Old 12-28-2013, 12:00 PM   #1
ALedbetter1
350 to 454 swap
I've got a '84 K20 4wd 4 speed with a 350 in it. I want to swap it out for a 454. Has anyone done this before? What do I need to do the conversion? My 454 is missing a alternator and upper bracket and the power steering set up. Will any of the 350 parts fit, with the exception of the alternator bracket which I know wont fit. Any help is greatly appreciated.
ALedbetter1 is offline   Reply With Quote
Old 12-28-2013, 12:45 PM   #2
mrolds88
Re: 350 to 454 swap
Not much will interchange. Starter, alternator, power steering pump may. You will also need a manual trans flywheel. 350's and 454's were balanced differently.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 12-28-2013, 08:46 PM   #3
jlk
Re: 350 to 454 swap
You may need an add-a-leaf in the front spring pack to help hold up all that extra weight. I did it on an '82 GMC 3/4 ton 2WD but it's been years ago. The power steering pump should work with the correct brackets of course. You'll need new exhaust head pipes too. Good time to replace the motor mounts too. I had to buy an extension wire harness for the alternator because it's farther across the big block. It's a common part at the local auto parts house.
jlk is offline   Reply With Quote
