#8951 |
Re: What did you do to your truck today?
well today i found some oem bumper brackets, and the spring and adjuster rod for my bench seat. and hopeful helped a guy get some rims shipped. sorry no pics as im waiting for the parts to be shipped!!!
#8952 |
![]() Join Date: Nov 2010
Got the rear down 4 inches
LIFE IS SHORT HAVE FUN |
#8953 |
i envy your valve covers endlessearth.
#8954 |
#8955 |
hey endless. what alt/gen u going with cu i have the same set ram style and oem bottom braket, but my alt is a few hairs off, making my belt no inline. any tricks, short of going into the alt and adding spacers behind the pulley?
#8956 |
hate to have a fan belt brake on my engine..
#8957 |
![]() Join Date: Sep 2006
started stripping down one of my trucks for parts. It is a 3/4 ton and I am just going to swapall the parts and put them on a 66 short frame.. I finally took the spare out and it is a 15" 8 lug wheel. The tire is a 7.50-15. It seems to be a split rim with the split.. First one i have even seen and I was a tire Tech back in the early 80's. Maybe I did see one but don't remember.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
#8958 |
ready made parts truck i like it...
#8959 | |
![]() Quote:
Sam |
#8960 | |
![]() Quote:
Sam |
#8961 |
yeah i did the back side already, just hated to butcher my nice oem part i search'd months for. i did see a post once about the spacer thing. i was seeing if others had the same issue first. thks
#8962 |
Thanks and yes I know.. I was a tire tech back in the early 80's and acually worked on split rims a bit. This tire will probably be taken apart and the rim scrapped. To dangerous to be used on any trucks.
#8963 | |
WANTED: * 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls. Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117 |
#8964 |
#8965 |
#8966 |
#8967 |
Make up or buy a roll pan, smmmooth, nice and clean looking. That bumper of yours is..
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
#8968 |
poured the oil into my new 327 - went to crawl under the old girl an hour later and there's a sizable puddle under the truck... reached down and felt around the drain plug - thinking ****e man - so disgusted I walked back into the house and told myself I have a mess to clean up tomorrow... figured it just wasn't going to be my day.
64 Step Side - The Mistress |
#8969 |
Fun reading through here ans seeing daily progress on randomness so I'll play along.
Today/this week I painted my new wheels a color I like to call "Cherry Coke" and got them ready for mock up. I also cut out all the old floor bed metal (had previouslly put it in to cover the airbag set up) to get ready for my wood bed to go back in. Which I also stained and cleared. Lastly I sprayed the dash in it's first coats of metal flake to "motivate" me forward on the interior design. I'll start up a build/progress thread soon here.
www.chadcantcolor.com |
#8970 |
last weekend got the 454 set in truck (65 one ton camper), and the th400 in. Had to modify engine mounts on frame and trim back top of frame rails, built radiator mounts for cross flow radiator out of donor vehicle. hope to finish up this weekend and get running. will post pics later.
![]() 71 GMC Long Bed, 454,factory everything, lowered, and shaved. 64 GMC Short Bed (great grandfathers truck) 65 Chevy 1 ton Dually a/c p/s p/b v8 auto 89 Jeep Cherokee 3" lift 79 MG Midget (My 7 year old vehicle) 29 Ford Model A Rat Rod (in the works) 86 pontiac fiero 2.5 manual18 year olds) 87 pontiac fiero SE 2.8 auto (18 year olds) 90 Mitsubishi eclipes turbo AWD (18 year olds) 69 BMW 1600 (wifes toy) |
#8971 |
I would say new bumper, but maybe paint it white. Depending on what look you are going for and if the front bumper is chrome.
#8972 |
![]() Join Date: Mar 2013
Put a can of sea foam fuel additive in my truck today.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#8973 |
While not actually something on the truck... more something for the truck to go on... Installed a two post lift while temperature wasn't in the single digits. Tomorrow I need to pickup some hydraulic oil and finish up the wiring before putting the 65 C20 on it.
Charlie.
See what I park on the other side of the garage http://www.57camaro.com |
#8974 |
#8975 |
that chrome bumper looks good, is it oem?
