Old 01-06-2014, 10:57 PM   #1
Pete1stark@yahoo.com
307 Chevy motor
I read an article about the 307 engine being a 350 cast block with a small (3.875) bore & the only reason the 307 got a bad rap was because the cam was mad from very soft material causing the cam to flatten really quick which made it sluggish. This giving it a bad rap. Am I wrong.
Pete1stark@yahoo.com is offline   Reply With Quote
Old 01-07-2014, 12:13 AM   #2
geezer#99
geezer#99's Avatar
Re: 307 Chevy motor
Cam was no different than any other small block. They where sluggish due to the smaller bore and longer stroke. Made for low end torque and not high rpm.
Old 01-07-2014, 12:15 AM   #3
mud.man.rj
mud.man.rj's Avatar
Re: 307 Chevy motor
307 will work for a truck for torque and daily driving but if spending cubic inchs rule, so at least spend on a 350, same parts more torque yet and power. Mileage is about the same.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 01-07-2014, 12:15 AM   #4
BigRed76
BigRed76's Avatar
Re: 307 Chevy motor
I believe the 307's had smaller valves than the 350's too.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 01-07-2014, 12:42 AM   #5
ho70
ho70's Avatar
Re: 307 Chevy motor
305'S had the cam problem in the 80's. 307's were dogs, they worked hard, were loyal but nothing fancy
ho70 is offline   Reply With Quote
Old 01-07-2014, 12:43 AM   #6
Re: 307 Chevy motor
307s git a bad rap from the bigger is better mentality They are actually a longer lasting motor than a 350.
Old 01-07-2014, 01:03 AM   #7
Terry Crist
Re: 307 Chevy motor
I had a 307 in a 1968 Chevelle with a 2sp auto behind it. It ran great and after I put headers on it the gas mileage went up by around 5%-10%.
I sold it to my sister. She ran it into the ground and thru a rod thru the side of the block. My brother and brother-in-law talked her into letting them put in a 327. It was a total gut-less POS after that (so she said) and sold the car. She said that it just was not the same anymore. She liked the low end torque of that 307.
Terry Crist is offline   Reply With Quote
Old 01-07-2014, 01:07 AM   #8
Fatherof3
Fatherof3's Avatar
Re: 307 Chevy motor
My 71 has one. I've only driven it home from buying it but if the compression is good I'm going to fix some oil leaks and run it so I can spend my time and money on other parts of the truck. With the 3.08 rear gear I'm hoping for some road trip worthy mileage.
65 C20 292 4spd 4:56 Eaton HO52
Fatherof3 is offline   Reply With Quote
Old 01-07-2014, 01:52 AM   #9
airdale94
airdale94's Avatar
Re: 307 Chevy motor
I've heard that to. Also that you could bore it out 4.00 (350).
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 01-07-2014, 08:26 AM   #10
MARKDTN
Re: 307 Chevy motor
A 307 has the same stroke as a 327 so if you have a good 350 block (4" bore) you can make a 327.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 01-07-2014, 09:07 AM   #11
Unionwelder
Unionwelder's Avatar
Re: 307 Chevy motor
Not to Steal your thread but i Have a question for these guys too.I've heard I can use the 307 piston in my i6 250 is that true?
-Sterling
GIG EM' AGGIES!!!! WHOOOOOOP!!!!!
"Whether you think you can or think you can't, you're
Right." -Henry Ford
1972 chevy lwb
1934 ford p/u
Unionwelder is offline   Reply With Quote
Old 01-07-2014, 10:52 AM   #12
ho70
ho70's Avatar
Re: 307 Chevy motor
307 uses the 327 crank with a 3.25 stroke
307 has a 3.875 bore
350 has a 4.00 bore is
230 has same stroke and bore as 307, so pistons should fit-check part numbers
250 bore is 3.915 not 4.00
you could bore out the 307 to 4.00 but need thick cylinder walls (different 307's have diiferent thickness) so you need a sonic check
Old 01-07-2014, 12:45 PM   #13
mmiddle
mmiddle's Avatar
Re: 307 Chevy motor
A 307 was a 283 bore with a 327 crank. 3.875 bore & 3.25 stroke. This made for more torque than the 283, but less potential than the 327. Overall these were a base-line engines and have never been popular for performance because of the odd CID. And chances are you cannot bore these blocks out to a 4.00 bore of a 302/327/350. You are better off finding a 4" bore block and starting from there.
Conversly, a 302 is a little monster. Lower torque, but very high RPM and very quick revving potential making it perfect for the short track in a lighter car
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 01-07-2014, 03:27 PM   #14
BigRed76
BigRed76's Avatar
Re: 307 Chevy motor
I've always wondered how a 307 with a 3.75" stroke crank would behave compared to a 383.
Zach
Old 01-07-2014, 05:05 PM   #15
Wrenchbender Ret
Re: 307 Chevy motor
I have heard that also many times. It raises the comp. ratio.
Wrenchbender Ret is offline   Reply With Quote
Old 01-07-2014, 07:15 PM   #16
gvw5400
gvw5400's Avatar
Re: 307 Chevy motor
No real magic with a 307, As stated above it's a 283 with a 327 crank. Think of it as a factory 283 "stroker" but with mild compression and a tame cam. Personally I think I would rather own a 307 then a 305. You could wake it up with a stouter cam, but I don't know if higher comp pistons are available. Build what you like, but a 350 is always a great cheap way to engine happiness. All the best, Dirk
gvw5400 is offline   Reply With Quote
Old 01-07-2014, 08:20 PM   #17
sean1969c10
sean1969c10's Avatar
Re: 307 Chevy motor
I think the 307 is a great engine as long as you have reasonable expectation. It's never going to make the power or torque a 350 would, but the bore and stroke sizes are pretty good when you compare it to other engines of similar size. I wouldn't want to try to bore one to 4.00", you would never be able to hone the cylinders straight because there wouldn't be enough cylinder wall left to keep the bore stable. And if you did manage to get the engine together, it would collapse a cylinder very quickly.
Sean
"If your gonna be dumb, you gotta be tough"
1960 Chevy Impala Sedan - my 25 year search is over!!
1969 C-10 longbed - Nice day DD
1970 Chevy Nova - Street and Strip Project
2002 Acura MDX my DD
2007 Honda Odssey - My Wife's "Mommy Van"
sean1969c10 is offline   Reply With Quote
Old 01-07-2014, 09:57 PM   #18
Re: 307 Chevy motor
Why bore a 307 to 4.00 when there are so many 350 blocks out there already? I built a 307 with an RV cam,1.94 valve 64cc heads,stock 4 bbl manifold,Holley 450cfm(can't recall,but performance not economaster),HEI,and double roller timing chain in a '71 K/20 work truck with 4.57s and 37/14.50 mud tires. That thing hauled and moved out like a 350 and got 13 mpg
Old 01-08-2014, 09:56 AM   #19
Re: 307 Chevy motor
My 307 was a crate motor purchased for a T bucket. It got 25 miles put on it when the guy decided to go Rat Motor. Since I've got a good complete motor I just wanted to perform it as much as I could without messing with the block and rotating assembly. I read that sometime after 68 Chevy was using the 350 block casting and boring the cylinders at 3.88, substantially increasing the wall thickness. And another article, head change, cam change with a Performer intake, & 650 edelbrock netted 315 horses @5800 rpm & 330 ft/lbs at 3800 rpm. That's kinda what I'm looking for. Thanks for all the input!
Old 01-08-2014, 04:58 PM   #20
Eddie H.
Eddie H.'s Avatar
Re: 307 Chevy motor
The 307 was a little work horse of an engine. My 69 GMC came from the factory with a 307 and TH400. It spent most of it's working life on a farm, pulling overloaded trailers through muddy fields, hauling hay, and earning it's keep as a work truck. When I got it, I pulled the tired little 307 out and replaced it with a SB 406. The 307 was still running pretty good even after 20 years of hard service, and would have probably gone much farther, but I just wanted more power.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 01-08-2014, 05:36 PM   #21
RANDY COX
RANDY COX's Avatar
Re: 307 Chevy motor
My 72 Blazer 4x4 4"lift and 33's had a 307 with 2 barrel, and that thing would absolutely get it..Of coure I wasn't out there dogging it, But it was a daily driver... was very happy with it...My truck 64 has a 307 in it with mild cam and 4 barrel still under construction so It's not on road so don't know how it's gonna do yet..
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 01-08-2014, 05:39 PM   #22
69GMCLonghorn
69GMCLonghorn's Avatar
Re: 307 Chevy motor
Way back, I had a '69 Chevy 307 with an SM465 and 4.10 gears. The guy that owned it from new was a tree trimmer. He pulled a triple axle dump trailer with it. He went over the scales loaded at 13,000 lbs! Forget power, how the hell he every STOPPED that thing is beyond me! But I digress... The truck is owned by my neighbor to this day and has over 400,000 miles on the third 307 (and still stock tranny and rear end). And BTW, the only reason the 2nd engine gave up the ghost was the bonehead ran it with no AIR FILTER for 3 years!! He finally sucked a rock or something into the engine and lunched it.
I now have a '70 Chevy 1/2 ton with a 307. I've got some bugs to work out with it, but if I get that resolved, I'll run it until it's blowing more oil than fuel. Then I'll dump a 350 with a 700R4 in it and keep it for another 100 years.
69GMCLonghorn is offline   Reply With Quote
Old 01-08-2014, 06:33 PM   #23
Re: 307 Chevy motor
Well... Now I'm crying. I just found out that my 307 turned out to be a 305. Now I have a boat anchor. Too much money to get even 300 horses out of this dog. ��
Old 01-08-2014, 07:14 PM   #24
zeldman
zeldman's Avatar
Re: 307 Chevy motor
Dont bash the 305. A different set of heads, good intake and cam designed for the 305 and it will surprise you.
2005 GMC K2500HD D/A
1993 GMC K1500
2011 Subaru Legacy.
2013 Subaru Outback
1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot.
zeldman is offline   Reply With Quote
Old 01-08-2014, 09:34 PM   #25
Re: 307 Chevy motor
Like I said. Too much money for not enough gain!
