Closed Thread
Old 01-12-2014, 01:34 AM   #8676
texjake
texjake's Avatar
Re: What did you do to your truck today!
Originally Posted by magwakeenercew2jh View Post
Nate's right.
Like any tools, if there's a good and a "better" one, get the "better" one.
I use a small chunk of dish towel wrapped around the shaft (all bad jokes aside) with some success.
Some are easier to get than others. But having extra wire "pins" is a good idea.
I'll risk this observation: When you put 'em back on, you snap the wire on the groove in the handle
and when you're ready, whack it into place....But you got that already, right?
I got that part down. I got a piece of stainless wire bent at the right angles where I can snag the clip & pull those off, that's the easy part. I've been messing with those ol' window crank clips for over 35 years. I was talking about installing the 4 escutcheons', those are a tad bit pesky to install. It's what some of the trucks came with on the doors. Not the thin flat plastic/nylon washer escutcheons that were used on padded door panels between the window cranks/door handles & the door panel. Mine had the thicker escutcheons'. See pic.
texjake is offline
Old 01-12-2014, 01:49 AM   #8677
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today!
Glad you used those , most are too lazy to care .
They're easy to install : hold them in place , and bang the handle on with the palm of your other hand .
I replaced these on my C/10 just because they were gone missing and I hate the drafts & rattles they prevent .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 01-12-2014, 01:54 AM   #8678
OregonNed
OregonNed's Avatar
I got the dash pad replaced and new visors and rods installed. Will be putting my newly recovered door panels in tomorrow - along with new handles, cranks and arm rests.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 01-12-2014, 06:11 PM   #8679
74baggedbug
Did something a bit diffrent on the roof..
74baggedbug is offline
Old 01-12-2014, 06:19 PM   #8680
67Slider
67Slider's Avatar
I got to spend a few minutes working on the truck. I replaced the shift indicator cable on my B&M shifter. It was a nice weekend here in CO. I tuned up the jeep, new plugs, wires, cap, rotor, fuel and air filter. Running like a champ now. I had to recharged the K&N air filter on my Toyota and replace the serpentine belt. Damn Toyota is made for tiny hands. Sure makes me appreciate the room I have in the truck. Watching the bronco game now. Go Manning.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 01-12-2014, 06:36 PM   #8681
In The Ten Ring
I bought a second set of front bumper guards.....just in case the current set ever takes a bad hit or I get another truck.
In The Ten Ring is offline
Old 01-12-2014, 07:26 PM   #8682
Lanman1972
Lanman1972's Avatar
Changed spark plugs, a/c vents and put on the sport mirrors
Lanman1972 is offline
Old 01-12-2014, 07:57 PM   #8683
Katrina/10
Katrina/10's Avatar
Like the smaller mirrors, what are you going to do with old holes?
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline
Old 01-12-2014, 09:16 PM   #8684
VWNate1
VWNate1's Avatar
Thumbs up Re : Custom Paint
You Sir , have MAD skills ! . I remember in the 1970's when so many Los Angeles cars had this typ of paint , it was *very* labor intensive and often had the appearance of overlapping lines in it .
Kudos .
-Nate
-Nate
Geezer
VWNate1 is offline
Old 01-12-2014, 09:19 PM   #8685
Molberg
Molberg's Avatar
That is awesome! Great work.
-Project Nitemare-
http://67-72chevytrucks.com/vboard/s...d.php?t=607359
Molberg is offline
Old 01-12-2014, 09:34 PM   #8686
Molberg
Molberg's Avatar
Finally got it back in. Outside frame took hours of polishing... Planned on painting it originally. (Had it sanded)Brackets painted, headlights wired. Made some bumper bolts. (Watch your shins) Onto grille inserts now.
-Project Nitemare-
Molberg is offline
Old 01-12-2014, 10:02 PM   #8687
OregonNed
OregonNed's Avatar
Today I got my new black door panels on - also the new arm rests and internal handles
Old 01-12-2014, 11:04 PM   #8688
ole dollor
ole dollor's Avatar
for about the last 3 days I decided to try and clean up and paint the inside of the hood area. after scrubbing and masking and painting this is how it turned out, if every one remembers how nasty looking it was before , I hope they can see a big change....I sure think it looks better...a few pic's...
ole dollor is offline
Old 01-12-2014, 11:10 PM   #8689
VWNate1
VWNate1's Avatar
Question Re: What did you do to your truck today!
Is that a 292 ? who's AC brackets are you using ? .
Are you using the factory AC ' suitcase ' and controls ? .
Etc. , etc.
TIA ,
-Nate
Geezer
VWNate1 is offline
Old 01-12-2014, 11:18 PM   #8690
ole dollor
ole dollor's Avatar
Etc. , etc.
TIA ,
Nate I built my a/c bracket, it was easy, its a 292 , I have a under dash a/c unit , its a sanden compressor , to hot in Texas for an old fat guy to drive around without an a/c...
Old 01-12-2014, 11:45 PM   #8691
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Looks sharp, ole.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 01-12-2014, 11:56 PM   #8692
ole dollor
ole dollor's Avatar
Looks sharp, ole.
thanks a bunch , got tired of the nasty dirty look...
Old 01-13-2014, 12:50 AM   #8693
Willys47
Willys47's Avatar
I like that look way to go
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline
Old 01-13-2014, 12:55 AM   #8694
ole dollor
ole dollor's Avatar
Nate here is a pic of the hang on unit I have inside the cab...and a pic of the mirror with map lights I installed some time ago..
Old 01-13-2014, 01:15 AM   #8695
OregonNed
OregonNed's Avatar
Looking good, Ole!
Closed Thread
