Old 01-10-2014, 02:43 PM   #26
68chvy
Re: Porterbuilt Stage 1 Front and Rear Kit Chart
question... how much did you spend? And it is bags right? stock arms? thanksfortheinfo!
Wellbedoingthesame once income tax money comes lol
68chvy is offline   Reply With Quote
Old 01-10-2014, 02:48 PM   #27
68chvy
Originally Posted by Porterbuilt Street Rods View Post
Matt-
Thanks for the write up! We will be borrowing your comparison pic you put together!
I plan on painting your truck and putting some wheels on it (digitally of course)... what are your plans for paint and wheels? Might as well try and make it look like it will when you complete it!
Nate
isthere any way you can.send me a parts list I will need to order if I wanted this exactdrop? ErikEscobar@ymail.com stageone front kit and I guess thestage two kit for rear.. I plan on getting some dropspindles and using stock control arms for now
Old 01-10-2014, 03:08 PM   #28
PBFAB.COM
PBFAB.COM's Avatar
We will be happy to. If you don't see an email today, look for it Monday.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 01-10-2014, 03:55 PM   #29
Dano69c10
Dano69c10's Avatar
According to the chart;
If I get the Stage 1 (f/r) w/ stock spindles and a-arms, then I will still be riding at about stock height?
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 01-10-2014, 04:04 PM   #30
PBFAB.COM
PBFAB.COM's Avatar
Correct. By swapping the steel spring with an air spring (everything else staying consistent) the "ride height change" could be minimal if even noticeable.
However, there will be some lea-way with the adjustability the air spring offers, but additional drop would achieved with a drop spindle and or tubular lower control arm.
It's always hard to define where "ride height" actually is when running an air suspension, as it can change with the air bag being inflated or deflated. Some like more pressure for a little firmer ride others like less for a softer ride. It's all based on preference.
In this case, for discussion purposes, it won't change much.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-10-2014, 07:04 PM   #31
MattPSU
MattPSU's Avatar
Correct - Bags.
Here's a basic rundown of what all I bought. Keep in mind, I also bought some tools (step bits, saw blades, cutting discs, etc.) and paint to complete the job. I made each item listed a link so you could see/read more.
Porterbuilt Stage 1 Front Kit - $365.00
Porterbuilt Stage 1 Rear Kit - $365.00
Porterbuilt Bolt In Notch - $249.00
Porterbuilt Adjustable Trac Bar - $149.00
McGaughy's 2.5" Drop Spindles - $242.00
2 - Pro Performance 1/4" Manual Schrader Valve Kit - $39.00 each
Total - $1448.00 plus shipping
If I were to do it again, I'd do this:
Porterbuilt Stage 2 Rear Kit - $799.00
Total - $1484.00 plus shipping. For $36 more you'll have the stage 2 shock bar system which I'm guessing is easily worth the difference.
- Matt
Matt Criswell - Lyman, SC
1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank
UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE
MattPSU is offline   Reply With Quote
Old 01-10-2014, 07:09 PM   #32
MattPSU
MattPSU's Avatar
Nate already confirmed this but I'll add that the ride quality is greatly improved over the jarring, bouncy ride on the stock springs & shocks. I had never even ridden in a bagged truck/car before I did this and wasn't sure if I'd be happy. I can't believe I ever even had a doubt about it.
Old 01-11-2014, 11:58 AM   #33
68chvy
Originally Posted by MattPSU View Post
Correct - Bags.
- Matt
thanks man, im sure this is the route I am going to go.. thanks again..
Old 01-11-2014, 12:45 PM   #34
Dano69c10
Dano69c10's Avatar
I want to stay about stock height, but was wondering if I do want to adjust the stance;
Are there air bags that are shorter in order to maintain air pressure, but lower the ride?
Dano
'69 Fleet
Old 01-12-2014, 05:58 PM   #35
Dano69c10
Dano69c10's Avatar
Dano
Any 1? ?????
'69 Fleet
Old 01-12-2014, 06:20 PM   #36
MattPSU
MattPSU's Avatar
Dano
I'm not sure about shorter bags. I'll let Travis, Nate or someone else who knows answer that question.
After I did the Stage 1 kits, I decided that I wanted to have a lower ride height too which is why I added the drop spindles and notch. I also removed the upper cups in the rear. Never thought about shorter bags, but removing those cups does make the bag shorter.
Changing the pressure changes the height as desired. These kits give about 6-8" of adjust-ability. Of course you don't want to run at 0 psi or at full pressure.
Personally, I like the fact that I have a nice ride with a slightly lowered stance and I can let the air out when I get to my destination and appear to have a super low truck. I had an S10 that was statically dropped a good bit, and it looked cool, but rode like crap. My C10 rides great AND has the desired look when parked.
Not sure if that answered your question or not. - Matt
Old 01-12-2014, 07:08 PM   #37
68chvy
is there a switch to disinflate bags?
Old 01-12-2014, 07:10 PM   #38
68chvy
Nd how do you get it back.up?
Old 01-12-2014, 07:23 PM   #39
MattPSU
MattPSU's Avatar
Eventually I'll have compressors, tanks and Accuair controls. But for now I have all the lines running to the cab where I've mounted a small gauge and schrader valve for each bag. I use the compressor in my garage to air the bags up and I just use my fingers to release the schrader valves to lower it. I have a 9 gallon tank that I keep in the bed when I drive it somewhere. This gives me the ability to air the bags up from empty one time. I also carry a small compressor that I can plug into the cig lighter if need be.
Old 01-12-2014, 07:26 PM   #40
68chvy
cool
Old 01-12-2014, 07:30 PM   #41
68chvy
you have a link of what you would need like what controls and compressor I.would.need.. I plan on doing.this drop soon so gathering my parts list.. thnx again.on.info
Old 01-12-2014, 07:41 PM   #42
MattPSU
MattPSU's Avatar
http://www.azproperformance.com/Air-Management-Kits/
Here's a link to the air management systems that Pro Performance offers. The Manual, Pro 1 and Pro 2 kits are nice in that they include everything you'll need. I'm sure you could piece one together, but these kits will have all the wiring, fittings, air line, etc. that you'll need.
I highly recommend that you call Travis at Pro Performance and tell him what all you're looking for. He'll help you put together everything so that you don't miss anything. If you want to do some variation on one of these kits (two tanks rather than one for example), he'll create a package to meet your needs/goals.
If you need more help, let me know. If you want my number/email, let me know and I'll PM you with that info.
BTW - just checked out your truck. Very nice. You guys and your LS swaps have me thinking that may be my power plant route when I get to that point.
Thanks - Matt
Old 01-14-2014, 11:39 AM   #43
Desert.Chevy
Desert.Chevy's Avatar
Good info, Thanks. Truck looks good too.
Desert.Chevy is offline   Reply With Quote
Old 01-29-2014, 10:24 AM   #44
c10Dream'n
c10Dream'n's Avatar
That was one heck of a write up. thanks for the visual. I have made up my mind and plan on piecing mine together since i won't be able to drop all the cash at once on the whole set-up.
My setup currently consists of CPP tubular control arms, ECE 4/6 kit wit 1" blocks in the rear. I have a CPP bolt in notch as well. I will have to talk to Nate or Travis bout my options.
Matt,
do you know what the difference is between having a 3 or 5 gallon tank? along with having 1 or 2 compressors? Thanks again.
c10Dream'n is offline   Reply With Quote
Old 01-29-2014, 10:33 AM   #45
PBFAB.COM
PBFAB.COM's Avatar
Matt,
We recommend running 2 compressors if you go to a 5 gallon tank. One compressor per 3 gallon tank also works well. We make some neat brackets that mount a compressor and a 3 gallon tank to the frame rail.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-29-2014, 01:23 PM   #46
MattPSU
MattPSU's Avatar
Matt,
Piecing it together is exactly what I did. It's taken a year and a half, but I'm happy with the results.
I would recommend talking to Nate and/or Travis about which components you can use with your current set-up. I think you're ok, but I'd check just to be sure.
My understanding on the compressors/tanks issue is pretty simple. The more compressor out you have, whether it's one or two, the faster you can fill your tanks. The more tank space you have, the longer it'll take to fill. But, the more tank space you have, the quicker you can raise your truck back up. I've been told that if you're not planning on playing around much, and you're never going to be in a hurry, you can get away with a smaller compressor and/or tank. But if you want to play and/or have a quicker response time, larger and/or multiple compressors and tanks are recommended.
The way I see it is that it seems like no matter what I do, I always want more! I lowered it some, then I wanted it lower. So with tanks and compressors, I'm was initially thinking I wouldn't play much, but when I let the air out of the bags using the schrader valves now, everyone watching smiles. I know I'll want to play at least a little, so duel tanks and compressors will be the route I go. And I'll mount them using the Porterbuilt brackets above. One of each on each side.
Good luck - Matt
Old 01-29-2014, 04:39 PM   #47
chevjayfsd
Project 7dos
chevjayfsd's Avatar
I agree Matt... Being able to pull up to grab some milk for the kids and airing it out while you run in, with people looking at your truck and hearing it, is an awesome experience... lol.
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
PSSST - Yes it's bagged.
7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290
chevjayfsd is offline   Reply With Quote
Old 01-29-2014, 04:53 PM   #48
c10Dream'n
c10Dream'n's Avatar
Thanks for your point of view Matt. I to like the set-up they provide with the bracket for compressor and tank. DECISIONS DECISIONS!!!!!!!!!
Old 02-04-2014, 11:22 PM   #49
mano
mano's Avatar
Originally Posted by nds1968 View Post
I am going to run shrader valves on the rear bags. I was thinking about going with coils again but I already have the bags, line and shraders. I just want to get my truck back in one piece again Then I can decide if I want to fully bag the truck. I'd rather not spend the money or the time messing with that now.
I grew up in Arlington (on the hill above South Side). I live in Brentwood now. My Dad moved out your way a few years ago to Freeport. Now he tells people he lives out in the country
Your truck looks awesome, keep up the good work. Nate
Ha your not even 5 mins away from me. lol I lived in Brentwood for 6 years.
mano is offline   Reply With Quote
Old 03-14-2014, 09:48 AM   #50
muckyp
muckyp's Avatar
MattPSU - are those 15" wheels on the truck in the photos? If so did you have issues with the wheels rubbing the lower control arms?
70 SWB 454/TH400
muckyp is offline   Reply With Quote
