Old 01-13-2014, 01:21 AM   #1
1Ton
1Ton's Avatar
1990 Suburban fuel line issue
I am working on a 1990 Suburban with my nephew. Our issue is the fuel line from the fuel filter up to the braided stainless part is rotted out. I have been looking for this line and haven't had any luck. I cant flare the end at the stainless since the line is junk right up to the stainless. GM has discontinued this line, so do any of you know where I can get one? LMC doesn't have it either.
Support your local search and rescue team.... GET LOST!
Originally Posted by DURRTY
if some is good
more is better
too much ought to be enough........
1Ton is offline   Reply With Quote
Old 01-13-2014, 09:53 PM   #2
72MARIO
72MARIO's Avatar
Re: 1990 Suburban fuel line issue
Most auto parts stores have a pre flared line kits that come with 3/8 compression fittings. You can also get a hydraulic hose shop to make you a length of stainless flexible line with 3/8 compression fittings on either end.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-14-2014, 12:09 AM   #3
1Ton
1Ton's Avatar
Thank you.
I'll try that.
if some is good
more is better
