Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 01-04-2014, 04:01 AM   #1
1968k10blue
1968k10blue's Avatar
Starter ???s
My current starter does not always engage and so I am thinking on getting a new one, definately not a spendy one. but I have heard that alot of people have starter issues when getting new ones so I guess my question is, what sould I look for when buying a new one?
the engine in my truck is a 350 from a 73 c10
Austin
2005 GMC Sierra 1500 4X4 4.8l V8 (Wrecked)
2003 Chevy 1500 standard cab short bed 4x4 w/ 5.3l
1968k10blue is offline   Reply With Quote
Old 01-04-2014, 08:58 AM   #2
watash
Re: Starter ???s
this may not be your problem, hot start, but go to "mad electrical" and look at their kit for installing a Ford starter relay.
watash is offline   Reply With Quote
Old 01-04-2014, 10:24 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Starter ???s
What do you mean by "it does not engage" ?
Do you mean it goes zingggg instead of actually turning the engine over ?
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-04-2014, 10:58 AM   #4
MalibuVLX
Re: Starter ???s
I'm in the middle of starter issues with a 406ci motor and can feel your pain. By not engaging??? Your solenoid may be bad. Easy fix. Did it work at one time and now works sometimes? If it did engage and work properly and has since started giving you issues, I would try to fix the existing first. If you have a good starter/alt rebuilder around, maybe take it off and take it to them to diagnose. Just a few suggestions. Sometimes new starters give more issues than the orig. Shimming, alignment etc.
MalibuVLX is offline   Reply With Quote
Old 01-04-2014, 05:45 PM   #5
1968k10blue
Re: Starter ???s
What it does is it TURNS but doesnt ENGAGE the flywheel, I know that the solenoid has issues when hot and I am thinking of doing a relocation kit, but this is a different story. either way I am getting a new starter and need to know what I need to watch out for when getting a new starter. I have heard of alot of ground bendixs lately through the thread
Austin
Old 01-04-2014, 06:22 PM   #6
Tx Firefighter
Re: Starter ???s
Inexpensive fix.
Saves buying a complete starter for an isolated issue.
Old 01-04-2014, 06:55 PM   #7
bigmac73
bigmac73's Avatar
Re: Starter ???s
I would get your old one rebuilt, it will be cheaper than buying a new one
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 01-04-2014, 07:55 PM   #8
1968k10blue
Re: Starter ???s
how much do they cost to rebuild? and where would I get it rebuilt? my local oreillys sells reman units for $40
Austin
Old 01-04-2014, 07:55 PM   #9
1968k10blue
Re: Starter ???s
Originally Posted by Tx Firefighter View Post
Inexpensive fix.
what is it?
Austin
Old 01-04-2014, 08:01 PM   #10
mac808
mac808's Avatar
Re: Starter ???s
Had the same issue a while back. Teeth were all rounded and slightly chipped. I bought a new one from DB Electrical based on suggestions made by many on this forum and haven't had a issue yet. Affordable and high quality.
Here's a link:
http://www.dbelectrical.com/p-10547-...t-sdr0059.aspx
mac808 is offline   Reply With Quote
Old 01-04-2014, 08:11 PM   #11
1968k10blue
Re: Starter ???s
does that price include a core? and do you have any heat soak problems with the solenoid?
Austin
Old 01-04-2014, 08:28 PM   #12
Evan's 1965
Evan's 1965's Avatar
Re: Starter ???s
I doubt you could get it rebuilt any cheaper than getting a new one. Can get a new/rebuilt one at about any parts store for $35-40. You could buy a starter heat shield if the new one acts up.
Evan's 1965 is offline   Reply With Quote
Old 01-05-2014, 10:23 AM   #13
MalibuVLX
Re: Starter ???s
I had a heat soak issue with a stock starter on my dad's 83 square body. Went to a hi torque mini and it has done excellent. Barely hit the key and she cranks right up. If you are set on getting a new starter, I would recommend that direction. that's just my $.02.
Old 01-05-2014, 12:41 PM   #14
Wrenchbender Ret
Re: Starter ???s
People having issues with new starters is from these $40 starters some are recommending. If you have any mechanical ability you can tear it down yourself & fix it. The drive like Tex shows is the culprit. If rest of the starter looks good clean it up, grease the bushings & replace that drive & you will be better off then one of the "remans" with cheap parts in them.
Wrenchbender Ret is offline   Reply With Quote
Old 01-05-2014, 12:59 PM   #15
Tx Firefighter
Re: Starter ???s
Thank you. Well said.
Old 01-06-2014, 03:14 AM   #16
1968k10blue
Re: Starter ???s
So what do I need to look for to make the starter engage more consistently?
Austin
Old 01-14-2014, 07:13 PM   #17
88Ironduke
Re: Starter ???s
Ensure the new starter is properly shimmed for you application. Nothing worse than tearing up a flywheel and/or new starter.
Good clean cables and terminal ends. I stress the terminal ends as a cause for poor starter performance. While the cables look good on the outside but can have severe corrosion wicking/working its way inside the shielding. What looks serviceable may be less than ideal and cause issues. Good solid power and ground sources mean a starter does not have to work as hard to get job done every time done.
Molded/sealed cables are the way to go if not a purist. Stay away from the temporary terminals unless stranded on the road.
88Ironduke
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!!
My Build Thread: Project 72' Green
http://67-72chevytrucks.com/vboard/s...d.php?t=587932
88Ironduke is offline   Reply With Quote
Old 01-14-2014, 10:33 PM   #18
1968k10blue
Re: Starter ???s
The problem isn't a connection (although it definitely wouldn't hurt) but the starter will spin but will not engage the flywheel. And this problem is actually worse when it is given more current
Austin
Old 01-16-2014, 01:23 PM   #19
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Starter ???s
hows your teeth
mine was worn out ,tried a few starters beore i saw how bad it was
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 01-16-2014, 01:26 PM   #20
1968k10blue
Re: Starter ???s
I haven't checked but once again, it just doesn't make the starter drive pop out to engage the flywheel, it just goes WRRRRRRRRRRRR a few times then it will engage and start right on cue
Austin
Old 01-18-2014, 07:08 PM   #21
starterman99
starterman99's Avatar
Re: Starter ???s
Sounds like the drive gear is slippingas mentioned above.It is a one way clutch meaning it slips in clockwise rotation and should lockup in counter clockwise rotation.when you turn the gear with your fingers clockwise you should feel resistance as it turns. If it spins easily with very little force like one finger it is worn out and should be replaced.the drive or bendix gear should be about 10 bucks.Not real hard to replace just pay attention to how the retainer and thrust washer are assembled when you take apart.
1950 5 window
starterman99 is offline   Reply With Quote
Old 01-18-2014, 07:30 PM   #22
Rocmonkey
Re: Starter ???s
Off topic a bit but... I saw this on an RV thread a few years ago and tried it on my 64 CJ-5 w/350 Chev. I could never get it to work. Thanks for the link tip cuz it sounds a lot better than GMs (although the RV site did say GM had used the Ford type solenoid setup in the past).
Rocmonkey is offline   Reply With Quote
Old 01-21-2014, 10:50 AM   #23
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Starter ???s
may want to check shaft the gear slids out on,seen some rust up
John
