Old 12-29-2013, 07:42 PM   #51
Hart_Rod
Hart_Rod's Avatar
Re: Porterbuilt extreme Dropmember and 2 piece drive shaft question???
I posted some pictures on my instagram...http://instagram.com/hart_rod
Hart_Rod is offline   Reply With Quote
Old 12-29-2013, 08:02 PM   #52
lolife99
67-72 parts collector,…
lolife99's Avatar
For those that don't go there,...
Keith
Convert to disc brakes.
Old 12-29-2013, 08:06 PM   #53
Hart_Rod
Hart_Rod's Avatar
Thanks Keith! Forgot to mention, I'm going to have to build a 2.875 spacer for the carrier bearing.
Old 12-29-2013, 08:12 PM   #54
lolife99
lolife99's Avatar
Will that allow the front driveshaft to clear the trailing arm crossmember hoop?
I see the newest version of the trailing arm crossmember has the carrier bearing pad on the front side of the crossmember.
Keith
Old 12-29-2013, 09:15 PM   #55
Hart_Rod
Hart_Rod's Avatar
Yeah, I have about 3/16th clearance with a 3.5" driveshaft. Do you have pictures of the new setup?
Old 12-29-2013, 09:30 PM   #56
lolife99
lolife99's Avatar
I will let Nate post his pics.
It's basically like your newest trans crossmember.
A bolt-in frame bracket on each side,... with a flush mount trailing arm crossmember.
The side brackets have a series of holes that allow you to move the trailing arm crossmember forward (stepside trucks) or rearward (60-66 trucks),... etc.
This still may be in the design process.
This eliminate the issue with tube diameter crossing through the trailing arm crossmember.
Only the small slip yoke will be through the crossmember.
But the front driveshaft will be very short on swb trucks.
I just recieved an extreme Dropmember rear set-up.
My crossmember is like the standard trailing arm crossmember (frame ends),... but the carrier bearing mount is on the front side.
Keith
Old 12-29-2013, 11:49 PM   #57
Bennett68C10
Bennett68C10's Avatar
Yeah we figured out today that we need to add another 1/2" to the 2" spacer I started with. If you haven't set the cab on yet just be careful how tall your spacer is. With a 3" spacer the carrier bearing hits the cab floor. Your going to be really close to the floor.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 12-30-2013, 12:07 AM   #58
David121582
If that is a 700r4 can you provide the specs for your driveshaft so that I can provide my driveshaft guy a starting point, thanks
David121582 is offline   Reply With Quote
Old 12-30-2013, 12:14 AM   #59
David121582
Sorry just saw its a 4l60 not sure if the specs would help on a 700r4 build.
Old 12-30-2013, 03:06 AM   #60
Oldtruckfanatic
Truck junkie
Oldtruckfanatic's Avatar
They're the same thing. The dimensions will be the same.
Oldtruckfanatic is offline   Reply With Quote
Old 12-30-2013, 07:19 AM   #61
lolife99
lolife99's Avatar
Just remember that there are MANY variables in these driveshaft set ups.
Truck year.
Dropmember version: mild, touring, or extreme.
Engine and mounts
Trans
Yoke length
Style of carrier bearing.
Carrier bearing spacer height.
Driveshaft diameter
Trans crossmember height in frame
Trailing arm or 4-link rear suspension
Rearend type: 12- bolt, 9-inch etc.
Taking someone else's dimensions to build your driveshaft could prove a very costly mistake.
Keith
Old 12-30-2013, 09:01 AM   #62
Bennett68C10
Very well said Keith, if you take my setup and Robs setup they are completely different and subsequently have yielded completely different results. He is running an LS/4L60E combo with Extreme Dropmembers front and rear, I'm running a 454/TH400 combo with touring dropmember front and extreme rear. We both have to run different height bearing spacers for the driveline to work correctly.
Keith
66 Suburban
IG: bennett68c10
Old 12-30-2013, 10:45 AM   #63
David121582
Im just looking at it for a starting point for measurements and would never go out and build one off of someone elses measurements. I am running a very similar setup all around and figured his might be close to what I need.
Old 12-30-2013, 01:38 PM   #64
Rochlow
I spoke with Mitch Henderson the other day about what he uses for driveshafts. He told me that they start with a 2wd longbed or 3/4 ton long bed 2-piece driveshaft. They have the front shaft cut down to fit, have new u-joints and carrier bearing installed. then have it balanced.
I'm in the process of purchasing a used drive shaft and I'm going to pursue this method.
///Relaxed Atmosphere
Rochlow is offline   Reply With Quote
Old 12-30-2013, 01:46 PM   #65
PBFAB.COM
PBFAB.COM's Avatar
Hey guys! I am working on an in depth write up that helps explain the best way to set-up the two-piece drive-shaft. Unfortunately, there isn't a "one size fits all" with all the different variables.... but the theory behind it is all the same.
Until I finish the write up, feel free to send us an email with any questions regarding the set-up process and I will be happy to reply and even set up a phone call if necessary.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 12-30-2013, 01:49 PM   #66
Rochlow
I found this online also. Not sure if it will help?
http://www.driveshaftspecialist.com/...oke%202009.JPG
Old 12-30-2013, 01:49 PM   #67
Bennett68C10
This is exactly what I did with mine
Keith
66 Suburban
IG: bennett68c10
Old 12-31-2013, 04:39 PM   #68
cook2199
great info HART_ROD, started following you on instagram as well. I am just getting started on my 68 swb.
cook2199 is offline   Reply With Quote
Old 12-31-2013, 06:26 PM   #69
PBFAB.COM
PBFAB.COM's Avatar
That is the measurement chart or diagram that most drive-shaft shops will send or ask to be filled out.
Here's something to keep in mind.... take a carrier bearing center to rear pinion at ride height, full dump, and full lift. Give these measurements to the driveline shop so they don't build it too long or too short (learned this the hard way).
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-01-2014, 12:34 AM   #70
jmedero
jmedero's Avatar
Will the CPP drive shaft with slip yolk help out with the different measurements in full dump, ride height and all the way up?
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 01-01-2014, 12:55 AM   #71
PBFAB.COM
PBFAB.COM's Avatar
A slip yolk is necessary for sure, regardless of wether its a CPP brand or other. The measurements at full dump and full lift are to help get the shaft built just right as it will plunge and grow through all the travel.
When having a shaft built by any shop it's best to provide them with all the info possible to avoid any questions, concerns, or finger pointing after the fact.
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-01-2014, 01:13 AM   #72
jmedero
jmedero's Avatar
Cool makes sense. Thanks man. Happy new year Nate.
