Heads and Cam For 350
I have a new 350 GM crate motor and am going to add some Vortec heads (will order them from JEGS or Summit) to it as well as a cam. I want a cam that will add horsepower, not really worried about the lope, I figure I get a good cam it will have a good lope. But what cam do I get? The truck is just used for crusin around town in the warmer months and sets in the garage during the winter months, but I love going fast so want to have some horse power available.
350 V8 5.7L Edelbrock Performer Intake Edelbrock 1406 Carb Hooker Comp Ceramic Long Tube Headers 2.5" Dual Exhaust exits just before rear tires 700r4 Tranny I do not know what the gears are Any other info needed on helping pick out the best cam I can get. |
Re: Heads and Cam For 350
Cam, gears, and torque converter stall speed should be matched to work with each other. Personally, I like higher stall speeds, so I can get away with a pretty radical cam. Some people hate hate hate high stalls and would never be able to live with what I deem acceptable and vice versa.
You're also in danger of limiting yourself with the Vortec heads for cam choices... if you're talking about stock Vortec heads. Stock Vortec heads don't flow very well at higher lift, so you'd want to stay with something in the .480-.500 area and something with a split pattern with more exhaust duration. Now if you're talking the GMPP large port Vortec castings, then that changes your cam again...
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube |
Here is a nice little flat tappet camshaft for your Vortec headed 350.
Smooth idle and torquey. http://www.summitracing.com/parts/is...make/chevrolet |
![]() Join Date: Jul 2010
get a cam that's close or matches tha one in tha 330 horse crate motor...that's a strong motor...
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
Pick your favourite cam grinder and call them up. They are best suited for this kind of thing, and the most experience and knowledge on the subject (we hope - I have met ~some~ salesmen, however,....).
If you really want lumpy - I like Lunati; they want to get to the grocery store first. I have a Howard's Cam 110961-08 in my '77 (video of it running) and I like it so far, but I have only driven it enough to break the engine in.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
Ok so the heads I would like to purchase are the bow tie large port http://www.jegs.com/i/Chevrolet-Perf...34446/10002/-1 Like I said I love horse power and going fast, so eventually I want to get as much out of the 350 as possible. I can't afford to do it all at once, but assumed heads and cam would be a good start, I don't want to be 6 months down line going " man I should have bought a bigger cam etc" then end up buying another one. So that said, I believe these are going to be a good choice of heads going forward; so what cam options would be best suited? Again wanting to make the 350
Is this a daily driver? 350 cubes, heavy truck, most likely 2.73/3.08 axle ratio.
Think small port Bowties(great heads BTW) and think smaller than you think on the camshaft selection. |
No this is not a daily driver, it's a garage queen. Its just used for cruises around town once in a while and other than that its parked in the garage. Forgot to mention in the prior posts its 2wd SB which I am guessing most of you already knew. Is my truck really considered heavy? Doesn't seem to heavy...... why go for small port vs the large port? I needed educated
The small port Bowtie Vortecs have 185cc intake runners, plenty for 350 cubes below 6500.
The large port Bowties are better suited for 383-400 cubes with some RPM. Your truck should weigh somewhere around 4000. |
OK that's why I love this forum the knowledge; so now best can option to maximize the HP of the 350 matched with the bowtie small port heads.....
I have a done a few Vortec head, GM Hot cam motors. It's a great combo of torque/hp. nice sounding idle. Chevy High Performance built the same combo a few years ago.
http://www.chevyhiperformance.com/te...e_roller_cams/
Eric Evans Queen City Shop Truck http://67-72chevytrucks.com/vboard/s...34#post6139834 66 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543110 |
