01-19-2014, 04:08 PM | #1 |
wtb 4x4 wheel bearing spindle
wtb 4x4 wheel bearing spindle 1971. I can buy a new hub and bearings, but nobody makes the spindle. I would be interested in The spindle hub and bearings. or just the spindle.
01-19-2014, 07:26 PM | #2 |
Re: wtb 4x4 wheel bearing spindle
Is it for a K10 or K20? Thanks, Dan
01-19-2014, 09:39 PM | #3 |
It's a k10. thank you dan for clarifying that
01-19-2014, 09:45 PM | #4 |
01-20-2014, 12:03 AM | #5 |
In 71 small bearing spindles were used. Around the mid 70s large bearing spindles came out as they held up better. I believe both work in the same hub. Do some research on Spicer 706570X.
-Jim |
01-20-2014, 09:15 AM | #6 |
You can also use the spindle 7 hub assembly from a 73+ ( Corp. 10 bolt )
But you to replace it as an assembly, spindle, bearing & hub because the bearing are a little larger. Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
