Old 12-29-2013, 10:58 PM   #1
rs74
rs74's Avatar
Dually drum question.
I had to take one of the inner duals off and take in tomorrow for a bad valve stem. Figured I would go ahead and pull the drums off to see what the brakes, hardware and wheel cylinders look like. Do I have to unbolt the axle and pull it out to get the drums off. If so is it as easy to just unbolt the outer bolts and slide the axle out or do I have to pull the rear dif cover. Am I on the right track here?
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 12-30-2013, 12:25 AM   #2
Rubble
Re: Dually drum question.
Your on the right track,remove the bolts& pull the axle.You don't have to pull diff cover unless you want to see how things look inside.Once the axle is out,you need a special socket to remove the wheel bearing nuts.once they are off,the drum should slide right off.You might have to back the brakes off a bit to get the drum to slide over the shoes.I would recommend changing wheel seals too,good chance of them leaking if you don't replace them.
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 12-30-2013, 12:28 AM   #3
rs74
rs74's Avatar
Thanks Rubble. What is the special socket? I assume I should be able to buy one from the local parts store.
Roy
1987 R10 shortie
Old 12-30-2013, 01:28 AM   #4
Rubble
Ya,any auto parts store should have one.It has four little tabs on the inside of a piece of tubing approx 1.5" dia.I would take a picture,but in from shop now & too lazy to go back out eh!!
Old 12-30-2013, 02:23 AM   #5
Alex V.
Alex V.'s Avatar
FYI, make sure you clean the axle flange and hub mating surfaces and seal them well upon re-assembly - don't want any gear lube leaks.
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 12-30-2013, 07:22 AM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I bought my special socket from O Reilly Auto Parts. They had it right there on the tool aisle for about 10 bucks.
Also, if you're just doing one side, only jack that side of the rearend up. That way the gear oil will run downhill and away from the hub you're removing. Keeps it from dripping out all over the place.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
