#201 |
Rollin' Old Skool
Re: Power Brake Booster Adapter Bracket
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
#202 |
Captainfab this looks perfect. How do I get one?
#203 |
60-66 Nut
I'll send you a PM with ordering and payment details.
#204 |
Arrived quickly and fits like a glove. Great business, great product!
#205 |
60-66 Nut
Thanks for the purchase and the compliments
#206 | |
Captainfab...can any of the above be used with drum/drum? im getting ready to work on a 63 panel/230 for my wife and need power first...then i will convert to disk at a later date if this is possible. thanks. |
#207 |
60-66 Nut
Most any of those boosters can be used with a drum/drum braking system. You just need the correct master cylinder. Since you are planning on upgrading to discs at a later time, I would suggest any of the listed boosters except the '67-'70 pickup, Suburban and Blazer booster. Then for a master cylinder you will want the '70 Buick Estate wagon master cylinder. The A1 Cardone number is 10-1363. Double check to be sure the one they give you have the shallow bore. It is basically just a dimple in the back of the piston which will be compatable with any of those boosters listed.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 11-04-2013 at 01:34 AM. |
#208 |
How can a guy go about getting the brake booster bracket for 60-62 that i seen on here that you build. How to ship it Grande Prairie Alberta Canada. What cost and payment. Cheers.
#209 |
60-66 Nut
I sent you a PM with details.
#210 |
![]() Join Date: Jul 2013
Can you send me details i am looking for black powder coat bracket
#211 |
#212 |
sorry its captainfab
#213 |
60-66 Nut
PM sent
#214 |
Captain, it's Mike in Colorado. I received the power steering bracket today as you said. Will check it out tomorrow. Thanks, Mike
#215 |
Captain, I'm sending u a pm. I have questions. Thanks, Mike
#216 |
I'm going to be ordering a booster bracket for '64 1/2 ton with discs up front. Read thru post , anyone have info or links on making / proper adjustment on making rods work ?
#217 |
60-66 Nut
Are you needing to know how to lengthen the booster pushrod? Or is your question about the intermediate pushrod?
#218 |
Just wondering on how to tell correct length an how to adjust. Have no problem making it longer or shorter
#219 |
60-66 Nut
The recommended adjustment for the booster to pedal pushrod is around 1/4" to the bumpstop, but it is also a matter of personal preference. I like mine a little tighter than that. But you have to be careful that you don't preload the master cylinder. If that does happen, everytime you push the pedal, the brakes will begin 'pumping up' until the brakes are totally locked.
#220 |
![]() Join Date: Jan 2011
I need to order another booster bracket for the 66 I just got. I am going to leave it drum drum for a now but need to split the brakes and go to a duel master cylinder. Whats the best combo of booster and master? Was looking at just putting the complete 67 setup on it.
Thanks Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#221 | |
60-66 Nut
Since you are staying drum/drum, yes you will want to use a '67-'70 booster and master cylinder, or any of the compatable boosters along with the '70 Buick Estate wagon master cylinder. Have you seen Sharps40 thread on his power brake upgrade? I'll send you a PM with payment info.
#222 |
Thanks for the info and payment made on the bracket. If I go this route and decide to go with front disc would a master cylinder and proportioning valve swap be all that needed? I have a bad habit of not leaving well enough alone.
Thanks Jimmy
#223 |
60-66 Nut
If you think you may go with discs later, I would go with any one of the compatable boosters and the '70 Buick Estate wagon master cylinder (A1 Cardone #10-1363), rather than the '67-'70 booster and master. The reason being is that the '67-'70 booster has the long intermediate pushrod for a deep bore master cylinder. The majority of the disc brake master cylinders have the shallow bore. The Buick master is for drum/drum brakes but is a shallow bore master.
#224 |
Thanks for the info. That is what I will do.
Jimmy
#225 |
Hi, I'm a new member to the forum. I have a 1965 chevy truck that is mostly stock but I would like to make some upgrades. I have seen your Power Brake Booster Adapter Bracket and would be interested in purchasing one. How would I go about buying one and what booster master cylinder combination would you recommend? Thanks!
