#8601 |
Re: What did you do to your truck today!
i installed my used cpp rear coilovers
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies 2004 2500HD utility bed aka Brutus |
#8602 |
i finally re-installed the defrost hoses and vents! picked up the 2 1/2 diameter flexible kind from autozone. so much nicer on those cold mornings
'69 c10 longbed granny 4spd 292 "Behemoth" ![]() '67 c10 longbed granny 4spd 292 "Burzum" some pictures of my work in progresshttp://photobucket.com/zaeea R.I.P. Corey "Flattus Maximus" Smoot 11/3/11 You will be missed. Your sound lives on. |
#8603 |
Well guys, I appreciate all your suggestions, and I will further to try tomorrow. In another forum I found a lot information and found another way to mount the alternator. They suggest I use a different mounting brackets you can mount at mid point on the passenger side with a special lower bracket that mounts to the back of the alternator that mount off the water pump. They use these brackets with engines that don't have the drilled holes in the heads. I just might do that instead. I figured out why the bolt broke in the first place. the PO put a different engine in the truck and sort of slapped it together. It didn't have the bottom bracket that goes off the water pump, so more or less the alternator was just hanging off the top bracket and created tension and that top bolt snapped, so I will get the bottom bracket and will probably get that med point bracket and be done with it.
I will post my results either way in case anyone else gets in the same situation. Thanks again one and all.. Great forum....... |
#8604 |
Got my tow hooks and skid plate on..
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold ![]() 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
#8605 |
![]() Join Date: May 2013
Tried to figure out why I'm not getting enough spark to fire up. New cap, rotor, points, plugs, wires, condenser, battery, battery cables, and coil. Rebuilt carb and plenty of gas.
Pulled the coil wire off the dizzy to check for spark, very weak and intermittent. Checked connections from starter to coil. Yellow to positive from starter, black from neg. to dizzy. TDC in #1 position. What am I missing here?
Rich J. 1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD ![]() 2002 Chevy Tahoe 4X4 5.3L SOLD 2015 Chevy Silverado Crew 4X4 5.3L |
#8606 |
Maybe point gap is incorrect, to wide or closed too much, .018-.022 is usual.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
#8607 | |
Fun Stuff
![]() Join Date: Jan 2010
Did this problem arise before or after you changed the parts? If it was after, go back over the things you did again, you should be able to fix it.
Jay 68 C10(project) 88 Honda Accord(DD) 93 Chevy Astro EXT 2wd Last edited by jayman68; 12-31-2013 at 12:53 AM. |
#8608 |
I struggled putting a new oil pan and gasket on my 69 C10 longbed and went through major trials getting the motor mount bolts back in. Got everything back in and torqued the bolts to spec, added oil and started it and.............. leak city from pan?!! I love working on my truck but ive got side work going on and dont have the time right now to pull pan off again. So my baby is in the shop today and hopefully shes ready to come back to my driveway after work tomorrow
#8609 |
I got the metal work finished on the drivers side. New kick panel, floor patch panel, outer rocker, door pillar post patch panel, cab corner and new door. Then I patched a hole in the left front fender were the p/o drilled a hole to mount a antenna. Then I hung the front fender on to make sure it fits the new door. I thought it turned out ok for the first timer mechanic doing body work.
#8610 |
![]() power seats in.. just need the brackets welded they are bolted in for now.. |
#8611 |
I finished installing 4" CPP drop springs, shock relocator kit, adjustable track bar and 1.5" lowering blocks on the rear of my '71 GMC S./Stepside. It had 3" drop springs and some kinda old air shocks that with no air in 'em. I'd bought the CPP lowering stuff for my '72 Jimmy and never installed it. Truck has 255/60's on truck ralley's all the way around. I drove it a little after I finished and thought the ride was harsh. It started to rain & I put away. Hopefully after the new stuff works some it'll soften up some. It has 2.5" drop spindles and stock springs on the front. Next project is new front shocks and maybe 2" drop springs on the front.
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
#8612 |
I reinstalled my freshly painted sun visors & the A/C vents. For some reason the PO had a vanity mirror on the driver side visor & from the indentions it left on the visor it looks as if it had been there for ages. I don't think they will ever go away. I thought most of those vanity mirrors were used on the passenger side so little Mrs Molley could put her makeup on....lol Honey you look great!..lol I am still waiting on my rear view mirror to arrive. UPS will say it's delayed due to the weather & on-line Christmas shoppers...lol
#8613 |
Christmas presents going in
1970 Chevy swb, project UGHH! ![]() 1987 Grand National http://s168.photobucket.com/albums/u.../1970%20Chevy/ |
#8614 | |
#8615 |
Got my old intake off, and found a list of things I need to do before I bolt my better intake down.
So, I got some parts together from my store... Pull the old stock manifold off... Find some not-so-nice looking water ports... Now I need to do a coolant, and oil flush. Decided that I would wait to bolt down the new parts until after I get that crud cleaned out, but hell, I may as well mock everything up, see how it will look. It looks nice. Cant wait to get it running.
Grunt: 1971 C20 Custom Camper. Runs/Drives/Kinda stops. 350Ci, TH350. 4.10:1 D60. Eight Lug LWB is more better. Hell no its not fast! Donkey: 93 Nissan D21, the farm truck. My 1/2 ton SWB. The Indomitable Datsun. 1st BN 3rd MAR. '00-'04 ![]() |
#8616 |
That water jacket looks nasty , a reminder why " lifetime coolant " is a myth .
The good thing is : *you* can clean it out good as new better your own self than any shop . Use Citric Acid powder or the neat Prestone cleaner in the yellow plastic jug ~ first flush with plain water until no loose shale or red water comes out then add the cleaner and sufficient distilled water , run it to work and back a few times , not just 30 minutes idling . I've had a few that required a week of daily commuting for over 30 minutes each way before the red crud stopped showing up in the water . Expect the mix to turn dead black and get thick ~ this is what you want , drain , flush a few times until you can drive it 30 minutes and the water remains 100 % clear , then you can add your 60/40 % coolant mix . The amount of time you invest here, directly correlates to how good the job turns out ~ you're cleaning up the DPO's mess , nothing you did . Was the inside of the valley that clean or did you clean out black oily sludge ? . Looks like you're well on the way to having a strong runner .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#8617 |
Thank you for the extra info, I was just going to back flush and fill with some brushing included.
The valley was already that clean, which surprised me. I managed to get some coolant in the oil when I pulled the old intake, so I will be draining the oil, and cleaning as much crud as I can out of those passages before I bolt on the new intake with new gaskets.
#8618 | |
#8619 |
Replaced rear wheel cylinders on my 72 GMC.
#8620 |
I put the little stainless steel vent shades over the windows on my GMC. I bought 'em at Summit in Atlanta on my way to N. Ga. for Christmas.
#8621 |
I GOT MY TITLE TODAY!!!!!!! im so floppin excited. i was flippin excited, but i got tired so now im just floppin.... its been a long, strange trip, but shes finally mine, all mine, no if's, and's, or butt's, except mine and my ole lady's on that somewhat worn bench seat. the feeling is indescribable. comparable perhaps to ones " first time ". all the blood sweat and tears i put in to her over the years on pretty much just a "maybe"... now ive gotten the sorely needed validation, and best of all, a huge green light to seriously invest the time and dead presidents into her that she deserves. i dont own a lot of stuff, or even nice stuff at that. i have the clothes on my back and some in a closet... all pretty much from high school 15+ yrs ago. the computer i type this with, a bow and some arrows to feed myself with and now my truck... not to mention the job i use to fund it all. thats pretty much me in a nutshell. what ive got, ive had to work my ass off for and it has made me appreciate it all the more. still looking to make friends with someone with the metal fabbing skills needed to get some new rockers and cab supports welded in tho. have grill and beer brewing equipment / knowledge : will travel!
i installed an led dome light from autozone. only has 3 leds and it isnt much brighter than the regular festoon. meh, for 5 bucks its ok. also pulled off a tire that has a slow leak and cleaned up the bead sealing surface on the rim a little bit then had the tire remounted and balanced. i noticed they added more weights than what was previously on the tire. makes me wonder how accurate some of these places really are. my next plans are to mount two LT's in the rear, maybe they are a little taller when installed than the bald passenger rated goodyear's that are on there. its miller time! i raise mine to every single one of you, keeping these awesome machines around, and im so ecxited that i get to be a part of it all!
#8622 |
I kicked off the New Year yesterday by driving my truck to get kerosene for the garage heaters and Advance parts run.
Today I ordered my LEDs for the dash, heater, and dome light from superbrightleds.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
#8623 |
Ripped out the nasty floor padding and rubber mats out of the 72' found a few holes in the drivers side, but the passenger side is perfect. Much better than I expected. Only one side to replace, not too shabby.
-Sterling GIG EM' AGGIES!!!! WHOOOOOOP!!!!! "Whether you think you can or think you can't, you're Right." -Henry Ford 1972 chevy lwb 1934 ford p/u |
#8624 |
Don't know why that's sideways...
#8625 |
![]() Join Date: Jan 2012
Matt Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=672655 "Father thank you for the gathering of friends, Father we give thanks for all the choices we've made because that's what makes us who we are, let us forever cherish the loved ones we've lost along the way and most of all THANK YOU FOR FAST CARS!" |
