01-09-2014, 11:28 PM | #1 |
lowering my 68 swb
heyguys!
Icurrently have a stock frontend, when Ibought it, it came with 5 lug discbrake upfront. it has factory control arms and bolt in ball joints. I'm not 100% sure which route to.take.. I would love a mild/extreme Porterbuilt.. but that is kind of expensive for me right now. so I'm leaning towards dropspindles.. any input and ideas would be greatly appreciated! |
01-09-2014, 11:47 PM | #2 |
Re: lowering my 68 swb
here's how she sits right now
01-10-2014, 02:07 AM | #3 |
Do porterbuilt stage one and add the drop member later as you can reuse most of the parts
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
01-10-2014, 08:34 AM | #4 |
01-10-2014, 09:38 AM | #5 |
If you go with bags the stage 1 would just be bags and cups and you reuse your stock control arms. I would still run a drop spindle anyway to get you that extra 2.5" drop. I would run the stage one front with the stage 2 basic rear kit that way you get there adjustable panhard bar, c-notches and shock crossmember. That with the stage one front would make for a nice kit. Very nice truck by the way.
Check out this thread, he did a great job showing the different stages of his Porterbuilt suspension. http://67-72chevytrucks.com/vboard/s...d.php?t=609897
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
01-10-2014, 09:59 AM | #6 |
For the 6x-87 C10's.... drop spindles before any other lowering mod. Then, if additional drop is desired, go from there. On 6x-70 trucks, swapping to disc brakes is 2nd behind the drop spindles just for the improved braking.
You need to determine how much drop you want. That helps determine which 'way to go'.
01-10-2014, 12:08 PM | #7 | |
question.. if I already have disc upfront on my 68.. What wouldl I order thedrop spindles for? a 70+? |
01-10-2014, 12:28 PM | #8 |
Happy to be here
your truck has been converted to disc brake. There are several methods used ranging from stock parts to aftermarket kits. You will need to determine what was used to order the correct era drop spindle.
01-10-2014, 02:52 PM | #9 |
this may sound.stupid to.some, but how would I know what I got on there? all I know that it is disc in.front 5lug.. control arms look stock due to.the steel controlarm bushings.. theupperballjoint is bolted in.. notsure if 68 came with bolt in.ball joints
01-10-2014, 03:05 PM | #10 |
Vintage Evil
sorry to thread jack... but which wheels are those?
01-10-2014, 06:47 PM | #11 |
theyare Boyd coddington.. notsure what series.. camewithtruck 20s frontandrear
01-10-2014, 07:23 PM | #12 |
Wellthey had Boyd coddington centercaps
