My current '67 half ton has the I6. It has never done me wrong, but it seems like getting a V8 is the thing to do. I am intending on getting a new transmission, but should I put in a V8 as well? The purpose of my vehicle is general driving, moving, hauling of small loads (nothing beyond a one-horse trailer). I also here that newer/fuel injected V8's get slightly better gas mileage. Is the V8 worth the money, or is sticking with the I6 a better idea? Thanks in advance for the input.
Re: Good ol' I6 or a New V8?
I have both, drive my I6 more. I don't have a new computerized sbc though so it likes to drink the gas.
-Sterling GIG EM' AGGIES!!!! WHOOOOOOP!!!!! "Whether you think you can or think you can't, you're Right." -Henry Ford 1972 chevy lwb 1934 ford p/u |
Thanks for the info, how much does a computerized carb improve mpgs?
what do you get mpg wise with your I6
#5 | |
Why so??? cheers JohnG |
I would say 14-16 depending on how I drive. I also have the four-on-the-floor with a granny gear, so I generally only use 2nd-4th gears.
Every pickup I see at car shows seems to have a V8, I actually don't think I have seen one in person inthis body stile with the set up I do. A lot of people I have asked said that V8 was the way to go, but people in my community are also oriented toward racing up at the local track.
I went through the same decision, I do not plan on racing it, figured if it lasted 45 years with the inline 6 who am i to change it. That and also the cost to refresh the l6 is WAY less then buying a v8 setup and swapping in.
That being said I do plan on hotrodding the l6, megasquirt and tbi injection to make it fun. |
#9 | |
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
#10 | ||
If you try to please everyone, you will end up pleasing no one. Do what YOU want.
Now if it was me, I would do the opposite of everybody and keep the 6. It's just the way I am. In fact, I am getting rid of my 350 for a 292. |
I got 16-18 with my I6 250 with 3ott. That was before I had the head planed and bored but if you are looking fora cheap build stay with the I6. I replaced my water pump, cam, crank and gears and all the lifters and rods for 140$ and took no time to replace them. As your project progresses you may want a souped up v8 but the I6 is very dependable.
The V8's are popular for good reason: the small block Chevy is one of the most versatile, durable domestic powerplants of the last century. For example, the 350 was first installed in the Camaro in 1967, and was last used in the truck line through, I think, 2002, with the only drastic changes in that run being to the intake and fuel system. But that doesn't mean the I-6 is a bad engine - they don't have the power potential of the 8's, but if you're only going to use your truck for "normal" there's nothing wrong with the inline six. And when you pop the hood bystanders see that long, narrow, torquey powerplant residing underneath and those that know their stuff take notice. Especially with a granny low 4-speed, I think you already have a good powertrain in your truck.
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
![]() Join Date: Sep 2007
It ALL depends your major and GPA...
#15 |
V8!! Def worth the work !
#16 |
Here's a cool vid of a modified 250ci on a dyno. Go to minute 9 if you want to see the nice results:
https://www.youtube.com/watch?v=1p3-...layer_embedded |
#17 |
![]() Join Date: Nov 2013
The best I6 for these trucks is the trailblazer engine. I have seen them bolted in older trucks....amazing engine that has won many awards.
I personally owned one and put into a 1966 chevy nova wagon......made 1400 Horsepower with a turbo on it.....could not break it ![]() |
#18 |
#19 | |
Its blue in color Had to sleeve the block and add a dist driven ff the crank and build a manifold..mileage? ...over 20 |
#20 |
CAN'T FIX NOTHIN
I like the ole six's remember driving dads new one and they are about bullet proof , I like the new engines that everybody is putting in these trucks now but to jump in the ole c10 and fire that 250 up anytime without a care is good too ,
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
#21 | |
I had an adaptor made for the old turbo transmissions.......the person who made it still has the drawing if anyone is interested. The adaptor is for the torque convertor and trans......you tighten the convertor bolts thruu the starter hole pretty impressive engine.....EFI and a four valve.revs to 10,000 rpm |
Tags |
conversion, engine, inline six |
