Old 12-20-2003, 01:05 AM   #1
griesel72
griesel72's Avatar
clutch install questions
Anybody have any good advice,or step by step for installing a clutch in a 4 speed 4X4 behind a small block 400
Thanks for anything you can tell me (I have never done it before)
David
1969 K10 Custom 10
1997 Z71
2006 Volkswagen Jetta TDI
2006 King Ranch
1980 Wife
griesel72 is offline   Reply With Quote
Old 12-20-2003, 01:28 AM   #2
71swb4x4
71swb4x4's Avatar
I haven't done one for a while so I will just give you a few pointers that I remember. You will have a plastic allignment tool that will fit into the clutch disc and the bearing that's on the end of the crankshaft, that will keep the disc in place while you tighten the pressure plate. Be sure to get the flywheel resurfaced, and don't get anything on the face of the flywheel, the clutch disc, or the pressure plate. It really is pretty easy. Hopefully someone else can fill in all of the holes.
For me putting the tranny back in was a 2 person job - but I did it with me and a jack - but it was a pain in the ass. Get another person to help you with that if you can.
Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 12-20-2003, 01:50 AM   #3
fast14
fast14's Avatar
Make sure when you are putting the tranny back in you put it in gear so you can turn the output shaft so you can get the input shaft lined up with the clutch.
Just a little crazy
1970 chevy full size half ton, soon to be one ton running gear, 350 turbo, 205 case, 355c.i.
fast14 is offline   Reply With Quote
Old 12-20-2003, 01:51 AM   #4
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
If I was doin a clutch on my truck I'd be more inclined to just pull the motor. I hate wrestling with a big tranny while on my back the whole time.
Cat Fuzz is offline   Reply With Quote
Old 12-20-2003, 02:10 AM   #5
Blue_71
Bloo
Blue_71's Avatar
make sure you have a weighted flywheel made for the 400 which is externally balanced... also im not sure if you can do this or not, most 400s came with autos and therefore they didnt drill the clutch Z-bar bracket holes on the block
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 12-20-2003, 02:45 AM   #6
Rooster's 67
Rooster's 67's Avatar
eat your wheaties!!!
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 12-20-2003, 03:36 AM   #7
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
I bought some long bolts the same thread that hold the tranny onto the bellhousing - cut the heads off & round them on a grinder. I threaded them in & used them as a guide for the tranny & as a place to rest & turn the inputshaft to align the splines. Change as many seals as you can when you pull the tranny - its easy when its out. Put on a new clutchfork boot, get the flywheel ground, use lots of brake cleaner spray, grease the splines on the driveshaft upon re-installation & IF your rearmain seal is leaking on your motor change it now - its easier with no flywheel in the way.
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
