Closed Thread
Old 01-12-2014, 03:16 PM   #8976
mud.man.rj
mud.man.rj's Avatar
Re: What did you do to your truck today?
Bumpers does look good, exh fits nice underneath it too.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 01-12-2014, 03:36 PM   #8977
firemanjimtfd
firemanjimtfd's Avatar
Not sure if its a OEM bumper. It is a used one . Has a few nicks and scrapes. Truck is a driver. Ordered brackets from Classic and they fit well. Now I have to get the correct tag holder, filler panels and right bumper bolts.
firemanjimtfd is offline
Old 01-12-2014, 04:33 PM   #8978
pimpston65
pimpston65's Avatar
i got my correct bumper bolts from aspensautoaz.com they sell usable 60-66 parts you get 6 bolts,washers and nuts for $10 plus i think $7 for shipped. i just wire wheeled em and the come out great!!!! ps the bolts for the brackets to frame are different, they dont have the rounded head, just a hex head. i found a guy on CL and grabbed 4 from him.
pimpston65 is offline
Old 01-12-2014, 04:44 PM   #8979
pimpston65
pimpston65's Avatar
they have em, they work on the back bumper also, cuz i used em. both on front and back bumpers
Old 01-12-2014, 06:30 PM   #8980
jayoldschool
Moderator
You can get those bolts at Lowes.
jayoldschool is online now
Old 01-12-2014, 07:09 PM   #8981
pimpston65
pimpston65's Avatar
true, lowes does have hardware items. since im using only period correct items, i went with parts that came off a simular truck. also the hardware may not be the right grade for bumpers, and if it is the price is higher. one other thing the nuts have a groove on the outside that looks cool. ps im kinda particular bout the period correctness so thats why i shown what i use...
Old 01-12-2014, 09:10 PM   #8982
steveb64
steveb64's Avatar
Took my trailing arms off to cleanup and discovered a rust through spot. Looks like I'm now in the market for a replacement set.
steveb64 is offline
Old 01-12-2014, 09:13 PM   #8983
E911manager
sand, fill, tap, weld, grind. The bed will never be ready..
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice
http://67-72chevytrucks.com/vboard/s...d.php?t=492640
E911manager is offline
Old 01-12-2014, 09:17 PM   #8984
dougf
dougf's Avatar
I agree, if thats the only spot with a rust through issue, then I would cut that part out and weld in a plate on both sides, wire wheel and paint the set. It just depends on if thats the ONLY damage, I have seen pics of these rusting from the inside out at the seam where they join, which hopefully isnt the case here.
dougf is offline
Old 01-12-2014, 10:02 PM   #8985
Softpatch
Softpatch's Avatar
Originally Posted by firemanjimtfd View Post
Changed out the old white painted bumper for a chrome one.
nice I'm in
were did you get the bumper and the brackets.?
Softpatch is offline
Old 01-13-2014, 01:32 AM   #8986
64shortbox
64shortbox's Avatar
Spent today and Saturday installing an aftermarket column shift linkage, replacing the shift shaft seal in the transmission and changing the plugs & wires. It took forever to get the indicator to center in the P R N D 1 2 letters on the column and the shift shaft seal still leaks. Guess I need to pull the trans pan and remove the shift shaft & see if it has any burs or nicks on it. CPP now has their linkage on sale for $39.00. The one I bought just used all thread and I didn't like the way it looked so I slid a piece of 3/8" stainless tubing over the all thread to make it look a little better.
64shortbox is offline
Old 01-20-2014, 11:39 PM   #8987
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Here is the continuation of this thread.
What did you do to your truck today, Part II
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline
Closed Thread
