01-16-2014, 10:24 PM | #1 |
16" 6 lug factory rims ? Question
Anyone heard of an optional 16" factory wheel for a c10 or k10 that was offered by gm?? If so, how wide were these rims 5.5" or 6" ?? Or other? I have been told that larger rims were a factory option. I have seen some before but maybe they were an older vintage that happen to fit thanks erik
01-16-2014, 11:19 PM | #2 |
Re: 16" 6 lug factory rims ? Question
01-17-2014, 12:14 AM | #3 |
What year rims ? These are the early 16x5 3 clip rims used up to 1963. These were replaced by the "nub" style that are also 16x5 used from 1964-1970. These were offered on C10 and K10.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
01-22-2014, 10:33 PM | #4 |
My '62 came with these 16x5 6 lug with the 3 clips to hold the hubcaps. As far as I know they are factory wheels.
10-12-2014, 06:32 PM | #5 |
What kind of caps will for on these type of rims?
10-12-2014, 07:36 PM | #6 |
Check The Champ, Demonstrator
7 5/8" ID for the hubcaps for 15 16 & 17.5" 6 stud wheels with clips.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 10-13-2014 at 10:12 AM. |
10-12-2014, 07:50 PM | #7 |
These are the ones I went with on my rims, not correct for '62 but I love the look! Think they are '55-'59 hubcaps. They were also correct for '60 I believe but smooth, no ribs.
10-12-2014, 09:09 PM | #8 |
My first ever c-10 had 3 piece rims. 6 lug 16 or16.5". That was a long time ago so I dont remember for sure. What I do remember is the truck was a 61 and the tire shop wanted nothing to do with them.
10-13-2014, 02:48 AM | #9 |
does these rims clear front disc brake conversion? picked up a set of these
10-13-2014, 08:17 AM | #10 | |
...ned.
'63 C10 long wide; '61 Corvair Lakewood; '74 BMW 2002tii; '89 BMW 325i, '49 Ford 8N |
10-13-2014, 11:48 AM | #11 |
I really like the three piece rims. Ive got a set of 8 lug 15 in three piece rims. I would like to find a set of 16 in 6 lug two or three piece rims. you can mount a really heavy tire without stretching the beads. I have been fixing split rims for more than 40 years. you need to be careful when fixing them. and if they are not on good condition you scrap them.
10-13-2014, 12:21 PM | #12 | |
10-13-2014, 12:33 PM | #13 |
I want to use then on my trailers. I can get 15 and 16 inch 14 ply lowboy tires that hold 80 pounds of air. most of my trailers have the chev 6 lug pattern hubs. My tilt top trailer has heavy 14 ply bias lowboy tires mounted on 15 inch split rims. I found a source for a 6 bolt hub bearings ect. that will fit on a house trailer axle. Ive replaced the 14.5 tires Dayton rims & hubs. if the 14.5 tires state for mobile home use only their illegal to use on a utility trailer.
10-20-2014, 09:28 PM | #14 |
are these worth restoring...3 seam to match...1 of them looks different...
16x5 wheels |
10-20-2014, 10:01 PM | #15 |
they look worth restoring, lug nut hole look good. Those look like 40's-50's style 16" rims
