Old 01-01-2014, 04:54 PM   #1
J48chevy
J48chevy's Avatar
48 Chevy rear end swap?
I may have missed it somewhere on here but wanting to swap the rear on my 1948 Chevy 3/4 truck. Looking at a 1992 camaro rear. Will this work? I see many suggest the Ford Explorer but wondered on this year. Just in the initial stages of turning this truck into something of a daily driver. Want reliability and for highway driving. Thanks.
J48chevy is offline   Reply With Quote
Old 01-01-2014, 05:58 PM   #2
Highsider
Highsider's Avatar
Re: 48 Chevy rear end swap?
Maybe this, from the search above, will help getting started:
http://67-72chevytrucks.com/vboard/s....php?p=3900121
Jimi J from I-Oh-Way
'57 Panel 3105
Met this deer...
Roof Swap on my Panel
Jim's Bread Truck
Highsider is offline   Reply With Quote
Old 01-01-2014, 06:35 PM   #3
J48chevy
J48chevy's Avatar
Thanks.
Old 01-02-2014, 12:44 AM   #4
mr48chev
mr48chev's Avatar
The 92 axles are according to my info 62 inches flange to flange but are also said to be a bit on the weak side if you intend to run serious horsepower and tires. If you have a mild engine and aren't wont to drive it hard you should be ok but if you have 400 or so hp and like to hit the loud pedal it might be a bit weak.
My ongoing truck projects:
Old 01-02-2014, 11:51 AM   #5
J48chevy
J48chevy's Avatar
Yes looking for a good cruiser rear end. I have a fresh, stock 305 that will be going in this truck, so not too much power, but enough for me.
Old 01-07-2014, 07:24 PM   #6
Firstgenfan
I put an explorer rear in my truck. It's not on the road yet so I can't say how it works out. I installed a TCI rear leaf kit at the same time. The rear almost dropped right in but the centering pins were about 1/4" off and the pinion was shooting 8* up. i'm going to pull it back out and cut the old perches off and weld new ones on. The rear I got was out of an '02 explorer with trac-loc posi and 3.73 rear gears and disk brakes. I grabbed it from a local u-pull-it that had about 15 more there for $100 bucks. The bolt pattern is different than chevy too. I had to get wheel adapters for mine because the rims I have had too much backspacing so I just ordered the adapter for the lugs too. Good luck on your build.
Firstgenfan is offline   Reply With Quote
Old 01-07-2014, 11:04 PM   #7
Root2812
Root2812's Avatar
The TCI kit is for 3inch axle tubes and the ford 8.8 has 3.25 inch tubes. I'd love to see more of what you did to make it fit. Also pictures of it in would be great.
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 01-07-2014, 11:12 PM   #8
Firstgenfan
I'll take pictures tomorrow morning when I get home from work but the lower spring plates are good for the 3.25" axle tube. I added a 2" lowering block so I have to get new u bolt made but for mock up purposes I used 3/8" all thread.
Old 01-08-2014, 05:42 PM   #9
Firstgenfan
For some reason I can't post pictures now. The kit worked out great though and is all quality materials.
Old 01-10-2014, 03:38 AM   #10
Firstgenfan
Here ya go my photobucket account needed updated.
Old 01-11-2014, 09:25 AM   #11
lazypineapple
lazypineapple's Avatar
Is that all-tread you are using ?
lazypineapple is offline   Reply With Quote
Old 01-11-2014, 10:25 AM   #12
Firstgenfan
Lol yea it's only for mock up. I need to get new ones bent since I'm using the lowering blocks.
