Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 01-01-2014, 01:59 AM   #1
Mthumphrey
Mthumphrey's Avatar
Cleaning Primer
Hey guys. I have a new to me black primer 66 C10 long stepper with a 250. I really don't foresee painting any time soon and just want to drive it; however, the primer has started to cloud. Any ideas on a way to clean it and then a finish to put on it to maintain it? Is there a wax or something that you would recommend? I have considered using this http://www.tcpglobal.com/Customshop/ksflatz.aspx, but I want to just run primer for now until I can afford to do it right.
Mthumphrey is offline   Reply With Quote
Old 01-01-2014, 02:09 AM   #2
BadaSs_Cal
BadaSs_Cal's Avatar
Re: Cleaning Primer
Is it an epoxy primer?
I am no paint pro of any sort, but primer by definition is meant for stuff to stick to it and porous. . Paint, dirt, water, grime etc...
I have used the hot rod flats from TCP.. its cheap and easy to lay... BUT
Semi glosses and Satin paints DO tend to be a little harder to get an even coat with. The first time I did it I kept getting blotchiness. I figured out it was from going over the same spot more than the rest of the panel and hence getting more gloss on it... at $100. It will buy you a few years and what's to lose?
66 Gmc 1 ton. Long Step 351e V6
69 1/2 CHEVROLET (now a shortbed) LONGBED!:devil
61 Shortbed Fleetside 1/2 ton.. in progress
Next a 50-53!
MY BUILD THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=447926
BadaSs_Cal is offline   Reply With Quote
Old 01-01-2014, 03:16 AM   #3
Captainfab
60-66 Nut
Re: Cleaning Primer
What I have done in the past is wash (wet sand) the truck with a gray Scotchbrite pad.
Old 01-01-2014, 10:34 AM   #4
chevyrestoguy
chevyrestoguy's Avatar
Re: Cleaning Primer
I see this stuff advertised, and I always wondered how good it works. I like the idea.
http://www.ratwax.net/
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 01-01-2014, 12:57 PM   #5
TJ's Chevy
TJ's Chevy's Avatar
Re: Cleaning Primer
Sweet looking truck! Like the 250!
Old 01-01-2014, 01:29 PM   #6
waspp
waspp's Avatar
Re: Cleaning Primer
My experience as well. I found a lot of variation in sheen with heavier coats and multiple coats. I painted mine a piece at a time and discovered the subtle variations when I started bolting things together. I think the scuff pad would be a way to even things out however primer is different, even epoxy. Sun does the most damage and that chalky hazing is difficult to remove but I have buffed it out of epoxy paint with compound. It was a motorcycle tank and it was a pain and obviously the flat look became satin-semi gloss.
waspp is offline   Reply With Quote
Old 01-01-2014, 01:35 PM   #7
LVPhotos
LVPhotos's Avatar
Re: Cleaning Primer
I use glass cleaner, Invisaglass, aresole can. Mine is epoxy primer on "ready to paint" parts and regular Rustoleum stuff on the parts that have not gotten final prep. I did the grey pad as well but now with final prep I backed off the sanding pads.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 01-01-2014, 06:57 PM   #8
Mthumphrey
Mthumphrey's Avatar
Re: Cleaning Primer
Thanks guys for the input! I am not sure if it is epoxy or not as it came this way. I will try the options and see what works. Thanks again!
Old 01-04-2014, 05:34 PM   #9
sixTsix
Re: Cleaning Primer
good looking truck either way. looks real straight.
sixTsix is offline   Reply With Quote
