01-15-2014, 07:25 PM | #1 |
Power steering pump differences
Does anyone know what the differences are between the late sixties and the late eighties pumps ? Not the cosmetics, I know the later pumps had metric threads and used O rings for sealing, but do the later pumps work any better? Are they smoother? Any advantage to running a later pump? I'm talking about pumps with reservoir attached. Thanks!!
01-15-2014, 08:50 PM | #2 |
Re: Power steering pump differences
in 73 I think it was the ps pumps went to 3.5 turns lock to lock and b-4 that it was 4.5 so newer pumps seem like sports car handling.
01-15-2014, 10:08 PM | #3 |
01-16-2014, 09:03 AM | #4 |
So then, are the pumps basically the same?
01-16-2014, 09:44 AM | #5 |
01-16-2014, 10:21 AM | #6 |
not sure exactly when the change was but the later pumps have a press on pulley shaft and the 60's era were mounted with a keyway and a nut.
01-16-2014, 10:31 AM | #7 |
Pulley n bracket mounting could be a nightmare unless you switch to a complete setup. I have never tried it. But have in a complete serpentine. Noticed no difference in performance of the pump itself.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
01-16-2014, 10:49 AM | #8 |
Except the press on and nut on shaft type[don't know what to call it but that don't sound right]there is very little diff. The shaft that has the nut is a tiny bit smaller so that a press on type pulley can't be used on that kind of pump. Jim
01-16-2014, 10:50 AM | #9 |
their whole thing is just to push fluid with pressure and do it for a long time
01-16-2014, 11:16 AM | #10 |
I believe 1974 was the last year for the keyed shaft/pulley with a retainer nut.
