Old 12-22-2003, 02:21 AM   #1
tmcdanielhsd
LT1 "L99" Motor
Has anyone had any experience with one of these motors ? Apparently, they are identicle to 5.7l lt1's except they are 4.3l.
At any rate, I have a chance to buy one with all accessories including wiring harness and computer for$700. It only has 35000 miles on it and came out of a wrecked state bureaue of investigation car.
69 C10 2wd, LT1, 4L60E, 4.11
2000 F350, 4wd CC 7.3 PSD, DRW
1995 F350, 2wd, 7.3 PSD, DRW
tmcdanielhsd is offline   Reply With Quote
Old 12-22-2003, 02:38 AM   #2
miket
miket's Avatar
I wouldn't touch it. It's not worth the effort and money. Buy a true LT1....
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
Old 12-22-2003, 03:15 AM   #3
dinnut
dinnut's Avatar
why is it not worth it? an lt1 will run 2-3x more than that. the 4.3l's arent too bad from waht ive heard.
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 12-22-2003, 03:23 AM   #4
neonlarry
neonlarry's Avatar
the only person that I know that has driven a car said it felt like 2 little elves trying to push the car, and having a rather hard time of it. I would pass on that engine and keep looking for an lt1.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 12-22-2003, 03:29 AM   #5
dinnut
dinnut's Avatar
oh. is that why. ok im stupid im thinking of another engine... maybe its the new 4.8 i thought you were talking abotu
70 longbed
496/th400/Ford 9"
Old 12-22-2003, 03:40 AM   #6
miket
miket's Avatar
"baby" LT1's are dogs....plus you get the pain in the A@# optispark to go with it.
Old 12-22-2003, 11:27 AM   #7
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
your lucky they aren't tring to passs it off as an lt1.
most people do.
tommie is offline   Reply With Quote
Old 12-22-2003, 11:51 AM   #8
swdobbs
L99 owner
Its clear a few of the previous posts are speculating and have never driven a L99.
I own a '94 B-body, loaded leather, posi... w/ the L99. I've done some "bolt-ons", a reprogram from BH for $100 and the #4400 beast pulls hard to 138 mph gets 26 mpg without my foot in it.
The only diff is the displacement and the injector size. I will grant that the baby LT1 is down on torque.
Check out the impalassforum.com posts for the L99, I know of a .30 over with LT4 heads and it runs 12's off the bottle.
swdobbs
swdobbs is offline   Reply With Quote
Old 12-22-2003, 12:42 PM   #9
Mark540
How can you tell by looking at teh motor it is not a 350?
1970 GMC Burb 4x4 - 68 Chevy Front, FI LT1, 4L60E
1970 Chevy Impala 47,000 miles
2001 BMW 540i 6-speed
2002 Dodge Ram 1500 4x4 w/20's
Mark540 is offline   Reply With Quote
Old 12-22-2003, 12:49 PM   #10
miket
miket's Avatar
It's next to impossible to tell. They look identical.
An interesting note. All the hoopla about the 94-96 SS and Caprice regarding performance....including the police edition 9C1 was and has been based on the LT1 motor. These cars weigh in excess of 4200lb's....they are heavy.
The true LT1 motor behind these cars was not a monster HP motor...just 260hp. Whats decieving is the 330lb/ft of torque. Torque usually comes from cubic inches, unless there have been performance mods done to a smaller motor to achieve greater output.
One for one, stock for stock, I will take the LT1 5.7 over the L99 anyday.
Old 12-22-2003, 03:07 PM   #11
swdobbs
LT1 v.s L99
I agree apples to apples, the stock LT1's I've driven have it hands down over a stock L99.
However if you truly can end up with all the LT1 parts sans block and heads for the fore mentioned price ($700), it is worth considering. The LT1 small parts will kill a budget build, just ask me about the last set of vette sensors.
I am running an L99 while rebuilding a LT1 block using LT4 heads, the final install will require nothing more than a bump in injecter size to 21/24lbs...same manifold/sensors/exhaust/ECM etc... as simple as it gets.
A good LT1 i.e. Rancho Recyclers in CA goes for $2750.
An extra $2000 buys the "Painless Harness" to run both the L99 and LT1, a good LT1 block, new heads and you have the ability to work out the bugs by running the L99 while you hand built a new .30 over LT1.
swdobbs...
Old 12-22-2003, 06:39 PM   #12
70short
There is the L98 (350) TPI which was A pre LT1 vette motor 85-91(Camaro, Firebird). Also pre Optispark. I think A TPI setup in our trucks would be and fuel efficient!!!
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
