Old 01-19-2014, 03:36 PM   #1
tismy55
72 Front Steering Bar name??
what is this front bar called and who sells them mine is bent> or would it be ok to heat it up and straighten it.This is not mine just used the pic to show the bar.
tismy55 is offline   Reply With Quote
Old 01-19-2014, 04:57 PM   #2
jaros44sr
jaros44sr's Avatar
Re: 72 Front Steering Bar name??
Tierod?
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-19-2014, 05:21 PM   #3
tismy55
have any idea who sells them ? are they hollow tube that is threaded on the ends?
Old 01-19-2014, 05:40 PM   #4
Howard Elliott
Don't know what your driving but it looks like the Drag Link. Check Napa
Howard Elliott is offline   Reply With Quote
Old 01-19-2014, 05:43 PM   #5
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Originally Posted by jaros44sr View Post
Tierod?
EDIT: tismy55 I'm assuming you mean the bar that's in line with and just ahead of the axle tube....
x2 - tie rod: only came from GM on 1972 4wd's
(comment removed by staff)
Last edited by ETsC10; 01-21-2014 at 12:27 AM. Reason: offering fs to non-subscriber
Old 01-19-2014, 05:51 PM   #6
tismy55
Yes that bar right in front of the axle that connects the outer tie rod ends.
Old 01-19-2014, 07:34 PM   #7
Chulisohombre
Chulisohombre's Avatar
tie rod.you can make one your self or buy stronger after market ones.if its not too bad you can bend it back.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 01-19-2014, 08:05 PM   #8
tismy55
That's what I was thinking just heat it up and bend it back into position It is not bent that far
Old 01-20-2014, 08:55 PM   #9
2003 silverado
2003 silverado's Avatar
They make a great place to put the TOW STRAP on..(LOL) Just Kidding
!972 K5 Blazer,Highlander,A/C a twin to the one I Had
1972 K/5 Blazer CST Highlander 15YR project
2003 Silverado Crew 2500HD (Daily driver)
1997 Ford focus (Beater)
2003 ford Taurus (student)
2014 Ford Fusion HYB (wife)
2003 Jetta ( Student)
2003 silverado is offline   Reply With Quote
Old 01-20-2014, 09:09 PM   #10
tismy55
looks like it hit a big rock.
Old 01-20-2014, 11:56 PM   #11
2many
2many's Avatar
Drag link runs from steering box down to knuckle. Tie rod connects the two knuckles (at least in the picture shown). You can heat and rebend but it will never be as strong as it's supposed to be. If you have oversize tires or are wheeling it, that's an even bigger concern. Best to replace, or straighten and then sleeve it.
2many is offline   Reply With Quote
Old 01-21-2014, 12:03 AM   #12
tismy55
will another year fit ,,like 73-87
Old 01-23-2014, 03:57 PM   #13
tismy55
I found out it is called tie rod adjusting tube,,now I need to know if a 73-78 blazer tube will work on my 72 ??? Thanks
Old 01-23-2014, 08:03 PM   #14
2many
2many's Avatar
Well, I know the tie-rod ends are different but the adjuster sleeve appears to be the same. I also know the complete axles themsleves interchange (even thought they went from the Dana 44 to the GM 10 bolt around '76 or so). Just not sure on the overall lengths. I'd imagine someone here has a rig from each era and can comment for sure. Or drive around with a tape measure and crawl under a rig in a parking lot or something!
Old 01-23-2014, 08:41 PM   #15
tismy55
I found a new on on LMC Trucks for a 73 up Blazer ,But did not see one for a 72.
