Old 01-19-2014, 12:32 PM   #1
krisner89
krisner89's Avatar
leaking fuel pump?
Started my 72' burb other day just to move it around so its not sitting for long periods of time. Started great, ran fine, no odd noises. I decided to look under the hood after I started it to do a quick visual before I took it down the road.
We just had a bad spell of extremely cold weather(one day the high was only -10,lows were around -30 to -40 at night) so I was looking for freeze plugs leaking,etc... Noticed the fuel pump was shooting gas toward the front of vehicle. What would cause this?
Its the factory fuel pump with inlet/outlet/ and return.
krisner89 is offline   Reply With Quote
Old 01-19-2014, 02:08 PM   #2
pwdcougar
pwdcougar's Avatar
Re: leaking fuel pump?
Cold weather is tough on everything under the hood. Is it the fuel pump housing itself or the hoses? Fuel pumps themselves are relatively inexpensive. Might be time to replace it.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 01-19-2014, 02:15 PM   #3
Sillyoldman
#16876
Sillyoldman's Avatar
I'd chuck a new pump & lines on it. It's an easy job and even if one of the two is not needed it will provide piece of mind.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 01-19-2014, 03:54 PM   #4
vectorit
What?
vectorit's Avatar
Change your oil after you change the fuel pump.
I have seen fuel pumps go bad, and when they do they typically leak fuel into the engine. Which goes with out saying, is very bad for your bearings.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 01-19-2014, 06:40 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
If you have any rubber hoses down there that is the first thing I would check for leaks.
LockDoc
Leon
Old 01-20-2014, 08:15 PM   #6
krisner89
krisner89's Avatar
Hoses are good. Tried to get a photo of where its leaking. Is there a filter in this pump that may need changed. It seems larger than most mechanical fuel pumps I've seen.
Old 01-20-2014, 08:49 PM   #7
LockDoc
LockDoc's Avatar
I lightened the picture but I still can't make out the top of it.
LockDoc
Leon
Old 01-20-2014, 09:31 PM   #8
vectorit
What?
vectorit's Avatar
Just replace it.
There is no filter inside, and the holes it is leaking from are just vents.
Not trying to sound rude, but do not run the engine anymore until you replace it with a new one.
I have had an engine ruined when a fuel pump went bad on it, since while it was pumping fuel to the carburetor it was pumping fuel into the oil pan. I think I drained 3 gallons of unleaded out of the oil drain plug, and when all was said and done the bearings were all washed out thus prompting a full rebuild and a new crank shaft.
Pull the dip stick, and smell the oil to see if it smells like gasoline.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 01-20-2014, 10:21 PM   #9
studda
studda's Avatar
I just replaced the fuel pump in my '53 because it sat for a long time and the bladder dried out and busted. As soon as I saw this, I didn't even crank the engine one more time until I changed the pump and the oil. Don't risk it for such a cheap part. The fuel thins the oil and it doesn't protect the bearings, and it's also a fire hazard under the hood. My grandfather's truck burnt up because of a leaking fuel pump.
studda is offline   Reply With Quote
Old 01-22-2014, 02:20 AM   #10
krisner89
krisner89's Avatar
OK. had to order one. Nobody had the three fitting pump. They all had the two fitting pumps only. Airtex brand for 31.99 at advanced auto parts. Claims to be the only mechanical fuel pump MADE IN USA.hell ya
