Old 01-16-2014, 05:42 PM   #1
dman1982
dman1982's Avatar
heater question
so I'm cleaning up my cluster and figured since i got all this out i might as well tackle some heater issues, my heater works, but it doesn't change or if it does change its when it wants to, it also only comes on when i turn it on full blast, what are some common issues caused by this? also the box on the passenger side makes this crazy sound like my truck is going to blow up haha...that is the most annoying thing tho, the defrost rarely comes on
84 k10, 350, scottsdale (if that helps)
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 01-16-2014, 05:55 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: heater question
sounds like a blower motor if its making a noise and prolly vacuum issues
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is online now   Reply With Quote
Old 01-16-2014, 06:05 PM   #3
dman1982
dman1982's Avatar
Re: heater question
thats what i was thinking....heck where do i start????
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 01-16-2014, 06:47 PM   #4
wilkin250r
wilkin250r's Avatar
Re: heater question
At Pick-N-Pull. Find a couple junkers and learn how they come apart.
If it only works at full blast, the problem is likely the resistor block or relay.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 01-16-2014, 06:54 PM   #5
dman1982
dman1982's Avatar
Re: heater question
Where are they located?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 01-16-2014, 10:24 PM   #6
old Rusty C10
Re: heater question
pick and pull is a junkyard that allows you to go in and pull your own parts check your local phone directory
Bob
I hate cancer!!
Old 01-17-2014, 12:15 AM   #7
dman1982
dman1982's Avatar
Re: heater question
haha, i understand that...i meant where to look for that
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 01-17-2014, 12:43 AM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
Re: heater question
with AC or without
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 01-17-2014, 10:14 AM   #9
rs74
rs74's Avatar
Re: heater question
Is this an AC truck or non AC? Have you tried pulling your glove box and looking in there? Do that while everything is running. Look in there while moving your vent selector and see if you can find anything that doesn't look right. Take a few pics and put them on this thread if you are not sure.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 01-17-2014, 10:27 AM   #10
rs74
rs74's Avatar
Re: heater question
Also if the resistor is bad check out the blower motor too. If the bearing or anything else starts going bad then it will cause high resistance and burn out the resistor. If by chance the resistor doesn't fix the issue look at the switch in the control panel. You could probably get by for around $50 for blower motor and resistor if your fan cage is good at O'reilly's. If you are not in a hurry for parts look them up on http://www.rockauto.com/
Roy
1987 R10 shortie
Old 01-17-2014, 11:47 AM   #11
dman1982
dman1982's Avatar
Re: heater question
Originally Posted by motornut View Post
with AC or without
i have a/c, and when i unhook that plug my heater works if its hooked up then it don't work...kinda weird i don't know how i discovered that but been like that for 5 years or so
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 01-21-2014, 10:55 AM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
Re: heater question
I'd open that make sure its not shorted/broke inside
a lot have a low speed on all the time for venting
John
Old 01-24-2014, 12:44 AM   #13
dman1982
dman1982's Avatar
Re: heater question
will do man, ill check it out tomorrow...its been acting weird here the last week or so
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
