01-07-2014, 07:10 PM | #76 |
Re: My build thread- 67 C10 SWB
Thank you sir, you have an impressive piece of sheetmetal of your own! Nice truck!
My 67 Chevy C10 SWB build: http://67-72chevytrucks.com/vboard/s...30#post6406130 Hydroboost conversion: http://67-72chevytrucks.com/vboard/s...22#post6405622 |
01-07-2014, 07:19 PM | #77 |
67cheby
thanks man !
01-07-2014, 10:13 PM | #78 |
Now that the bed metal is here from LMC, I can work on that until the mufflers arrive. Like a idiot, I am piecing it together. I smart person would have just bought the complete steel bed already assembled. But I am probably saving a couple hundred bucks by welding it together myself.
01-08-2014, 10:03 PM | #79 |
The Spintechs are here and exactly what I needed! (provided they aren't too loud) (1) 45 gets me right to the Xpipe and the other gets me right where I need the exhaust tips to be. These mufflers look like very good pieces, very well built! Still fabricating the muffler brackets.
01-08-2014, 11:23 PM | #80 |
This is a nice build!
01-09-2014, 11:39 AM | #81 |
Did you learn to mig weld starting on body panels? I just started mig welding myself and I have to weld on my rockers, fill old tank fill hole, and shave side markers. Any tips?
01-09-2014, 12:21 PM | #82 |
Still Learning
You did a great job saving that cab! For a second, I thought dang that was fast! Then I saw the date stamp 2011. Time lapse....? tetanus shot . Nice build.
01-09-2014, 05:57 PM | #83 | |
I really like the copper backing when working with sheetmetal because you can turn the heat up a little more to get better penetration an not worry as much about burn through. http://www.eastwood.com/butt-weld-cl...ckers-kit.html
01-09-2014, 06:03 PM | #84 |
Thank you. Lol, I started this truck in June 2011. This has been over 3 years in the making, and still a long ways to go. Then I decided to share what I have learned in the process after getting inquiries into the complete floor pan process.
01-09-2014, 06:24 PM | #85 | |
http://www.eastwood.com/soft-copper-triangle.html
01-12-2014, 08:47 PM | #86 |
4 more pipes left to take care off and probably need to add at least 4 more hangers.
01-12-2014, 09:43 PM | #87 |
Looks great Checkmate! I'm about to install a Magnaflow system on my 72. What cats are you using?
Thanks,
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
01-12-2014, 09:56 PM | #88 |
Thanks! No cats, just flex pipes to absorb the vibrations from the motor. Decided to use flex pipes to avoid putting the torque stress on the exhaust pipe joints.
01-13-2014, 09:18 AM | #89 |
Nice job on the exhaust
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
05-08-2014, 10:29 AM | #90 |
um it's May already no update since January.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
05-08-2014, 06:22 PM | #91 |
I know man! Sorry, a lot of changes went down at work in January. So a lot more responsibilities got thrown into my lap, unfortunately, more pay was not. Overtime is now at my discretion, so that was my "raise". Also was "handed" a company phone, so even when I'm not at work, I am. Seems like the likelihood of raises went out the door when the current idiot usurped the Oval Office.
05-08-2014, 07:41 PM | #92 |
Huh my work schedule changed for the worse also, I feel like I'm always there and never have any time off unless I use vacation.
05-08-2014, 08:35 PM | #93 |
I feel ya. I'm terrified to use vacation time because I'm the only true parts/tire guy. Inventory is hard enough to keep straight when I'm there, let alone being gone for a few days. I will be out doing forklift tires tomorrow, so I cringe at the thought of what the end of my day will be like.
05-16-2014, 06:32 PM | #94 |
FINALLY!!!!! AN UPDATE! Got around to tacking the exhaust and then got someone to TIG weld. Still a little more to go, but finally some progress.
05-26-2014, 11:38 AM | #95 |
Managed to get some work done on the dash this weekend.
05-28-2014, 08:57 PM | #96 |
Decided I need to get this bed together so its not taking up so much room in the garage.
05-28-2014, 09:00 PM | #97 |
That dash is looking great. What size exhaust did you put in it.
05-28-2014, 09:09 PM | #98 |
Thanks Matt. Kinda procrastinating on the dash, can be a bit stressful at times. The dash is my make/break on the build. If it looks like crap, I will look like an idiot. The exhaust is 2 1/2". The largest motor I ever plan on putting in the truck is a 383, so I should be good for a while. Most of it is 304 stainless, but the X pipe is 409. The mufflers are aluminized Spintechs. Once the bed is done, I can plan the position of the tips (forward of the rear tires).
05-28-2014, 09:38 PM | #99 |
The dash is defenately a monumental task, but it is looking as good as the rest of your build.
05-29-2014, 12:14 AM | #100 |
Still Learning
Very nice progress. Looking good.
