![]() Join Date: Oct 2010
Hi all, happy new year. Have a question for you guys. Have a 1972 Cheyenne Super SWB. Did this truck ever come with a front sway bar? If not could I put one on it from a another 67-72 C10?
Thanks Eddie ![]() ![]() |
Re: Front Sway Bar?
Yes, you can. It will bolt right up. All the holes are there.
1971 C/10 - Orange & White 2009 GMC 1500 - Lowered 3/4 22' KMC Slides |
![]() Join Date: Jul 2012
Re: Front Sway Bar?
you can pull one off of any square body Chevy truck too. Mine on my 71swb came off of an 81 3/4 ton
My 71 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=548438 |
![]() ![]() Join Date: Sep 2008
Re: Front Sway Bar?
All the holes are there, but you will have to cut one rivet on each side at the cross member and frame connection. Not a big deal. An air chisel will take the head right off the rivet, and you can punch it out.
![]() Join Date: Nov 2003
Re: Front Sway Bar?
Find a BIG one off a square body one ton. The last one I put on I bought the brackets at the Chevy dealership, that was only a couple years ago so they may still stock the brackets .
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Moderator
![]() Join Date: Jul 2006
Re: Front Sway Bar?
Yes they did and they are a MUST, your ride will improve drastically. As mentioned, they were common in later trucks. I saw 3 in the junkyard last week.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
70+ ( Old Skool Club )
Re: Front Sway Bar?
Check the FAQ section on the site. Member Texas Firefighter has an in depth-faq that I used when I installed my front sway bar. This is one of the best inexpensive upgrades you can do to your truck.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Re: Front Sway Bar?
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
Re: Front Sway Bar?
X2... mine was an 1 1/8" off an early 80's 2wd 1 ton. I had to fab the frame brackets..
2WD Jimmy
![]() Join Date: Mar 2005
Re: Front Sway Bar?
You can also buy a swaybar kit from ECE or Hotchkis or Porterbuilt etc.
![]() Join Date: Jan 2012
Re: Front Sway Bar?
My $.02. bought a used bar 1 1/8. I bought the rest from local Chevy dealership. The rubber grommets # 3927019,the brackets for the grommets #334671,and the frame brackets #6271375,You need two frame brackets. This worked great on my 67 lwb.
It builds on my intelligence when I make a mistake, Boy am I building on it! '67 C-10,'70 Nova SS ![]() |
#12 | |
Re: Front Sway Bar?
very nice! just found something to keep me busy the next coupla days ![]()
'69 c10 longbed granny 4spd 292 "Behemoth" ![]() '67 c10 longbed granny 4spd 292 "Burzum" some pictures of my work in progresshttp://photobucket.com/zaeea R.I.P. Corey "Flattus Maximus" Smoot 11/3/11 You will be missed. Your sound lives on. |
![]() Join Date: Feb 2013
Re: Front Sway Bar?
Use grade 8 hardware to bolt everything up. it is easy and makes a big difference in handling... I am now planning to do a rear bar as well.
Re: Front Sway Bar?
not trying to hijack this thread, but are you gonna use that blade style or regular type rear sway?
#15 |
Re: Front Sway Bar?
