Old 12-26-2013, 11:20 PM   #1
mgchevyparts
mgchevyparts's Avatar
pros/cons of shock extenders
Installing flip kit, what are the pros/cons of using shock extenders. The way I see the extenders keep you from having to buy new shocks, any down side to this other then maybe just looks?
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 12-27-2013, 10:46 AM   #2
Jonboy
Slots go on anything!
Re: pros/cons of shock extenders
They do hang down some, but that is a minor annoyance to me. I have used them on the couple trucks that I have had that are lowered.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 12-28-2013, 12:49 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
The "pros"are they allow your shock to function properly. The "cons" are you will hate your ride if you dont.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-28-2013, 12:50 AM   #4
KrazyRay
KrazyRay's Avatar
Shock extenders are a must with the axle flip.
KrazyRay is offline   Reply With Quote
Old 12-28-2013, 12:51 AM   #5
mgchevyparts
I probably didn't word it right. You can get shorter shocks and not use the extenders so I was wondering if either method is better then the other and why.
Old 12-28-2013, 12:53 AM   #6
mgchevyparts
I was removing the bump stop brackets, I hate removing factory rivets
So I decided to try my 120v Hobart plasma cutter, worked like a charm. Took about 15-20mins to blow the heads off then pry the bracket loose. Just don't use this method if you want to save the bracket.
Old 12-28-2013, 01:31 AM   #7
joe231
joe231's Avatar
stock front shocks will fit after flipping the axle, on the pick ups anyway....
not sure on the blazers and burbs.
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 12-28-2013, 11:11 AM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Yes you can use shorter shocks, but your ride will be better with long shocks and extenders.
Articles-
"Refining Sierra"
