest wheelbase this side if a bicycle, and the squiggles from the Lock Right were very slight. Probably no effect at all on a long wheelbase pick-up.
But then, everything in that beater Jeep was loosey-goosey, so the squiggles could have been masked somewhat by the nature of a trail beater.
Definately not a good highway cruiser!
Old 12-24-2013, 09:14 PM   #8
70c10stepside
Cool. I'll try it here soon. I don't mind the noise and all. Its a 'muscle truck' type truck. So that doesn't bother me. And its auto
