Old 12-24-2013, 09:13 AM   #1
FRANKENSTEINC10
FRANKENSTEINC10's Avatar
big block conversion ????
my small block 305 took a crap on me (go figure). I have a friend with a 454 that he is letting me get CHEAP and tranny will be TH350 for a little while. what all do I need to complete this swap on a 72? do I absolutely have to have big block frame stands? are there any specific mods that I need to do to make things easier?
FRANKENSTEINC10 is offline   Reply With Quote
Old 12-24-2013, 11:28 AM   #2
68350
68350's Avatar
Re: big block conversion ????
I believe you can use the small block motor mounts. Really the motor will drop right in. You will need to do things like exhaust, change radiator shroud, etc. Is motor short or long water pump? Are you getting all the accessory brackets with it?
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 12-24-2013, 12:34 PM   #3
merlin3
i purchased a 72 c10 with a big block after replacing the motor with another big block i could not get any headers to fit and the oil pan was hitting the front crossmember along with other issues.thanks to this forum i figured out the truck had small block frame stands after installing a set of big block stands my problems were solved.
merlin3 is offline   Reply With Quote
Old 12-24-2013, 01:13 PM   #4
FRANKENSTEINC10
I was thinking I'm gonna need the big block fram stands but they look like they cost almost as much as I'm paying for the complete engine!!
68350 I'm not sure on the water pump but yes I am getting everything.
Old 12-24-2013, 01:39 PM   #5
merlin3
i found my stands on e-bay for i think$150.00 no problems with shipping worth every penny.
Old 12-24-2013, 03:13 PM   #6
ecgate
ecgate's Avatar
I used POL's tubular engine stands and mounts to put my bbc in. I had no fitment issues at all and my headers even fit with no problems. My hei has plenty of room from the firewall. It did get real tight when I squeezed in my 4 row radiator and electric fan set up.
ecgate is offline   Reply With Quote
Old 12-24-2013, 03:43 PM   #7
Shyguy
Junior Member
Shyguy's Avatar
We used 74 big block mounts and stands when we put the '74 454 with a SM-465 transmission in my '69 frame with no problems.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 12-24-2013, 08:30 PM   #8
WIDESIDE72
WIDESIDE72's Avatar
If you arent going for correct look this is the way to go as it is cheaper and better design than the pre 72 stand design. The 72 mounts are better than the 67-71 design but are more expensive. The 67-71 cushions are expensive as well!
WIDESIDE72 is offline   Reply With Quote
Old 12-24-2013, 11:46 PM   #9
jeh
jeh's Avatar
I used POL tubular stands also, I was wondering what headers you used to work out ? Sorry, not trying to high jack the thread....
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 12-25-2013, 07:02 PM   #10
FRANKENSTEINC10
ok so I found a set of the POL mounts on eBay for $120. if I'm using all factory components do I absolutely have to have the big block mounts? I already have a 4 row radiator and I plan on electric fans. could I mount the fans in front of the radiator outside of the engine bay to leave more room for the motor.
Old 12-25-2013, 07:21 PM   #11
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
[QUOTE=I already have a 4 row radiator and I plan on electric fans. could I mount the fans in front of the radiator outside of the engine bay to leave more room for the motor.[/QUOTE]
Absolutely not. Fans are designed to draw, not push. I'm not sure why so many want the electric fans. If it's a stock or mildly warmed up 454, the factory fan and clutch with the factory shroud has stood the test of time for years.
Now mind you I have large dual electric fans and large aluminum rad, but I'm pushing 1100+ HP. This setup actually clears an F1R Procharger with a 10 rib belt as well as air conditioning and power steering and everything else... But just barely.
Keep it as simple as possible, GM makes some good stuff, no need to go to aftermarket if your system doesn't require it.
Tom Vogel is offline   Reply With Quote
Old 12-25-2013, 08:39 PM   #12
FRANKENSTEINC10
I would like to keep it all stock because the engine only has 36,000 miles on it! I just want to make sure it will fit without much modification. I could probably move the radiator back about 2.5 inches to help with clearance but my main concern is the frame mounts. I've been told and read that it will work either way.
Old 12-25-2013, 10:02 PM   #13
hugger6933
Of the three trucks I am building two are gonna be with a 454. One already has a big block it is a 68 model the other is a 70 and I am gonna use the later 73 and later style mounts as I am not as concerned with being period correct, even to the point of the thought has come to me to change out the 68's for the later style ones as well. Jim
hugger6933 is offline   Reply With Quote
Old 12-25-2013, 10:10 PM   #14
Terry Crist
You can get electric fans that are pullers or pushers and you can get some that you can set up either way.
I would rather not use pusher fans just because I would not want something blocking the passageway to the radiator. Seems a bit redundant to me.
Terry Crist is offline   Reply With Quote
Old 12-25-2013, 10:11 PM   #15
FRANKENSTEINC10
hugger6933 I'm not concerned about being period correct either. but what are the benefits of the big block mounts? what would the drawbacks be to not using them?
Old 12-25-2013, 10:38 PM   #16
WIDESIDE72
WIDESIDE72's Avatar
You will have exhaust manifold/ header clearance issues if you try to use sbc towers with a bbc. Do a search on this forum for "big block swap" and other similar terms. This swap has been done and discussed here numerous times.
Old 12-26-2013, 12:00 AM   #17
hugger6933
Yeah, if you try to use headers or exhaust manifolds that are close to the right ones for our trucks with the small block mounts, your might as well save time and just go to the shop now and hit your hand with the ball-peen hammer. It will save time and probably be less painful.it just will not fit properly. Jim
Old 12-26-2013, 05:50 PM   #18
FRANKENSTEINC10
ok so I've seen that I can use mounts out of a 73-87! is there a special big block in those years also or did gm pull their heads out of their asses after 72 and start making sense?? if so I will just go to the pick n pull and rip some out of a square body.
Old 12-26-2013, 10:28 PM   #19
ecgate
ecgate's Avatar
I used chevelle headers. If you use these headers they are a great fit and don't hang as low as the truck headers but installing them can be a pain in the a$$. I had to hook my engine picker up and raise the motor 6 or so inches to get them in. I think the pass. side will go in with out raising the engine but the drivers side gave me a bit of a headache and required me to pick the engine up a little bit to get them in. Hope this helps.
Old 12-26-2013, 10:37 PM   #20
jeh
jeh's Avatar
Thanks, I will defiantly try to find a set of them. My headers hang below the frame
Jason
'10 Ford F 350
'13 Ford RAPTOR 6.2
Old 12-27-2013, 02:16 AM   #21
69SCSS
69SCSS's Avatar
Just grab a pair of Big block stands for 67-71 trucks and use small block motor mounts. You'll have to just get a couple of bolts and large washers, and you can bolt the engine right up. They'll also clear the headers. It'll put it in the right place, won't need to mess with the radiator location, just make sure you have the right fan shroud for a big block, the correct shifter rod, and the right Power steering pump for a big block (they're different). You can use the stock BBC fan also. Hope that helps.
There's a guy on here that has a full writeup about using the SBC mounts on the BBC stands, TX Firefighter is his name on the board, here's the link: http://67-72chevytrucks.com/vboard/s...d.php?t=122645
My 68 SWB
Al Silveira Music
<- My daughter loves this guy 8-)
69SCSS is offline   Reply With Quote
Old 12-27-2013, 08:26 AM   #22
MARKDTN
What is the 454 out of? Is it a later model out of a pickup? Tall deck out of a school bus? Rebuilt out of a Chevelle? A 454 can be 200hp or 450hp and run on 87 or have to have race fuel. If you sit down and count the cost of a BB swap with exhaust and the stands and radiator and all the other stuff that goes with it, you are well on your way to an LS swap. The TH350 will live for a while, but eventually you will need a bigger transmission which means a new driveshaft, etc. I would consider to just pony up for either 1) a different small block that will just bolt right in or 2) an LS swap and have mileage and power-especially if the 454 is nothing special. My .02
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 12-30-2013, 06:53 AM   #23
FRANKENSTEINC10
thanks guy for all the info. I managed to find a guy parting out an 84 and talked him in to pulling the frame mounts of for me. cone to find out he was less than 6 minutes from my buddy's house where I was picking up the motor so I didn't have to go out of my way. $40 later and they were mine. I also found out the stock manifolds weren't in good enough shape so after I picked up the motor I hit Craig's list for some big block headers. after scrolling through 400+ post I found a set of 70 chevelle headers for $50. the guy has so many part that he through in a set of moroso valve covers and a huge air cleaner for free!!! all in all a pretty good weekend. I wish I were furth in to the project but this time raind I'm going to take my time and do it right.
Old 01-03-2014, 03:26 PM   #24
FRANKENSTEINC10
dropped it in for a test fit and to mark the location of the mounts!
Old 01-03-2014, 03:28 PM   #25
FRANKENSTEINC10
I know you guys love pics so I will post some more when I get home!
