Old 01-05-2014, 02:13 AM   #1
sighlurr
______________
sighlurr's Avatar
1967 C10 Big Window & Porterbuilt Equipped Frame
I've decided to sell my 1967 Chevrolet C10 pickup truck project. I have a 1967 big window cab that needs a little work on the floors due to rust. I have the patch panels and will include those. Dash is uncut and interior is very original. No speaker holes cut in the doors. Registration is paid through February 2014 and it is titled a 1967 LWB. Big window '67's are pretty tough to find, that's why I was willing to look past the rust issues. All four corners are solid. New white CA plates (sorry).
Also have a 1970 GMC leaf spring SWB OEM frame. This has been professionally blasted and all of the factory holes have been MIG welded shaved. Frame was sprayed in ZeroRust gray, and all Porterbuilt suspension parts are in ZeroRust black.
Front -
- Rear notch bolt in: Bolted in and MIG welded in place. This is the larger step notch that will require you to cut the bedfloor for the bridge, or raise the floor @5.5"
- Bridge assembly for coilovers
- 4 link
- Carrier bearing x-member
- Lower shock bar
- Panhard bar
- Rear frame crossmember
- Rear RideTech coilovers. Springs have been powdercoated gold flake.
Front -
- Dropmember Touring main crossmember assembly
- Upper hats Touring coilover
- Inner truss Touring
- Motor mounts 63-72 Dropmember Touring
- Transmission cross member
- 63-87 tubular control arms coilover
- Ball joints
- CPP power rack & pinion
- Power steering hose kit - mid 90's power steering pump
- RideTech front coilovers. Springs have been powdercoated gold flake
- Sway bar DMTouring
- Steering linkage kit - 3 joints
Porterbuilt parts alone were over $6K.
Comes with a '70 12 bolt rearend - the wider of the two (the later one, but still 6 lug). Trailing arm perches have been removed. I don't think it's a posi and couldn't tell you what rearend gears it has. 4 link brackets will need to be installed. Drum brakes have been removed, I was planning on running discs.
This isn't a rolling project, but it pretty close to be done.
$5500 for everything listed above. No trades please.
sighlurr is offline   Reply With Quote
Old 01-05-2014, 02:14 AM   #2
sighlurr
______________
sighlurr's Avatar
Re: 1967 C10 Big Window & Porterbuilt Equipped Frame
A couple more pics -
(925) 979.8161 - call or text.
Old 01-13-2014, 02:17 PM   #3
sighlurr
______________
sighlurr's Avatar
Open to selling just the chassis and 12 bolt for $5000. I wrapped the control arms and rear section of the frame this weekend in cardboard to transport. It's not rolling, but much easier to move now. Happy to work with any shipping company for guys outside of CA. After creating a move profile on uship.com, I've seen some pretty affordable rates after 24 hours of bids by various shipping companies...
Old 01-20-2014, 10:04 PM   #4
sighlurr
______________
sighlurr's Avatar
Frame is sold. I still have the '67 big window cab - $750.
Old 01-21-2014, 07:19 AM   #5
asizemore
asizemore's Avatar
Do you have more pictures/info of the rust on the cab? Is the cab originally from California?
asizemore is offline   Reply With Quote
Old 01-29-2014, 05:24 PM   #6
sighlurr
______________
sighlurr's Avatar
Sorry, no other pictures but it's always been in CA since it was new in '67.
Old 08-11-2014, 01:44 AM   #7
sighlurr
______________
sighlurr's Avatar
Sold
