engine height???
I have 1950 AD 5.3 with Mll suspension, i would like to know what the maximum height i can set motor in order to gain oil pan and exhaust clearence.
Fabricate till you "puke"
Re: engine height???
I can not answer your question, as you would like to hear....but will tell you, that a trial fit will probably show you more? I would set the engine as LOW as possible in that truck.....just to where it all clears? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
