#101 |
60-66 Nut
Re: Power Brake Booster Adapter Bracket
#102 |
![]() Join Date: Oct 2013
Will this put you back up front so I can keep tabs on you and your nice fab work!!
#103 |
60-66 Nut
It will for just a short time with as busy as this classified section is. You can always find this thread again by either subscribing to it, or simply follow the link to it from my signature line.
#104 |
Received my bracket in the mail yesterday! Looks great! Thanks again! Now I've just gotta find time to put it on.
61 apache |
#105 |
![]() Join Date: Dec 2006
PM sent
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#106 |
60-66 Nut
#107 |
#108 |
Hey, just getting started on a build of a '70 Long bed stepside. What exactly is the advantage of using this setup?
#109 |
60-66 Nut
The purpose of my '67-'72 brake booster bracket is to get the booster and master cylinder closer to the firewall instead of hanging way out there. You do not have to use a newer booster if you don't want to. The '67-'70 is one of the compatable boosters. But if you are going to upgrade to front disc brakes, that would not be the one that I would choose. If you do go with a newer brake booster, you can find one in just about any wrecking yard or parts store.
#110 |
60-66 Nut
I have 2 of these '67-'72 booster brackets that are zinc plated. The price is the same as the powder coated version which is $61.50 plus $11.65 for shipping.
#111 |
60-66 Nut
One zinc plated booster bracket left
#112 |
Does this set up work for disk/disk? I want to use the same power booster as all of you are talking about. I am running a ls5.3. w/ a 4l60e.
#113 |
60-66 Nut
This booster bracket will work for all types of braking systems. You will just need to use a master cylinder and prop valve for a disc/disc system with the booster that you select. Some guys recommend a dual diaphram for a disc/disc system.
#114 |
Getting ready to install a setup on my 70 LB stepside. I'll post pics as I get it done and let everyone know how the conversion goes. Got my brackets from Captainfab for the Impala rear disc setup and the booter bracket as well. It's 4 wheel manual drum now. Got a pair of 2 1/2" drop spindles that'll be here tomorrow. Gonna use a Wilwood adjustable proportioning valve.
#115 |
Wide n'Low
![]() Join Date: Jan 2007
Sending PM for a pair of brackets
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
#116 |
60-66 Nut
I still have one zinc plated booster bracket.
#117 |
Subscribed
What do you have available? |
#118 |
60-66 Nut
I still have the zinc plated booster bracket as well as several in bare steel. I am currently out of the satin black powder coated booster brackets but I will be getting more done.
#119 | |
What would the cost for bare steel shipped to 77095? Thanks |
#120 |
60-66 Nut
The total price for the zinc plated booster bracket is the same as in post #110 above.........$73.15. The price for the bare steel booster bracket is the same as in post #1 of this thread.......$66.65.
#121 |
Registerd User
![]() Join Date: Nov 2006
I have a i6 250 and have read that I will need an offset breather if I go with a booster. If I use your bracket will my factory breather clear.
#122 |
60-66 Nut
I haven't received any feedback nor any personal experience with a I6 and my booster bracket. I made some measurements and I think that if you used a 9" diameter booster, it would fit with your stock air cleaner. If you have power steering, you could always go hydroboost.
#123 |
Do you have this bracket with a hydraulic clutch bracket?
#124 |
60-66 Nut
You must not have received the PM I sent you last night?
Yes I do make a hydraulic clutch conversion for the '67-'72 trucks. I do not have a pic of it on this computer. I can get a pic tomorrow when I am at my shop. It is basically the same as what I make for the '60-'62's and '63-'66's. The price is the same as well.
#125 |
Thanks!
