Old 01-11-2014, 10:36 PM   #1
DreamRyder1963
DreamRyder1963's Avatar
Edlebrock C4B Intake
I picked up this old Edlebrock C4B intake in hopes of swapping it out with my Offenhauser 360 degree intake. I am looking for more low end torque. My problem is that I am concerned that this intake will not work with my HEI. Does anyone have experience with this intake?
1971 Chevy C10 Cheyenne (sold for Mazda)
1963 Chevy Corvair Pro-Touring Project
2012 Mazda 3 i Sport sedan
http://www.dracoautodesigns.com/
DreamRyder1963 is offline   Reply With Quote
Old 01-11-2014, 10:44 PM   #2
burnin oil
Re: Edlebrock C4B Intake
I think that it will clear with no problems. I have no experience with that manifold though. It is older than I am! You may be able to make a few bucks from someone doing a 60s period build.
burnin oil is offline   Reply With Quote
Old 01-11-2014, 10:50 PM   #3
DreamRyder1963
If it doesn't clear that will be my plan. The part I'm concerned about is the rear runner. It seems to be taller than on most intakes.
Old 01-11-2014, 11:12 PM   #4
burnin oil
Just measured a HEI dizzy. There is 2 1/8" from the bottom of the mounting pad to the base where the cap goes.
Old 01-12-2014, 12:25 PM   #5
DreamRyder1963
I just measured the space on the intake. There is only about 1 3/8" on space between the runner and the outer edge of the hole.
Old 01-12-2014, 01:38 PM   #6
oldschool18
oldschool18's Avatar
what is your height clearance?
_________________________________
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Members Met......2003Silverado (Dave)
oldschool18 is offline   Reply With Quote
Old 01-12-2014, 01:52 PM   #7
DreamRyder1963
The runner is about 2" tall at an almost 90 degree angle.
Old 01-12-2014, 02:32 PM   #8
oldschool18
I think burnin oil meant you had 2 1/8" clearance in height?
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Old 01-12-2014, 02:56 PM   #9
DreamRyder1963
If thats the case then my distrubitor might fit. I think I have a spare at the house that I can test fit. I read on a different forum that someone had to grind off some of the runner to get to fit correctly. I might just clean it up and flip for an Edelbrock Perfomer EPS.
Old 01-12-2014, 04:29 PM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I restored an earlier one that that, a C3BX for my 327. Cleared the HEI just fine.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-12-2014, 04:34 PM   #11
DreamRyder1963
How do you like it Tx Firefighter?
Old 01-12-2014, 04:40 PM   #12
Tx Firefighter
I like funky old parts. After running it a while I changed it to a Performer RPM, but I had other reasons to do so.
Old 01-12-2014, 04:47 PM   #13
DreamRyder1963
How was it on low end torque? That is my main objective right now. My current intake is gutless when it comes to low end power.
Old 01-12-2014, 04:51 PM   #14
Tx Firefighter
I never had any complaint on the bottom end torque. It would blow the tires off at will.
Old 01-12-2014, 04:54 PM   #15
DreamRyder1963
Sweet thanks for your input.
Old 01-12-2014, 07:49 PM   #16
LSGarage
LSGarage's Avatar
I've had an old C4B in the garage for over 30 years. An HEI distributor would not fit when I tried the combination on a 79 El Camino that I had at the time.
67 GMC 4x4, 305 V-6, 4-spd
86 S-10, 2.8 2WD LWB
01 Suburban (family hauler)
13 Honda CRV (wife's wheels)
03 Malibu (daughter’s car)
LSGarage is offline   Reply With Quote
Old 01-12-2014, 08:04 PM   #17
DreamRyder1963
I'm pretty sure I have an old dizzy lying around I will mock it up later. I'm only in it $60 so I am good either way.
Old 01-12-2014, 08:38 PM   #18
bigguy69
dazed and confused
bigguy69's Avatar
I had that same intake. Mine cleared no problems with hei.
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 01-12-2014, 09:27 PM   #19
DreamRyder1963
I just tested the intake with the distributor. The edge of the base hits the top of the runner. It's just barely off probably no more than 1/4" of need clearance. I will probably just sell it and get another type.
