Old 01-05-2014, 08:59 PM   #1
bwood
bwood's Avatar
98 GMC door hinges
I replaced the pin/bushings in the driver's door this evening. There is still some slop and I found that it is in the bottom hinge where the pin goes through the bottom of the
cab side hinge. The hole is a little oblong towards the cab. Does anyone know of a kit that would allow the hole to be drilled and a bushing installed (or something similar)?
I'm considering building the back of the hole up and cleaning it up with a burr, but I was curious if there was a aftermarket solution. This is for my 98 in my signature, thanks.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
Old 01-06-2014, 12:25 AM   #2
Cape Codder
Cape Codder's Avatar
Re: 98 GMC door hinges
If you have a way to weld it another option is to weld a heavy washer in the correct position to hold the bushing.
Cape Codder is offline   Reply With Quote
bushing, hinge, pin
